*surfaceaddpoint
Add a fixed point on a surface at the specified coordinates.
*surfaceaddpoint surfptr x y z
HyperMesh Tcl Modify Command
- surfptr
 - The ID of the surface.
 - x,y,z
 - The coordinates of the point.
The coordinates must be within tolerance of the surface. If the coordinates are within the geometry tolerance of an edge, a surface vertex is created. Otherwise, an interior fixed point is added to the surface.
None.
