*elementquality_move_node
Moves a node from its current position to a new position to improve element quality.
*elementquality_move_node entity_id movelength=<value> x=<value> y=<value> z=<value>Type
HyperMesh Tcl Modify Command
Moves a node from its current position to a new position to improve element quality. The command supports three different use cases: move a node to a specific position, translate the node in a specified direction, or translate it along its normal vector.
- entity_id
 - The ID of the node.
 - movelength=<value>
 - The distance to translate the node. The value can be positive or negative.
 - x=<value>
 - The x-component of the directional vector or the x-coordinate of the new position.
 - y=<value>
 - The y-component of the directional vector or the y-coordinate of the new position.
 - z=<value>
 - The z-component of the directional vector or the z-coordinate of the new position.
*elementquality_move_node 15 x=25.5 y=65.9 z=15.9*elementquality_move_node 15 movelength=6.5 x=0 y=1 z=1*elementquality_move_node 15 movelength=6.5Errors
   # Handle error
}Version History
2021.1
