*elementtestwarpage
Tests 2D and 3D elements for whether or not they pass the warpage element quality check, and puts those that fail on the specified outputmark.
*elementtestwarpage entities markmask angle outputmark dimension contour title
HyperMesh Tcl Modify Command
- entities
 - The entity types to be checked. Currently, only elements is supported.
 - markmask
 - The mark that contains the elements to test.
 - angle
 - The value to use as a threshold beyond which elements should be considered to have failed the test (in degrees).
 - outputmark
 - The mark where HyperMesh should put the elements that fail the test.
 - dimension
 - A code telling to measure the dimension of:
- 2 - Measure 2D elements.
 - 4 - Measure 3D elements.
 - contour
 - A code telling if HyperMesh should:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram.
*createmark(elements,1) "displayed"
*createmark(elements,2)
*elementtestwarpage(elements,1,5,2,2,0,"2D Element Warpage")
      The details of the warpage element quality check can be found in the online help for the Check Element panel.
