*usercheck
Runs a template that can be used to check element quality.
*usercheck template file output file all
HyperMesh Tcl Modify Command
- template file
 - The name of the template file.
 - output file
 - The name of the output file.
 - all
 - Determines the entities the template scans.
The template file can use the *markfailed() template command to mark elements that do not pass any user-specified test. *markfailed() highlights the element on the screen and also puts the element on the user mark.
None.
