*morphupdateendbymvol
Updates the end conditions of edges on selected morph volumes.
*morphupdateenbymvol a_entity_type a_mark_id b_entity_type b_mark_id vector system_id mode
HyperMesh Tcl Modify Command
This command will update the end conditions (free, fixed, main-secondary, or continuous) for edges on the morph volumes specified in the marks. Connecting edges from one group of morph volumes to another is supported as well as specifically dealing with radial and tangential edges for cylindrical morph volume matrices. The results depend on the selected mode.
a_entity_type
Must be set to hypercubes.
a_mark_id
The mark ID of the hypercubes for end 'a'. Valid values are 1 and 2.
b_entity_type
b_mark_id
The mark ID of the hypercubes for end 'b'. Valid values are 1 and 2.
vector
Temporary fixed end orientation vector ID.
system_id
The ID of the origin system for radial and tangential connections (modes 8, 9, 10, and 11).
mode
1 - Free all edges on mvols on a_mark_id
2 - Free edges on mvols on a_mark_id from those on mvols on b_mark_id
3 - Fix all edges on mvols on a_mark_id to vector which are within 45 degrees
4 - Free all edges on mvols on a_mark_id within 45 degrees of vector
5 - Create main-secondary connection between all edges on mvols on a_mark_id to all on mvols on b_mark_id within 60 degrees of each other
6 - Create continuous connection for all edges on mvols on a_mark_id within 60 degrees of each other
7 - Create continuous connection between all edges on mvols on a_mark_id to all on mvols on b_mark_id within 60 degrees of each other
8 - Free all edges on mvols on a_mark_id which run radially from the selected system
9 - Free all edges on mvols on a_mark_id which run tangentially about the selected system
10 - Create continuous connection for all edges on mvols on a_mark_id which run radially from the selected system within 60 degrees of each other
11 - Create continuous connection for all edges on mvols on a_mark_id which run tangentially about the selected system within 60 degrees of each other
12 - Create a continuous connection for all edges on mvols on a_mark_id within 30 degrees of vector
Examples
To create tangencies for all edges which connect roughly parallel end to end:
*createmark hypercubes 1 "all"
*createmark hypercubes 2
*createvector 1 1.0 0.0 0.0
*morphupdateendbymvol hypercubes 1 hypercubes 2 1 0 6
To free tangencies for all edges which run tangentially about a system:
*morphupdateendbymvol hypercubes 1 hypercubes 2 1 1 9
To create a main-secondary tangency for the edges on one morph volume to the edges on another morph volume:
*createmark hypercubes 1 14
*createmark hypercubes 2 15
*morphupdateendbymvol hypercubes 1 hypercubes 2 1 0 5
   # Handle error
Version History
10.0
