*hm_meshutils_cutelements_2points
Cut elements with a box defined by 2 diagonal points.
*hm_meshutils_cutelements_2points element_mark c1x c1y c1z c2x c2y c2z spc_collector_name box_collector_name
HyperMesh Tcl Modify Command
- element_mark
 - The mark of the elements that needs to be cut.
 - c1x, c1y, c1z
 - The coordinates of the point 1.
 - c1x, c1y, c1z
 - The coordinates of the point 2.
 - spc_collector_name
 - The name of the collector in which the spcs will be created for constraining cut elements.
 - box_collector_name
 - The name of the collector in which a hexa might be created to show the cutbox.
Only linear shell elements will be cut properly. For any other type of element, it will simply be deleted if it is completely or partially inside the cut box.
None.
