*create_springs
Creates spring elements between selected coincident nodes.
*create_springs entity_type ?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?
HyperMesh Tcl Modify Command
<option>=<value> options can be provided in any order.
- entity_type
 - The type of input entity. Must be set to nodes.
 - DestinationComp =<value>
 - The components to which spring elements will be stored. This is a required option.
 - EntityMark=<value>
 - The ID of the mark containing the nodes. Valid values are 1 and 2.
 - Property=<value>
 - The property ID to be assigned to the spring elements.
 - PropertyMode=<value>
 - The properties to be assigned to the spring elements. This is a required option.
 - System=<value>
 - The system ID to be assigned to the spring elements.
 - Tolerance=<value>
 - The tolerance to consider coincident nodes.
Examples
To create spring elements between selected coincident nodes:
*createmark nodes 1 3-1000
*create_springs nodes EntityMark=1 Tolerance=0.1 DestinationComp=1 PropertyMode=1 Property=8
   # Handle error
}Version History
2019
