*xyplotreadengineeringcurve
Reads in stress/strain information for HyperForm.
*xyplotreadengineeringcurve filename
HyperMesh Tcl Modify Command
filename
The full path and file name for the file containing the stress/strain information.
To read the file named C:/temp/curves.txt:
*xyplotreadengineeringcurve C:/temp/curves.txt
   # Handle error
Version History
13.0
