*createsinglewallbulkhead
Creates a single wall bulkhead inside a C section formed by selected elements.
*createsinglewallbulkhead elems_mark=<mark_id> dom_elem_mark=<mark_id> normal={<value>} plane_point={<value>} flange_width=<value> mesh_elem_size=<value> thickness=<value> offset=<value> materialid=<value> realizeconnectors=<value>? ?connectorcontrolid=<value>?Type
HyperMesh Tcl Modify Command
This command creates single wall bulkhead at the C section formed by selected elements with given width of flanges and sets the thickness property card with given thickness.
- elems_mark=<mark_id>
 - The ID of the mark containing the elements of the C section. Valid values are 1 and 2.
 - dom_elem_mark=<mark_id>
 - The ID of the mark containing the elements from the dominant face of C section. Valid values are 1 and 2.
 - normal={<value>}
 - The normal direction defining the main bulkhead plane.
 - plane_point={<value>}
 - The coordinates of the base point defining the position of the bulkhead.
 - flange_width=<value>
The width of the bulkhead flanges.
 - mesh_elem_size=<value>
 - The element size used for the bulkhead mesh.
 - thickness=<value>
 - The thickness value assigned to the property card of the bulkhead.
 - offset=<value>
 - The extra offset value for the bulkhead flanges. The default offset value is calculated from the C section thickness and the specified bulkhead thickness.
 - materialid=<value>
 - The ID of the material which will be set as the material property for the created bulkhead. This is an optional argument.
 - realizeconnectors=<value>
 - The flag enabling connector realizations.
 - connectorcontrolid=<value>
 - The ID of the connectorcontrol entity used to realize the connectors.
*createmark elements 1 1-9889
*createmark elements 2 8396 8418
*createsinglewallbulkhead elems_mark=1 dom_elem_mark=2 normal={0 0 -1} plane_point={42.6 -21.9 223.9} flange_width=32.0 mesh_elem_size=3.0 thickness=2.0 offset=0.0Errors
   # Handle error
}Version History
2021.1
2021.2 - Added new option materialid.
2022 - Added new options connectorcontrolid and realizeconnectors.
