*vabs
Generates VABS cross-sectional ply mesh information along with an OptiStruct solver file.
*vabs shell_elements_mark_id, beam_elements_mark_id
HyperMesh Tcl Modify Command
This command generates cross-sectional ply mesh information along with an OptiStruct solver file, taking shell elements and beam elements as input. The ply mesh gets generated by cutting a plane passing through the center of the beam element and intersecting the shell elements. The mesh gets propagated from the cutting points of the shell along the smoothed normals by extracting the numbers of the layers and thicknesses of the plies.
- shell_elements_mark_id
- The ID of the mark containing the shell elements. Valid values are 1 and 2.
- beam_elements_mark_id
- The ID of the mark containing the beam elements. Valid values are 1 and 2.
*createmark elements 1 100-1001
*createmark elements 2 5-8
*vabs 1 2Errors
# Handle error
}Version History
2021.2
