*hf_setdiestampingdirection
Sets the stamping direction for the die module.
*hf_setdiestampingdirection x_coord y_coord z_coord reserved
HyperMesh Tcl Modify Command
This command sets the stamping direction for the die module.
- x_coord
 - x-coordinate of the vector direction.
 - y_coord
 - y-coordinate of the vector direction.
 - z_coord
 - z-coordinate of the vector direction.
 - reserved
 - Reserved for future use. Must be set to 0.
*hf_setdiestampingdirection 1.0 0.0 0.0 0Errors
   # Handle error
}Version History
11.0
