HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  2. HyperWorks Reference Guides
  3. HyperMesh
  4. Scripts
  5. Commands and Functions
  6. Tcl Modify Commands
  7. *view_restoreprevious
    Return to previous view state.
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Reference Guides
Index
HyperWorks Desktop
2022
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
      • Ext API
      • FE Input Readers
      • HMASCII
      • Scripts
        • Introduction
        • Create Scripts
          The functionality of the HyperMesh Tcl Modify Command commands are available through Tcl. Additionally, commands that allow you to extract information from the HyperWorks Desktop database, such as entity ID numbers on a mark, a list of assemblies, component names, elements per component, nodes per element, node values, and so forth. These are known as HyperMesh Tcl Query Command commands. They are used to query information from the database or template system.
        • Run Scripts
        • Commands and Functions
          • Tcl GUI Commands
          • Tcl Modify Commands
            • 1774 more
            • *absoluterotatedummyjoint
              Rotate the dummy’s joint to an absolute position. Rotation occurs first about the X, then Y, then Z.
            • *absorbbeamsections
              FE-absorb 1D properties into beam sections.
            • *absorbentities
              Absorb entities using the tabular segregation interface.
            • *absorbloads
              Absorb classical loads to engineering loads.
            • *absorbmember
              Absorbs existing 1D elements or lines to skeleton entities.
            • *accepteditedsurface_with_user_tolerance
              Moves surfaces from the midsurface to edit component into the middle surface component and stitches surfaces according to a specified tolerance.
            • *acm_create_mpc
              Creates MPCs between selected main and secondary elements.
            • *acousticmeshcreate
              Previews and creates a solid acoustic cavity mesh after running *acousticmeshinit.
            • *acousticmeshend
              Clears memory after previewing or generating an acoustic mesh using *acousticmeshcreate.
            • *acousticmeshinit
              Initializes an acoustic cavity mesh before running *acousticmeshinit.
            • *acousticmeshinterface
              Identifies acoustic cavity interfaces.
            • *acousticmeshinterface_2
            • *activatetransformations
              Apply or unapply all the transformations in the model.
            • *adaptive_triangle_mesh
              Creates an adaptive tria mesh from an STL tria mesh input.
            • *adaptive_wrapper_build
              Builds the skeletal octree structure for the adaptive wrap mesher.
            • *adaptive_wrapper_end
              Terminates the adaptive wrap mesher.
            • *adaptive_wrapper_init
              Initializes the adaptive wrap mesher input elements.
            • *adaptive_wrapper_leak_check
              Checks for leaks from selected elements with specified seed nodes during adaptive wrap meshing.
            • *adaptive_wrapper_leak_check_mc
              Check leakage and generate 1Ds for the leak path for an adaptive wrap mesh control.
            • *adaptive_wrapper_mesh
              Generates an adaptive wrap mesh.
            • *adaptive_wrapper_mesh_mc
              Creates the mesh for selected adaptive wrap mesh controls.
            • *adaptive_wrapper_mesh_reject
              Rejects the *adaptive_wrapper_mesh operation.
            • *adaptive_wrapper_preview
              Previews the cavities for the adaptive wrap mesher.
            • *adaptive_wrapper_preview_clear
              Clears the preview generated by *adaptive_wrapper_preview.
            • *adaptive_wrapper_preview_reject
              Rejects the mesh generated by *adaptive_wrapper_preview and the preparation generated by all *adaptive_wrapper_* commands.
            • *adaptive_wrapper_proximity_params
              Assigns proximity parameters to the adaptive wrapper mesher.
            • *adaptive_wrapper_reject_clear
              Clears the reject buffer for all *adaptive_wrapper_* commands.
            • *adaptive_wrapper_set_features
              Assigns/extracts features for the adaptive wrapper mesher.
            • *adaptive_wrapper_set_params
              Assigns meshing parameters to the adaptive wrapper mesher.
            • *add_multi_washer_elements
              Adds washer elements to circular holes of shell meshes.
            • *add_remove_distance_manipulator
              Adds or removes distance (dimension) manipulators between two surface vertices.
            • *add_rib
              Creates a triangular or quadrilateral rib at a given position.
            • *addedgesorfaces
              Adds faces of solid elements or edges of shell elements to a segment set and contactsurf.
            • *addfacestocontactsurf
              Adds elements using the face/edge option to a contact surface.
            • *addfacestocontactsurfusingfacenumber
              Adds elements using the face number to a contact surface.
            • *addicconnectivity
              Updates the connectivity of an IC element.
            • *addincludetodisplay
              Adds the entities contained in the specified include file to the current display.
            • *addnewmodel
              Used by multiple models to add a new secondary model.
            • *addposition
              Adds a solver position into another solver position entity.
            • *addshellstocontactsurf
              Add selected 1D and 2D element(s) to existing contactsurf.
            • *addtransformation
              Adds transformations to positions.
            • *adjustcontactsurfacenormal
              Adjusts a contact surface normal using an orientation element.
            • *adjustgroupsnormal
              Adjusts a group normal using an orientation element.
            • *adjustmass
              Adjust mass for a selection of components for LS-DYNA.
            • *adjustnodes
              Fixes the penetrations by moving only the failed nodes.
            • *admasconnectivityupdatemultentselectwithvisnod
              Updates mass elements. A visualization node is used when updating and the number of selected entities are greater than one.
            • *admascreatemultentselectwithsets
              Creates mass elements with the option to create the mass on the independent entities or to create a set out of those entities and attach the set to the element mass created.
            • *AE_AttachmentAbsorb
              Absorb FE into attachments.
            • *AE_AttachmentControlConvert
              Convert an existing attachment control to a different config.
            • *AE_AttachmentControlCreateFromAnother
              Duplicate an attachment control.
            • *AE_AttachmentControlCreateFromDefault
              Creates an attachment control that can be used for attachment realizations and saved to the binary file.
            • *AE_AttachmentControlDefaultCreate
              Initializes the attachment control defaults.
            • *AE_AttachmentCreateWithOptions
              Creates attachments with options.
            • *AE_ConvertBoltLinkToAttachment
              Converts connector bolt comp/part links to attachment links.
            • *AE_Realize
              Realize attachments.
            • *AE_Unrealize
              Unrealize attachments
            • *AE_UpdateLink
              Updates the link for selected attachment entities.
            • *align1delemsbysystem
              Aligns 1D elements with respect to global or local system.
            • *alignnode
              Aligns a node along the imaginary line between two other nodes.
            • *alignnode2
              Aligns a node along the imaginary line between two other nodes, using a ratio coefficient.
            • *alignnode3
              Aligns multiple nodes along the imaginary line between two other nodes.
            • *aligntoedges
              Aligns nodes of mesh edges along geometric edges.
            • *allsuppressactive
              Sets the active/inactive state of all supported entities.
            • *allsuppressoutput
              Sets the export/do not export state of all entities.
            • *alternatefejointcreate
              Creates an FE joint element for use with the OptiStruct FE solution sequence.
            • *alternatefejointupdate
              Updates FE joint elements for use with the OptiStruct FE solution sequence.
            • *alternatejointcreate
              Creates a joint element for use with the OptiStruct MBD solution sequence.
            • *alternatejointupdate
              Updates joint elements for use with the OptiStruct MBD solution sequence.
            • *altgapelement
              Creates a node-to-node gap element (CGAP) for use with the OptiStruct solver.
            • *altgapelementupdate
              Updates property and orientation of node-to-node (CGAP) or node-to-element (CGAPG) gap elements.
            • *ameshclearsurface
              Frees memory temporarily allocated for the automesher.
            • *analysiscurvecreate
              Creates a curve by extracting values from a results file.
            • *analysiscurvecreatecomplex
              Creates a curve pair by extracting complex values from a results file.
            • *analysisfileset
              Loads a results file for use in subsequent operations.
            • *analysisfilesetwithsolverids
            • *animatecycles
              Sets the number of animation cycles for the subsequent animation.
            • *animatelegendsetrange
              Sets the animation legend range for transient animation sequences.
            • *animatelinear
              Creates a linear animation from results data.
            • *animatemodal
              Creates a modal animation from results data.
            • *animatetransient
              Creates a transient animation from results data.
            • *answer
              Provides an answer to the previous command for .cmf files.
            • *appendmark
              Appends entities on a mark based on user supplied options.
            • *appendmarksolverdata
              Appends a mark with entities of the given type that match a defined pattern of identifying information.
            • *applybeamsection
              Applies a beamsection to selected members or membersections.
            • *applydisplayattributes
              Sets the components on the graphics component list (select/apply on the menu) to the specified style and color.
            • *applyresults
              Modifies node coordinates by applying displacements from a .res file.
            • *applyresultsasloads
              Create loads at an entity's nodes based on a models result information.
            • *assemblyaddmark
            • *assemblymodify
              Creates or modifies an assembly.
            • *assemblymodifyhierarchy
              Adds an assembly.
            • *assemblyremovemark
              Removes the components within a mark from the components contained in an assembly mark.
            • *assignedplot
              Creates an assigned plot from results data.
            • *assignidpooltocweldelements
              Assigns correct ID Pools to cweld elements when switching from Nastran/OptiStruct to OptiStruct/Nastran profiles.
            • *assignsystem
              References a coordinate system to an element.
            • *assignsystem_fromcurves
              Assigns a system to an entity type based on lines/nodes.
            • *assignsystem_option
            • *assignsystemfromcurveswithnormals
              Assigns a system to an entity type based on curves with surface normal.
            • *associate_nodes_to_geom
              Associates nodes to geometry.
            • *attributeupdate_entityidarray2d
              Updates an attribute that is a 2D array of entity IDs.
            • *attributeupdate_entityidarray2d_mark
              Updates an attribute, which is a 2D array of entity IDs, on a set of entities.
            • *attributeupdatedouble
              Updates an attribute of type double.
            • *attributeupdatedoublearray
              Updates an attribute of type double array.
            • *attributeupdatedoublearray2d
              Updates an attribute of type 2D double array.
            • *attributeupdatedoublearray2delementmark
              Updates one element of an attribute of type 2D double array.
            • *attributeupdatedoublearray2dmark
              Updates an attribute of type 2D double array on a set of entities.
            • *attributeupdatedoublearrayelementmark
              Updates one element of an attribute of type double array.
            • *attributeupdatedoublearraymark
              Updates an attribute of type double array on a set of entities.
            • *attributeupdatedoublemark
              Updates an attribute of type double on a set of entities.
            • *attributeupdateentity
              Updates an attribute of type entity.
            • *attributeupdateentityidarray
              Updates an attribute that is an array of entity IDs.
            • *attributeupdateentityidarray2delementmark
              Updates one element of an attribute of type 2D entity ID array.
            • *attributeupdateentityidarrayelementmark
            • *attributeupdateentityidarraymark
              Updates an attribute, which is an array of entity IDs, on a set of entities.
            • *attributeupdateentitymark
              Updates an attribute of type entity on a set of entities.
            • *attributeupdateint
              Updates an attribute of type int.
            • *attributeupdateintarray
              Updates an attribute of type int array.
            • *attributeupdateintarray2d
              Updates an attribute of type 2D int array.
            • *attributeupdateintarray2delementmark
              Updates one element of an attribute of type integer array.
            • *attributeupdateintarray2dmark
              Updates an attribute of type 2D int array on a set of entities.
            • *attributeupdateintarrayelementmark
              Updates one element of an attribute of type int array.
            • *attributeupdateintarraymark
              Updates an attribute of type int array on a set of entities.
            • *attributeupdateintmark
              Updates an attribute of type int on a set of entities.
            • *attributeupdatesolverid
              Updates an attribute of type solver_id.
            • *attributeupdatestring
              Updates an attribute of type string.
            • *attributeupdatestringarray
              Updates an attribute of type string array.
            • *attributeupdatestringarrayelementmark
              Updates one element of an attribute of type string array.
            • *attributeupdatestringarraymark
              Updates an attribute of type string array on a set of entities.
            • *attributeupdatestringmark
              Updates an attribute of type string on a set of entities.
            • *autocolor
              Automatically colors any collectors that are currently set to gray (colors 10-18).
            • *automesh
              Employs a surface-based automeshing algorithm to generate a mesh on a given surface face.
            • *automesh_mc
              Meshes elements or surfaces using automesh mesh controls.
            • *automesh_params
              Set 2D meshing parameters on edges and faces.
            • *autotopocleanup
              Performs automatic preparation of a model’s topology for meshing, using specified element size and element quality criteria.
            • *autotopocleanup2
            • *autotopocleanuplimited
              Performs a limited set of topology cleanup operations on CAD or FE surfaces.
            • *autoupdate1delems
              Update orientation and/or offset of 1D elements with reference to neighboring shells.
            • *bagdeleteall
              Deletes bags on a mark and all of the child entities within each bag.
            • *bar3element
              Creates a bar3 element.
            • *bar3elementcreatewithoffsets
              Creates a bar3 element with offsets.
            • *bardirectionupdate
              Updates the direction node for multiple bar and/or bar3 elements.
            • *barelement
              Creates a bar element.
            • *barelementcreatewithoffsets
              Creates a bar element with offsets.
            • *barelementorientbysystem
              Orients bar elements along a given direction with respect to an input system.
            • *barelementrotatebyangle
              Rotate bar elements along their respective X-axis using an input angle.
            • *barelementupdate
              Updates the vector (global system), pin flags and property for multiple bar and/or bar3 elements.
            • *barelementupdatebytable
              Update bar elements using an input table.
            • *barelementupdatelocal
              Updates the vector (local system), pin flags and property for multiple bar and/or bar3 elements.
            • *barelementupdatewithoffsets
              Updates the vector, pin flags, property, direction node and offset for multiple bar and/or bar3 elements.
            • *baroffset
              Updates the offsets in the global system for a single bar or bar3 element.
            • *baroffsetupdate
              Updates the offsets in the global system for multiple bar and/or bar3 elements.
            • *baroffsetupdatelocal
              Updates the offsets in the local system for multiple bar and/or bar3 elements.
            • *barpinsupdate
              Updates pins of bar elements.
            • *barrierpositioner
              Positions the barrier according to various protocols with respect to a given vehicle.
            • *batchmesh_mc
              Meshes geometry using BatchMesh mesh controls.
            • *batchparams_update
              Updates the global mesh parameter values.
            • *batchparams_write
              Write the global mesh quality parameters to a file.
            • *BCM
              Creates loads by performing linear interpolation between existing loads or loads defined in a text file.
            • *beamsectionautoconnectshell
              Connects the parts of a shell section.
            • *beams_to_surfaces
              Create surfaces/meshes from 1D beams.
            • *beamsectioncalculateresults
              Calculates results for selected beam sections.
            • *beamsectioncreateatplane
              Creates a shell or solid beam section by cutting a plane through the selected entities.
            • *beamsectioncreateshell
              Creates a shell beam section for HyperBeam.
            • *beamsectioncreateshelldirect
            • *beamsectioncreatesolid
              Creates a solid beam section for HyperBeam.
            • *beamsectioncreatesoliddirect
            • *beamsectioncreatesolidfrompoints
            • *beamsectioncreatestandardsolver
              Creates a standard solver-specific HyperBeam section.
            • *beamsectionsetdatageneric
              Updates the data for a generic type beam section.
            • *beamsectionsetdataroot
              Updates the root data for a beam section.
            • *beamsectionsetdatashell
              Updates the data for a shell type beam section.
            • *beamsectionsetdatasolid
              Updates the data for a solid type beam section.
            • *beamsectionsetdatasolidelems
            • *beamsectionsetdatastandard
              Updates the data for a standard type beam section.
            • *beamsectiontranslate
              Translates a shell or solid beam section within its local coordinate frame.
            • *beamsectionupdateshellpartname
              Renames a HyperBeam shell section part.
            • *belttensioning
              Applies tension on the seat belt and updates its nodes to any intermediate/final configuration, with a choice to maintain the length of the seat belt.
            • *blmesh_2d
              Generates a 2D boundary layer mesh on surfaces/elements.
            • *blmesh_2d_computeblthickness
              Generates boundary layer thickness on boundary nodes, with specified parameters.
            • *blmesh_2d_computeblthickness1
              Generates boundary layer thickness on boundary nodes, with specified parameters and default boundary layer/non-boundary layer type definition.
            • *blmesh_2d_input_bl
              Specifies boundary layer input.
            • *blmesh_2d_input_nonbl
              Specifies non-boundary layer input.
            • *blmesh_2d2
              Generates a 2D boundary layer mesh on boundary layer edges, with specified parameters
            • *blmesh2d_mc
              Imprints edge layers on a surface mesh based on parameters defined in the edge layer control.
            • *blockcontrollines
              Controls the lines on a block.
            • *blockcontrolplanes
              Controls the planes on a block.
            • *blocknodeupdate
              Updates the finite difference nodes in a finite difference block.
            • *blocksetcurrent
              Sets the current block.
            • *blockvisualize
              Creates a fill hide plot of a finite difference block.
            • *blockwalladdcell
              Adds one cell to a finite difference wall.
            • *blockwallcreate
              Creates a wall in a finite difference block.
            • *blockwalldelete
              Deletes a wall from a finite difference block.
            • *blockwalleditrange
              Adds or deletes a range of cells in a finite difference wall.
            • *blockwallfill
              Fills an enclosed plane of cells in a finite difference wall.
            • *blockwallfindintersect
              Intersects one- and two-dimensional finite elements with cells in a finite difference block.
            • *blockwallremove
              Removes all cells from the given finite difference wall.
            • *blockwallremovecell
              Removes one cell from a finite difference wall.
            • *blockwallreset
              Deletes all walls from a finite difference block.
            • *blockwallupdate
              Updates the color of a wall in a finite difference block.
            • *bm_markpreservedcompsboundary
              Flags the boundaries of components to be preserved during batch meshing and autocleanup.
            • *body_split_with_morphed_lines
              Splits surfaces or solids using swept lines.
            • *body_split_with_points
              Split a set of solids or surfaces along a spline constructed from a series of specified points.
            • *body_split_with_swept_lines
            • *body_trim_with_templine
              Trim selected solids or surfaces by sweeping line constructed from input coordinates in input direction.
            • *boolean_merge_solids
            • *calculateElemDrapingAngles
              Calculates the draping angles of elements associated with ply.
            • *calculateproximityelements
              Used to determine the proximity distance between elements.
            • *carddelete
              Deletes a control card.
            • *carddisable
              Disables an existing control card from being output through the template system.
            • *carddisablebyid
              This command allows browsers to disable duplicate control cards by id and name.
            • *cardenable
              Enables an existing control card to be output through the template system.
            • *cardenablebyid
              This command allows browsers to enable duplicate control cards by id and name.
            • *CE_AddLinkEntities
              Update connectors with entities.
            • *CE_AddLinkEntitiesDirectByRule
              Allows the user to add link directly to the connectors without considering tolerance or number of layers.
            • *CE_AddLinkEntitiesWithArrays
              Update connectors at the specified locations with arrays.
            • *CE_AddLinkEntitiesWithDetails
              Update connectors at the specified locations with rules and other details.
            • *CE_AddLinkEntitiesWithRules
              Update connectors at the specified locations with rules.
            • *CE_AddLinkEntitiesWithXYZs
              Update connectors as group links with criteria.
            • *CE_BoltAutoCreateFromAttachments
              Creates bolt connectors from attachments.
            • *CE_Cleanup
              Sets connectors to unrealized and back to a clean undefined state.
            • *CE_ConnectorAreaCreate
              Create area connector(s) at the specific location(s) by mark with certain rules.
            • *CE_ConnectorAreaCreateFromList
              Create area connector(s) at the specific location(s) by list with certain rules.
            • *CE_ConnectorAreaMapMesh
              Use the projections of components or elements to mesh area connectors.
            • *CE_ConnectorAreaMesh
              This command meshes area connectors.
            • *CE_ConnectorAreaMeshWithDetails
              Meshes area connectors and updates the width and offset stored on the connector.
            • *CE_ConnectorAreaTrim
              Trim/split area connectors using nodes.
            • *CE_ConnectorCombine
              Combines connectors.
            • *CE_ConnectorCreate
              Creates spot connector(s) at the specified location(s) by mark.
            • *CE_ConnectorCreateAndFERealizeForTrimMass
              Create apply mass connectors at the specified location with certain rules, and realize them using a specified config type, mass value and distribution type.
            • *CE_ConnectorCreateByAutopitch
              Create connectors using autopitch points, obtained by flange detection techniques.
            • *CE_ConnectorCreateByAutopitchNew
            • *CE_ConnectorCreateByAutoseam
              Creates line connectors between the input components.
            • *CE_ConnectorCreateByList
              Creates a certain style of connector at locations specified by a list, with certain rules and details.
            • *CE_ConnectorCreateByListAndRealizeWithDetails
              Creates a certain style of connector at locations specified by a list, with certain rules and details, and realize the connectors using specified realization details.
            • *CE_ConnectorCreateByListWithCC
              Creates a connector from a list and assigns a connectorcontrol/connectorcontroldefault.
            • *CE_ConnectorCreateByMark
              Creates a certain style of connector at locations specified by a mark, with certain rules and details.
            • *CE_ConnectorCreateByMarkAndRealizeWithDetails
              Create a certain style of connectors at locations specified by mark using certain rules and details, and realize them using specified details.
            • *CE_ConnectorCreateByMarkWithCC
              Creates a connector from a mark and assigns a connectorcontrol/connectorcontroldefault.
            • *CE_ConnectorCreateWithRules
              Creates connector(s) at the specified location(s) with defined rules.
            • *CE_ConnectorGroup
              Group or ungroup seam connectors on mark to behave as a single/multiple seam connector(s).
            • *CE_ConnectorGroupCreateAndOrganizeConnectors
              Create new connector group(s) and reorganize connector(s) inside them based on criteria given.
            • *CE_ConnectorLineCombine
              Combines multiple line connectors to a single line connector.
            • *CE_ConnectorLineCombineWithCC
              Combines multiple line connectors to a single line connector and assigns a connectorcontrol.
            • *CE_ConnectorLineCreate
              Creates connector(s) on the lines at the given density or spacing.
            • *CE_ConnectorLineCreateWithRules
            • *CE_ConnectorPartition
              Partitions seam connectors.
            • *CE_ConnectorRemoveDuplicates
              Deletes connectors that are considered to be duplicates of other connectors within a given tolerance.
            • *CE_ConnectorSeamCreateUsingLinelist
              Create seam connectors at specified locations by line list with certain rules.
            • *CE_ConnectorSeamCreateUsingLines
            • *CE_ConnectorSeamTrim
              Trim/split seam connectors using nodes.
            • *CE_ConnectorSetVectorById
              Sets the projection vector for a connector specified by ID.
            • *CE_ConnectorSetVectorByMark
              Set projection vector for connectors specified by mark.
            • *CE_ConnectorSpotTrim
              Trims/splits spot line connectors using nodes.
            • *CE_ConnectorsUpdateByMetadata
              Extracts link and other information from the connector location entity and applies it on the connector.
            • *CE_ConnectorTrimAdvanced
              shortDescription
            • *CE_ConnectorUpdateByCC
              Updates connectors using a connector control or connector control default.
            • *CE_ConvertByMark
              Converts between bolt and spot connectors.
            • *CE_ConvertByMark_new
              Converts several spot or bolt connectors into a spotline or boltlline.
            • *CE_ConvertLinksByMark
              Converts connector links to a new entity type.
            • *CE_CreateNodeOnSeamConnector
              Creates a node on a seam connector at a given position.
            • *CE_CreateNodeOnSpotConnector
              Creates a node on a spot line connector at a given position.
            • *CE_DetailDelete
              Delete connector details (stored in connector metadata) from connectors specified by ID.
            • *CE_DetailDeleteByMark
              Delete connector details (stored in connector metadata) from connectors specified by mark.
            • *CE_DetailsCopy
              Copy realization details from a connector to a list of connectors.
            • *CE_DetailSetDouble
              Sets a double connector detail for a single connector.
            • *CE_DetailSetDoubleByMark
              Sets a double connector detail for a mark of connectors.
            • *CE_DetailSetInt
              Sets an integer connector detail for a single connector.
            • *CE_DetailSetIntByMark
              Sets an integer connector detail for a mark of connectors.
            • *CE_DetailSetString
              Sets a string connector detail for a single connector.
            • *CE_DetailSetStringByMark
              Sets a string connector detail for a mark of connectors.
            • *CE_DetailSetTriple
              Sets a triple connector detail for a single connector.
            • *CE_DetailSetTripleByMark
              Sets a triple connector detail for a mark of connectors.
            • *CE_DetailSetUint
              Sets an unsigned integer as connector detail for a connector specified by ID.
            • *CE_DetailSetUintByMark
            • *CE_DetermineConnectionType
              Determines the seam connectors' connection type.
            • *CE_EditSeamAndLineDetail
              Edit density, spacing and offset details for seam or line spot connectors specified by mark.
            • *CE_ErrorSet
              Assign a pre-defined error code to a connector.
            • *CE_ExportFile
              Export connectors in the native XML/ASCII format.
            • *CE_ExportFiles
              Export connectors to their original files in their original or specified format.
            • *CE_ExportMainConnectorsFile
              Export the connector information to a main connectors file.
            • *CE_ExportOneFile
              Export connectors which belong to specified original file in their original or specified format.
            • *CE_FE_1DQuality
              Checks the quality of 1D elements (welds) created by realizing connector entity (CE).
            • *CE_FE_3DQuality
              Checks the quality of 3D elements (welds) created by realizing connector entity (CE).
            • *CE_FE_Absorb
              Absorbs certain FE information into connectors.
            • *CE_FE_AutoRegisterSharedEntitiesByMark
              Auto register pre-existing entities to multiple connectors.
            • *CE_FE_CreateDCC
              Creates all connector control default entities.
            • *CE_FE_CreateUCCFromConnector
              Creates a connector control from a connector.
            • *CE_FE_CreateUCCFromDCC
              Creates a connector control from a connector control default.
            • *CE_FE_CreateUCCFromUCC
              Creates a connector control from another connector control.
            • *CE_FE_GlobalFlags
              Set global flags for connectors to perform different operations.
            • *CE_FE_LoadFeConfig
              Load or unload an FE config file.
            • *CE_FE_RealizeWithDetails
              Realize existing connectors, using specified details.
            • *CE_FE_Register
              Registers pre-existing FE to a single connector ID.
            • *CE_FE_RegisterAdvanced
              Registers pre-existing FE to multiple connector IDs.
            • *CE_FE_RegisterSharedEntities
              Registers pre-existing entities to a single connector.
            • *CE_FE_RegisterSharedEntitiesByMark
              Registers pre-existing entities to multiple connectors.
            • *CE_FE_SetCommonDetails
              Sets common parameters required to realize connectors as welds.
            • *CE_FE_SetDetails
              Set FE realization details for the connectors on a mark.
            • *CE_FE_SetDetailsAndRealize
              Set FE realization details for the connector(s) on mark and realize them with welds.
            • *CE_FE_SetSpecificDetail
              Changes a single FE realization detail for connectors on the mark.
            • *CE_FE_SetSpecificDetailById
              Changes a single FE detail for a connector specified by ID.
            • *CE_FE_UCCUpdateByDCC
              Updates a connector control using a connector control default.
            • *CE_FE_UCCUpdateUseConnector
              Updates a connector control using a connector.
            • *CE_FE_UnregisterRealizedEntities
              Unregister the realization entities from connectors.
            • *CE_FE_UnregisterSharedEntitiesByMark
              Un-register registered entities from multiple connectors.
            • *CE_GlobalSetDouble
              Set global double parameters relating to the display of connectors.
            • *CE_GlobalSetInt
              Set global integer parameters relating to the display of connectors.
            • *CE_GlobalSetString
              Set a value to a global string variable.
            • *CE_MarkCombineLinks
              Combine the individual/group links into a single group link.
            • *CE_MarkRemoveLink
              Remove a link entity of a specific type and ID or name from the connectors on mark.
            • *CE_MarkRemoveLinkMark
              Remove link entities of a specific type and ID or name from the connectors on mark.
            • *CE_MarkReplaceLinkEntities
              Replaces the links from scratch in connectors.
            • *CE_MarkSplitLink
              Split group links into individual links.
            • *CE_MarkUpdateLink
              Allows search and replace of an existing link in the specified connector mark with a new link entity.
            • *CE_MarkUpdateLinkGroup
              Allows search and replace of existing link information in the specified connector mark with new link information.
            • *CE_MarkUpdateLinkMark
              Allows search and replace of existing links in the specified connectors with new link information.
            • *CE_PositionConnectors
              Positions connectors to the middle point or back to the source location.
            • *CE_PreviewBoltCylinder
              Set cylinder bolt parameters for bolt connectors and display the graphical preview.
            • *CE_PreviewCombine
              Find connectors that need to be combined and place them on the output mark.
            • *CE_PreviewDuplicates
              Find duplicate connectors and place them on the output mark.
            • *CE_ProjectionCheck
              Check quality of projections with connectors.
            • *CE_ReadXmlString
              Creates a connector from an XML string.
            • *CE_Realize
              FE realize all the defined connectors on mark (creates FE).
            • *CE_RemoveLink
              Remove a link entity of a specific type and/or ID/name from a connector entity.
            • *CE_ReverseSigPoints
              Reverses the direction of a line connector.
            • *CE_ReviewConnectorCollectors
              Review connectors by collector according to user options.
            • *CE_ReviewConnectorsReverse
              shortDescription
              Review connectors according to user options.
            • *CE_ReviewLinks
              Review links according to user options.
            • *CE_SetGlobalSharedEntitySettings
              Set the global shared entity management settings.
            • *CE_SetLinkChangeManagerSettings
              Modifies/unrealizes/rerealizes connectors when there is change in attribute values or deletion of referenced entities.
            • *CE_SetSpecificDetail
              Sets a specific detail for all the connectors on the mark.
            • *CE_SetSpecificDetailById
              Sets a specific detail for a specific connector ID.
            • *CE_Unrealize
              FE unrealize all the defined connectors on mark (removes all created FE).
            • *CE_UpdateCustomMessage
              Attaches a custom error message to a connector.
            • *CE_UpdateLink
              Allows search and replace of an existing link in the specified connector with a new link entity.
            • *cfdoutput
              Writes a CFD output deck.
            • *change_edgedensities
              Changes the densities of selected surface edges and remeshes the adjacent surfaces, according to the specified mode.
            • *change_edgedensities_advanced
              Changes the edge density and remeshes only the given layers of elements on the surface attached to the edge.
            • *check_symmetric_mesh
              Checks whether a selection of meshes is symmetric.
            • *check_symmetric_surfaces
              Checks whether a selection of surfaces is symmetric.
            • *checkpenetration
              Checks a group of elements for penetrations and/or self-interference.
            • *cleanmember
              Performs cleaning operations on selected members.
            • *cleanup_unoffsetable_nodes
              Smooths the area around any unoffsetable nodes to attempt to make them offsetable.
            • *cleanupmodelfile
              Cleans up model specific data after a box trim operation.
            • *clearallidranges
              Clears all ID ranges for various portions of a model.
            • *clearallpreservednodes
              Clears the preserve nodes flag from all the nodes that were marked as preserved.
            • *clearallunresolvedids
              Removes from the unresolved IDs database all entries for a specified entity type.
            • *clearlist
              Clears the specified list.
            • *clearlock
              Clears all entity locks.
            • *clearlock2
            • *clearmark
              Clear all entity IDs of the passed entity type from the specified mark.
            • *clearmarkall
              Clear all entity IDs for all entity types from the specified mark.
            • *clearpreservednodes
              Clears the selected nodes that were marked as preserved.
            • *clearunresolvedid
              Removes from the unresolved IDs database a single ID for a specified entity type.
            • *clearunusedunresolvedids
              Audits the list of unresolved ID references and discards any which are no longer needed.
            • *coarsen_and_decimate_mesh2
              Performs mesh coarsening and decimation on selected components.
            • *coarsening_mesh
              Performs mesh coarsening on selected components.
            • *collectormarkmove
              Moves and/or sorts the entities on a mark.
            • *collisioncheck_temp
              Performs a collision detection.
            • *collisioncheck2_temp
            • *collisionfix_temp
              Fix collisions by moving nodes.
            • *collisionrecheck_temp
              Updates the results of a collision check.
            • *colormapedit
              Modifies a color in the color map.
            • *colormark
              Colors the entities on a mark a specified color.
            • *combineelements
              Combines the selected elements into one.
            • *combineplotels
              Creates a line from a group of plot elements.
            • *compactsubmodelids
              Renumbers ID ranges starting from the minimum allowed ID.
            • *complexanimatemodal
              Creates a complex modal animation from results data.
            • *compositeanalysis
              Analyzes composite materials, plies, sequences or laminates.
            • *compute_midmesh_thickness
              Calculates the thickness of a midmesh and assigns properties.
            • *computeboundarylayerthickness
              Calculates the boundary layer thickness reduction factors based on the proximity used for the boundary layer mesh generation.
            • *configedit
              Changes the configuration of a selection of elements.
            • *configurationsuppressactive
              Sets the active state for configurations entity type.
            • *connect_surfaces_11
              Extends surfaces to meet other surfaces.
            • *contactsurfcreatewithfaces
              Creates a contact surface using 2D element edges or 2D/3D element faces.
            • *contactsurfcreatewithfacesusingfacenumber
            • *contactsurfcreatewithshells
              Creates a contact surface using 1D or 2D elements.
            • *contourplot
              Creates a contour plot from results data.
            • *control_sum_print
              Outputs a control sum number to the specified text file.
            • *convertbeamsection
              Updates the target solver ID for beamsections.
            • *convertcord3rtocord1r
            • *convertelements
              Converts certain elements from one solver to another.
            • *convertlegacyentities
              Converts any of the source legacy entities, in a particular solver interface, to a specified target entity.
            • *convertinclude
              Converts a regular include file into an include transform include file or vice versa.
            • *convertthermalloads
              Converts thermal loads from one solver to another.
            • *convertthickness
              Converts the thickness of the specified entities to the target solver.
            • *convertunit
              Converts entity values from one unit system to another unit system.
            • *copy_feature
              Copies a selection of elements and pastes them onto the displayed shell elements at the target location.
            • *copymark
              Copies entities from one collector to another.
            • *copymarkgroup
              Copies main/secondary elements from one group to another.
            • *correctoverflowsubmodelentityids
              Corrects an entity ID range overflow for a submodel.
            • *create_batch_file
              This command sets a limited set of cleanup parameters directly in the command file for use with *autotopocleanup.
            • *create_bead_elements
              Creates a bead on 2D elements.
            • *create_lines_by_mesh_plane_intersection
              Create the lines at the intersection between input elements and a plane.
            • *create_shell_mesh_features
              Generates plot elements between 2D elements.
            • *create_solid_from_eight_points
              Creates a solid from eight points.
            • *create_springs
              Creates spring elements between selected coincident nodes.
            • *create_tube_midline
              Creates midlines from tube solids.
            • *create_voxel_lattice_mesh
              Creates 1D and 2D axis parallel lattice meshes.
            • *createairbag
              Creates an airbag control volume.
            • *createandadjustmass
              Adjusts mass for a selection of source components by creating solvermasses on the target components.
            • *createandmanagesetsandcontents
              Creates a hierarchy of set entities to include all entities on a given mark according to set creation rules specified in a configuration file.
            • *createarray
              Creates an array of integers for use in a subsequent command.
            • *createautoddp
              Create a design points from the selected elements.
            • *createbestcirclecenternode
              Creates a node or a point at the center of the circle that best approximates the input set of lines or points.
            • *createCAERO1
              Creates an aero component of type CAERO1.
            • *createcaero1panelmeshing
              Creates a component for aeroelastic panel mesh CAERO1.
            • *createcaero2bodymeshing
              Creates a component for aeroelastic panel mesh CAERO2.
            • *createCAERO2card
              Creates a body component of type CAERO2.
            • *createcenternode
              Creates a node at the center of a circle defined by 3 input nodes.
            • *createcirclecenterpoint
              Creates a point at the center of a circle defined by 3 input points.
            • *createcirclefromcenterradius
              Creates a circle or arc given the center and radius.
            • *createcirclefrompointplane
              Creates a circle or arc by spinning a point about the normal vector of a plane.
            • *createcirclefrompoints
              Creates a circle or arc from 3 nodes.
            • *createcollectorforpartiallycontained
              Creates a collector and moves certain entities into the collector.
            • *createconnectionelements
              Creates elements of a specified type between input nodes and nodes determined from the nearest elements within tolerance.
            • *createcontrolvol
            • *createcrbrelation
              Creates a main-secondary relationship for LS-DYNA *CONSTRAINED_RIGID_BODIES keyword.
            • *createdoublearray
              Creates an array of doubles for use in a subsequent command.
            • *createdoublearray2d
              Creates a 2D array of doubles for use in a subsequent command.
            • *createdoubler
              Creates a doubler by offsetting elements at a C section formed by selected elements.
            • *createdummytargetpoints
              Creates design points with 'TargetPoint' configuration.
            • *createdummytargetpointsfromcsv
              Creates design points with ‘TargetPoint’ configuration.
            • *createdynamicdataname
              Creates a dynamic dataname on an entity.
            • *createelement
              Creates an element from a node list.
            • *createelements
              Create multiple 1D elements from a list of nodes.
            • *createelements1d
              Creates 1D beams, bars and rods, and optionally assigns properties to created elements.
            • *createelementsbetweennodes
              Creates a spotweld element between two surfaces at the selected nodes with an element type, coordinate system, and property ID.
            • *createelementsbetweenpoints
              Creates a spotweld element between two surfaces at the marked points with an element type, coordinate system, and property ID.
            • *createellipsoids
              Creates one or more ellipsoids based on the information given.
            • *createellipsoidsbypoints
              Creates one or more ellipsoids based on the information provided.
            • *createentitiesfromsource
              Creates entities using an external source file.
            • *createentity
              Create a new entity with specified data.
            • *createentityarray2d
              Creates a 2D array of entities for use in a subsequent command.
            • *createentitypanel
              Allows you to interactively select a single entity
            • *createentitysameas
              Create a new entity that is a clone of a source entity.
            • *createfacesonfreeboundaries
              Creates face elements on all free solid element boundaries.
            • *createfbddisplacementtable
              Creates an FBD displacement summary table.
            • *createfbdfilefromfbdsummarytable
              Creates a .fbd file from an FBD summary table.
            • *createfbdgroupfortraceplot
              Creates a freebodygroup entity, used for FBD trace plots.
            • *createfbdreport
              Creates a report for FBD panel and FBD bar from panel and freebodysection entities respectively.
            • *createfbdsummarytable
              Creates an FBD summary table or min/max table.
            • *createfillet
              Creates a fillet between two lines.
            • *createfilletmidlines
              Recognize fillet surfaces of triangular or rectangular shape, and split strings of fillets down to their longitudinal center lines.
            • *createflattenfold
              Creates a flatten fold setup for solver run to get the resulting position of airbag.
            • *createfoldingtable
              Creates an airbag folding table.
            • *createidrange
              Creates an ID range.
            • *createinclude
              Defines a new include file in the database.
            • *createincludeperpart
              Create a new include file for prototype parts that do not have an include.
            • *createintarray2d
              Creates a 2D array of integers for use in a subsequent command.
            • *createintersectionsegments
              Creates intersection segments as plot elements from the results of hm_collisioncheck.
            • *createjointelement_twonoded
              Creates a two-noded joint element.
            • *createlist
              Creates an ordered list of entities for use in a subsequent command.
            • *createlistbypathpanel
              Provides a panel to create an ordered list of entities for use in a subsequent command, with the collector set to "by path".
            • *createlistpanel
              Provides a panel to create an ordered list of entities for use in a subsequent command.
            • *createmark
              Places entities on a mark based on user-supplied options.
            • *createmarklast
              Populates the mark with the entities used in the last command.
            • *createmarkpanel
              Provides a panel to add entities to a mark.
            • *createmultiplespotwelds
              Creates multiple spotwelds between a set of nodes on the finite element mesh for a given type of element, coordinate system, and property ID.
            • *createnodesandspotweldelems
              Creates nodes and spotweld elements between two surfaces on the selected lines at a specified spacing or density with an element type, coordinate system, and property ID.
            • *createnodesbetweennodelist
              Creates nodes between each pair of nodes along a list.
            • *createnodesbetweennodes
              Creates a user-specified number of nodes between two nodes.
            • *createorthotropicdirection
              Creates the INSHE/ORTHO_LOC tables based on the composite data in the session.
            • *createplane
              Defines a plane for use in a subsequent command.
            • *createpoint
              Creates a point in space.
            • *createpointsbetweenpoints
              Creates a specified number of points between points.
            • *createpointsbetweenpositions
              Creates midpoints between two geometric positions in space.
            • *createpositionformech
              Creates a new position for a mechanism.
            • *createreferencegeometry
              Creates a reference geometry control volume.
            • *createrollfold
              Creates a rolling fold setup for solver run to get the resulting position of airbag.
            • *createsectioncut
              Computes area moments of inertia from a section cut, and creates beam elements along the cuts.
            • *createsensor
              Creates a sensor entity.
            • *createsimplefold
              Creates a simple fold setup for solver run to get the resulting position of airbag.
            • *createsinglewallbulkhead
              Creates a single wall bulkhead inside a C section formed by selected elements.
            • *createsolidsfromshells
              Creates solid elements from shell elements.
            • *createspotweld
              Creates a spotweld between two nodes on the finite element mesh for a given type of element, coordinate system, and property ID.
            • *createstringarray
              Creates an array of strings for use in a subsequent command.
            • *create_thin_solid_midline
              Constructs midline of a section cut through selected solids.
            • *createtuckfold
              Creates a tuck fold setup for solver run to get the resulting position of airbag.
            • *createvector
              Defines a vector for use in a subsequent command.
            • *createweldelemsfromalinelist
              Creates weld elements between surfaces using a line list to determine the weld points.
            • *createweldsbetweencompsusingpoints
              Creates weld element(s) between pre-existing components at the given point(s).
            • *createweldsbetweenelemsusingnodes
              Creates weld element(s) between pre-existing elements at the given node(s).
            • *createweldsbetweenelemsusingpoints
              Creates weld element(s) between pre-existing elements at the given point(s).
            • *createzigzagfold
              Creates a zigzag fold setup for solver run to get the resulting position of airbag.
            • *criteria_update
              Updates the global mesh quality values.
            • *criteria_write
              Writes the global mesh criteria to a file.
            • *currentcollector
              Sets the current collector.
            • *curveaddpoint
              Adds a new point in the curve.
            • *curvedeletepoint
              Deletes a point from the curve.
            • *curvemathexternalfilter
              Runs an external filter on a curve.
            • *curvemodifypointcords
              Modifies the x or y coordinate of an existing point on a curve.
            • *cut_hole
              Creates holes of a predefined shape on selected mesh or surfaces.
            • *cuttingplanereverse
              Reverses a cutting plane display orientation.
            • *decimate_mesh
              Performs mesh decimation on selected components.
            • *defaultmeshelems
              Meshes a selection of elements using saved or default parameters and various options.
            • *defaultmeshsurf
              Meshes a selection of surfaces using saved or default parameters and various options.
            • *defaultmeshsurf_growth
              Generates surface meshes using surface deviation parameters with growth ratio transitions given by refinement sizes defined on points, edges and surfaces.
            • *defaultremeshelems
              Re-meshes a selection of elements using various options, and deletes the original elements.
            • *defaultremeshsurf
              Re-meshes a selection of surfaces using saved or default parameters and various options, and deletes any elements already meshed on those surfaces.
            • *deformedshape
              Creates a deformed shape plot from results data.
            • *delaunay_2d_3d
              Performs 2D/3D triangulation of selected nodes.
            • *delete_logo
              Removes geometric logos.
            • *deleteedges
              Deletes the edges if any in the current database.
            • *deletefeatures
              Deletes the features in a model.
            • *deletefile
              Deletes a file.
            • *deletefillet
              Deletes a fillet from a line.
            • *deleteidrange
              Deletes an ID range.
            • *deletemark
              Deletes entities from the database.
            • *deletemodel
              Deletes all of the entities in a database
            • *deletesolidswithelems
              Deletes solids. Includes the option to keep boundary surfaces, and an option to keep attached elements.
            • *DeleteUC
              Deletes connector/attachment control for a given page, engineering, and control name in control manager.
            • *dependencycheck
              Checks nodes for multiple dependence.
            • *descriptormove
              Moves the plot descriptor.
            • *descriptorsetcolor
              Sets the color of the plot descriptor.
            • *descriptorsetfont
              Sets the font for the plot descriptor.
            • *descriptorsettext
              Sets the text which should be displayed in the plot descriptor.
            • *detach_fromelements
              Detaches elements from selected elements or nodes.
            • *detach_fromwall
              Detaches elements from each other and from the attached structure, using the specified offset value.
            • *detach_solids
              Separates solids that have shared boundary surfaces.
            • *detachallelements
            • *detachelements
              Detaches elements as a unit from the attached structure, using the specified offset value.
            • *detectandcreateface2facecontacts
              Detects if the specified components are within the contact distance specified and creates contact entities relevant to the solver interface.
            • *detectandcreatefeatures
              Detect all feature types within the filter options and create feature entities.
            • *display_thickness
              Sets or graphically reviews the thickness assigned to a midsurface.
            • *displayall
              Turns on the display of all entities in the model.
            • *displaycollector
              Controls the display state of a collector.
            • *displaycollectorsall
              Controls the display state of all collectors.
            • *displaycollectorsallbymark
              Turns the display of a mark of entities on or off, including toggling their current state.
            • *displaycollectorsbymark
              Changes the display state of collectors in a mark.
            • *displaycollectorwithfilter
              Changes the active state of a collector using the menu filter.
            • *displayelementsbyproperty
              Controls the display of elements that have either a direct, indirect or mixed property assignment.
            • *displayelementsbypropertybymark
              Controls the display of elements that have either a direct, indirect or mixed property assignment for a selection of properties.
            • *displayincludeonly
              Displays all entities contained in the specified include file, and hides all other entities.
            • *displaynone
              Turns off the display of all entities in the model.
            • *draglinetoformsurface
              Drags a trimmed line to create a surface, and optionally, prepares it for immediate use within the automesher.
            • *dragnodestoformsurface
              Drags a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher.
            • *drawlistresetstyle
              Resets the display mode on the draw list to the default.
            • *dummyautomaticpositioner
              Positions a dummy to an optimal position based on a list of design points with 'TargetPoint' configuration and a list of bodies that are free to move.
            • *dummyplacerootbodytopoint
              Moves a dummy from a source point to a target point.
            • *duplicateandreflectskeletonentities
              Duplicates and reflects skeleton entities – member joints, members and member panels along the symmetry plane.
            • *duplicateentities
              Duplicates elems, nodes and comps along with any attached loads.
            • *duplicatemark
              Duplicates entities.
            • *dynamicrotatemode
              Sets mode for output of intermediate rotation commands.
            • *dynamicviewbegin
              Begins a block of *rotate(), *window(), or *quatrotate() commands.
            • *dynamicviewend
              Ends a block of *rotate(), *window(), or *quatrotate() commands.
            • *edgerelease
              Unstitches the selected edge.
            • *edgerestore
              Unsuppress the selected edge.
            • *edgesmarkaddmidpoint
              Splits each of the input face edges at its midpoint by adding a fixed point on the edge.
            • *edgesmarkrelease
              Unstitches each of the input edges.
            • *edgesmarkrestore
              Unsuppresses a group of edges.
            • *edgesmarkrestorejoints
              Restores previously suppressed fixed points on edges.
            • *edgesmarksuppress
              Suppresses a group of edges.
            • *edgesmarkuntrim
              Removes the specified trimming lines from their surface.
            • *edgesmerge
              Combines two edges to create one unsuppressed common edge.
            • *edgesuppress
              Suppresses the selected edge.
            • *editmarkpanel
              Provides a panel to add or remove entities to a mark.
            • *element_smooth_nodes
              Smooth a selection of elements with optional anchor nodes.
            • *element1dswitch
              Switches the order of 1D element nodes.
            • *element2Dalign
              Aligns the order of nodes in 2D elements based on the nodes of attached 1D elements.
            • *element2Dshiftnodes
              Reorders the nodes in a 2D element.
            • *element3Dalign
              Aligns the order of nodes in 3D elements based on the nodes of attached 2D/3D elements.
            • *element3Dshiftnodes
              Reorders the nodes in a 3D element.
            • *elementchecksettings
              Specifies the methods for calculating element quality checks which are generally those used by an FE solver.
            • *elementmarksplit
              Splits a group of elements based on a graphical split line.
            • *elementqualitycollapseedge
              Collapses an edge between two elements.
            • *elementqualitycollapseelems
              Collapses/combines two adjacent trias into a quad.
            • *elementqualitydragtriaelem
              Moves a tria element towards a specified point within the interactive cleanup tool.
            • *elementqualitymodifyhole
              Modifies holes in a mesh using radial, angular and circumferential adjustment methods.
            • *elementquality_move_node
              Moves a node from its current position to a new position to improve element quality.
            • *elementqualityoptimizeelement_2
              Optimizes 2D element node locations to improve the element and adjacent elements’ quality index according to pre-set quality criteria.
            • *elementqualityoptimizeelementnew
              Optimizes 2D element node locations to improve the element and adjacent elements' quality index according to pre-set quality criteria.
            • *elementqualityoptimizenodenew
              Optimizes a node location to improve the attached elements' quality index according to pre-set quality criteria.
            • *elementqualityplacenodenew
              Moves the specified node to a target point.
            • *elementqualityredoaction
              Within the interactive element cleanup tool, repeats the effects of the last specified command that was reversed by a call to *elementqualityundoaction().
            • *elementqualitysetup
              Prepares a mark of elements for use within the interactive element cleanup tool.
            • *elementqualitysetup_new
            • *elementqualityshutdown
              Closes down a session of the interactive element cleanup tool.
            • *elementqualitysmoothnodesnew
              Smooths/optimizes nodes of selected elements.
            • *elementqualitysplitedge
              Splits an edge between two elements.
            • *elementqualitysplitelem
              Splits a quad element into two trias.
            • *elementqualityswapedgenew
              Switches the connectivity of the two elements that share the specified edge to the next legal configuration.
            • *elementqualityundoaction
              Reverses the effects of the last specified command within the interactive element cleanup tool.
            • *elementsaddelemsfixed
              Marks the specified 1D plot elements as feature edges before using the command for remeshing by elements.
            • *elementsaddnodesfixed
              Marks the specified nodes of the old elements as fixed nodes (nodes that must be retained in the mesh to be created) before using the commands for remeshing/meshing by elements.
            • *elementsettypes
              Sets the element types to the current global value.
            • *elementtestaltitudeaspect
              Tests tetra elements for whether or not they pass the tetra AR element quality check, and puts those that fail on the specified output mark.
            • *elementtestaspect
              Tests 2D and 3D elements using the aspect element quality check.
            • *elementtestcellsquish
              Tests 2D and 3D elements using the cell squish element quality check.
            • *elementtestchordaldeviation
              Fits an inferred surface through the selected plate or shell elements and measures their chordal deviation from the inferred surface or from the geometric surface to which they belong, and puts those that exceed the given threshold on the specified outputmark.
            • *elementtestconnectivity
              Tests elements for whether or not they are connected in any one of a number of common but invalid ways and puts those that are on the specified outputmark.
            • *elementtestdependancy
              Tests 1D weld and rigid elements for double dependencies and puts those that fail on the specified outputmark.
            • *elementtestduplicates
              Tests elements for whether or not any two share the same nodes in the same order and puts all except one of any set of duplicates on the specified outputmark.
            • *elementtestequiaskew
              Tests 2D and 3D elements using the equiangle skew element quality check.
            • *elementtestfree1d
              Tests 1D elements for free nodes.
            • *elementtestinterangle
              Tests 2 and 3 dimensional elements for whether or not they pass the interior angle element quality check, and puts those that fail on the specified outputmark.
            • *elementtestjacobian
              Tests 2D and 3D elements for whether or not they pass the Jacobian ratio element quality check, and puts those that fail on the specified outputmark.
            • *elementtestlength
              Tests elements for whether or not they pass the edge length element quality check, and puts those that fail on the specified outputmark.
            • *elementtestorthogonality
              Tests 3D elements for whether or not they pass the orthogonality element quality check, and puts those that fail on the specified outputmark.
            • *elementtestrigidloops
              Tests 1D rigid elements for possible rigid loops, and puts those with rigid loops on the specified outputmark.
            • *elementtestsizeratio
              Tests 3D elements for whether or not they pass the neighbor size ratio element quality check, and puts those that fail on the specified outputmark.
            • *elementtestskew
              Tests 2D and 3D elements for whether or not they pass the skew element quality check, and puts those that fail on the specified outputmark.
            • *elementtesttetracollapse
              Tests tetra elements for whether or not they pass the tetra collapse element quality check, and puts those that fail on the specified outputmark.
            • *elementtesttimestep
              Tests beam, spring, shell, solid and thick shell elements using the time step element quality check.
            • *elementtestvolumeareaskew
              Tests 2D and 3D elements using the volumetric and areal element quality check.
            • *elementtestvolumetricskew
              Tests tetra elements using the volumetric skew element quality check.
            • *elementtestwarpage
              Tests 2D and 3D elements for whether or not they pass the warpage element quality check, and puts those that fail on the specified outputmark.
            • *elementtype
              Sets the global element type variable.
            • *elemoffset
              Offsets shell elements normally to create solid elements.
            • *elemoffset_thinsolid
              Creates layered solid or shell elements in one or more thin solids.
            • *elempatchdecraction
              Decreases the QI patch checker patch size by one element layer.
            • *elempatchincraction
              Increases the QI patch checker patch size by one element layer.
            • *elempatchnextaction
              Moves to the next failed element patch in the QI patch checker patch.
            • *elempatchprevaction
              Moves to the previous failed element patch in the QI patch checker patch.
            • *elempatchstartaction
              Starts the QI patch checker.
            • *elempatchstopaction
              Stops the QI patch checker.
            • *elemswarpagefix
              Attempts to fix quad elements violating warpage criteria threshold.
            • *enabledirtinessdetectionforentitytype
              Enables/disables automatic dirtiness detection for an entity type.
            • *encryptentity
              Encrypts an entity.
            • *end_batch_import
              Finalizes a sequence of multi-file batch import/merge operations.
            • *endnotehistorystate
              Defines the end of a history state.
            • *entitybundleaddid
              Adds a single entity to a data item of a bundle.
            • *entitybundleaddmark
              Adds the entities on a mark to a data item of an entity bundle.
            • *entitybundleclear
              Removes all entities either from a single data item of an or from all the data items of an entitybundle.
            • *entitybundleregister
              Defines a name and signature for a new entity bundle.
            • *entitybundleremoveid
              Removes a single entity from a data item of a bundle.
            • *entitybundleremovemark
              Removes the entities on a mark from a data item of an entity bundle.
            • *EntityDeleteEmpty
              Delete the entities put in the outputmark by *EntityPreviewEmpty().
            • *EntityDeleteUnused
              Deletes the entities in the outputmark by *EntityPreviewUnused().
            • *entitydisplaywithattached
              Isolates an entity and its attached entities.
            • *EntityMoveUsingArray
              Organize a different group of elements to their respective collectors.
            • *EntityPreviewEmpty
              Searches the entities specified and stores any empty entities in the outputmark.
            • *EntityPreviewUnused
              Searches the specified entities for any unused entities, and stores them in the outputmark.
            • *entitysetdirty
              Updates dirtiness status of an entity.
            • *equationcreate
              Creates an equation between a dependent node and multiple independent nodes.
            • *equationcreatebylist
              Creates an equation between a dependent node and multiple independent nodes using a list.
            • *equationupdatemeshconnectivity
              Updates MPC equation connectivity.
            • *equivalence
              Equivalences or finds duplicate nodes of selected components, elements or nodes within a tolerance.
            • *equivalence2
              Equivalences duplicate nodes on the "exposed" faces of 2D/3D elements in selected components to all other nodes in the model within a tolerance.
            • *evaltclscript
              Run a Tcl/Tk based script file.
            • *evaltclstring
              Evaluate a Tcl/Tk based expression.
            • *exclusiveidrange
              Sets an exclusive ID range.
            • *ExportAssemblyAndGlobalEntities
              Exports part assembly and child data.
            • *exportbif
              Exports the current database to Medina .bif format.
            • *exportbom
              Exports a UDMXML BOM file for a given part.
            • *exportshapes
              Exports shape design variables and shapes in several formats.
            • *exportuserdefinedshapes
              Exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
            • *extend_elements
              Extends, connects and optionally remeshes source 2D elements to target 2D elements.
            • *external_skin_extraction
              Detects leaks and extracts exposed exterior or interior faces and surfaces.
            • *facedeleteduplicates
              Deletes duplicate faces.
            • *facepreviewduplicates
              Finds duplicate faces.
            • *facesdelete
              Deletes the component ^faces.
            • *facesmarktosurface
              Assigns a group of faces to a different surface.
            • *fastenercreation
              Creates fastener connectors, elements, properties, and materials using the Huth formula.
            • *fatiguewrite
              Creates a fatigue analysis input file in the format specified.
            • *fbddisplacement
              Creates an FBD displacement plot, and fields or loads from the results.
            • *fbdforce
              Creates an FBD force plot, and fields or loads from the results.
            • *fbdtraceplot
              Creates an FBD trace plot.
            • *feabsorbtomassentity
              Finds and absorbs relevant FE entities into mass entities.
            • *feature_replace
              Geometrically replaces a selection of surfaces with a second selection of surfaces, reconnecting the new surfaces to the rest of the original surfaces according to the original connections.
            • *features
              Generates plot elements between two-dimensional elements whose normals exceed the user-specified angle.
            • *features_add
              Creates elements or lines between a list of nodes.
            • *features_advanced
            • *features_move_all_opened
              Moves all open ^feature elements into a component called ^open features.
            • *features_remove_selected
              Deletes specified elements from ^feature and ^open features.
            • *feinputinteractive
              Inputs an ASCII analysis input deck, and for certain import translators, invokes a Part Browser to allow selecting various options while importing the chosen model.
            • *feinputmerge
              Inputs data from FE files, additionally applying redundant entity management.
            • *feinputoffsetid
              Sets the value to offset the IDs of the entity type during feinput.
            • *feinputomitincludefiles
              Informs HyperMesh that the next call to *feinputwithdata2 should have the input translator skip over reading include files entirely, and only import the base file.
            • *feinputpreserveincludefiles
              Informs HyperMesh that the next call to *feinputwithdata2 should have the input translator recognize and preserve include file information, so that the model might be written out with the entities segregated into their respective files.
            • *feinputwithdata2
              Reads data from sources such as CAD files, connector files/MCF/MWF, and FE files, with additional input parameters.
            • *feoutput_select
              Creates an ASCII export file of selected entities based on an output template.
            • *feoutput_singleinclude
              Creates an ASCII export file based on an output template, for a single include file.
            • *feoutputincludes
              Exports selected includes which were modified since the last export.
            • *feoutputmergeincludefiles
              Informs HyperMesh how to handle include files for the next call to *feoutputwithdata.
            • *feoutputwithdata
              Creates an ASCII export file based on an output template.
            • *feoutputwithdata_PI
              Creates an ASCII export file based on an output template for part and instance models.
            • *fetosurfs
              Generates surfaces from shell elements.
            • *filewritecomponentgeometry
              This command allows you to export HyperMesh files on a per-component basis, so that you can export HyperMesh geometry that is part of a larger assembly without exporting the entire assembly.
            • *filewriteentities
              Saves a BINARY file with only the contents of selected modules/parts.
            • *fill_circular_holes
              Fill flat circular holes on 2D elements.
            • *fill_fe_gaps_elems
              Fills gaps in FE from elements selected on both sides of the gap.
            • *fill_fe_gaps_lines
              Fills gaps in FE from lines selected on both sides of the gap.
            • *fill_fe_gaps_nodeid
              Fills gaps in FE from a node selected on both sides of the gap.
            • *fill_fe_gaps_nodelist
              Fills gaps in FE from node lists selected on both sides of the gap.
            • *fill_fe_holes
              Fills FE holes by automatic or manual detection.
            • *fill_fe_holes_lines
              Fills FE holes from a line selection defining the holes.
            • *fill_fe_holes_nodelist
              Fills FE holes from a node list defining the hole.
            • *fillet_surface_edges
              Create a fillet surface of a constant radius between two surfaces at the selected edges.
            • *fillplot
              Generates a fill plot.
            • *filtertable
              Filter unique cells of key strings of selected column(s) and generate a new table considering the indices of key strings in key columns.
            • *find_holes_in_3d_body
            • *findandremovethreads
              Finds cylindrical threads in 3D geometry and replaces them with smooth surfaces.
            • *findattachedelementfaces
              Returns information to a table about solid elements attached to quad/tria element.
            • *findbetween
              Finds entities that are between/connect other entities.
            • *findedges
              Finds element free or T-connected edges.
            • *findedges1
            • *findfaces
              Finds the free faces in a group of elements.
            • *findloops
              Finds the closed loops in a group of elements.
            • *findmark
              Finds and displays entities or finds and displays adjacent entities.
            • *fix_2d_mesh
              Performs local mesh operations to resolve intersections and slivers on a surface mesh.
            • *fix_surfaces_orientation
              Flips surface normals from a selected surface (or set of surfaces) and any surfaces attached to the selection to all point in the same direction.
            • *fixnarrowsurfaces
              Fixes narrow surfaces and surfaces having local narrow regions like tails and necks.
            • *flanges_detect
              Finds and selects flanges from specified geometry.
            • *flattenpartmodel
              Converts entities that refer to parts to refer to root.
            • *freesimulation
              Ends the post-processing display, and frees memory used by a contour or assigned plot, a deformed plot, a vector plot, or an animation.
            • *freeshapedesvarcreatewithmethod
              Creates a free shape design variable.
            • *freeshapedesvarupdatewithmethod
              Updates a free shape design variable.
            • *fuse_shell_mesh
              Attempts to mesh two disconnected element/component sets within a certain proximity with each other.
            • *gapelement
              Creates a gap element.
            • *gapelementupdate
              Updates the property pointer of gap elements.
            • *geomexport
              Exports geometry to various CAD formats.
            • *geomimport
              Imports geometry from various CAD formats.
            • *geommatchtopology
              Fixes gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
            • *geomupdate
              Update CAD files with modified data.
            • *geomvectorcreate
              From input nodes and geometries, create vectors tangent to lines or normal to surfaces.
            • *geomvectorupdate
              Updates vector entities using input geometries to set vector directions tangent to lines or normal to surfaces.
            • *GetLatitudeLineHandles
              Finds the latitude lines handles of the selected latitude lines and shows these handles in HyperMesh.
            • *getnodesinsidedomaintomark
              Places the displayed nodes inside an element to the specified mark.
            • *getqualitysummary
              Computes the quality index for the specified selection of shell elements and writes the quality summary to the specified text file.
            • *getunmeshedsurfstomark
              Places displayed, unmeshed surfaces on the specified mark using basic logic.
            • *getunmeshedsurfstomark2
              Places displayed, unmeshed surfaces on the specified mark using advanced logic.
            • *graphimport_file
              Imports a mesh stored in HDF5 into the graphics.
            • *graphicfont
              Sets the size of the graphics font.
            • *graphicsfilecolor
              Sets the graphics file image color mode.
            • *graphuserwindow_byXYZandR
              Re-centers the graphics display to center on a specified point, and resizes (zooms) the display based on a specified view radius.
            • *graphuserwindow_to_XYZ
              Re-centers the display on a specified point, using a specified number of animation steps to do so.
            • *group_matches
              Groups parts into partsets based on matching shapes.
            • *groupchangetype
              Changes the config and type of an existing group.
            • *groupcreatesameas
              Creates a new group using an existing group’s dictionary/attribute data and type information.
            • *groupdeleteunused
              Deletes unused groups.
            • *grouppreviewunused
              Identifies the unused elements within a group.
            • *groupsetconfigtype
              Sets the configuration and type for a group entity.
            • *hf_Addendum_PrepareLatitudeLine
              Finds the latitude lines to drag and organize them into the component ^latitude_lines_drag.
            • *hf_Addendum_UpdateSlide
              Update the handle position.
            • *hf_AddSectionHandle
              Add a handle on a section. The section is automatically identified.
            • *hf_CheckDieModuleElementsRES
              Creates and visualizes the contour of draw depth, trim angle and undercut.
            • *hf_ClearFromWorkingSection
              Clears the model from the working section and handles, used to edit the binder.
            • *hf_ClearLLHandles
              Delete all the handles from the model.
            • *hf_Create_DieCadSys
              Creates a system from the CAD system stored in the database.
            • *hf_CreateBinderSectionAndHandles
              Create a section on a binder surface and create five handles on it. The binder section can be identifying by a cutting plane, by two nodes or selecting an existing line. The binder is automatically identified.
            • *hf_createdoubleattachedparams
              Creates the base point for the symmetry plane, the n1/n2 node of the given line and the part of this line between n1/n2 needed for the double attached feature.
            • *hf_CreatePol
              Creates POL from the current trim line, with the specified offset.
            • *hf_DeleteSectionHandle
              Delete a handle of a section.
            • *hf_DiePartPositioning
              Repositions the model to avoid an undercut for the die module.
            • *hf_EditPol
              Opens the Section Editor and loads the POL profile into the 2D editor.
            • *hf_FeatureFromSurfaces
              Creates the feature line from surfaces.
            • *hf_FillDoubleAttachedPart
              Reflects the current die part, duplicating elements and surfaces, and fills the gap in between, creating the surface and the mesh in the die part component.
            • *hf_LevelElementsOnOff
              Controls the display/masking state of eroded elements.
            • *hf_RejectDragDeleteHandle
              Rejects the edit binder drag operation.
            • *hf_ResetDFRibs
              Reset the ribs attribute.
            • *hf_RotateBinderSurf
              Rotate the binder around an axis in space. The binder is automatically identified.
            • *hf_ScaleBinderSurf
              Scale the binder dimension. The binder is automatically identified.
            • *hf_setdieline
              Sets the selected lines as TL or POL.
            • *hf_setdiestampingdirection
              Sets the stamping direction for the die module.
            • *hf_setdiesymmetry
              Sets the symmetry plane for the die module.
            • *hf_setformingdirection
              Sets the draw direction for 1-step solver.
            • *hf_setpartcomponent
              Sets the specified component like the die module main part.
            • *hf_setpartflangecomponent
              Moves the specified entities to the specified component and sets them as flange or part.
            • *hf_setTLPOL
              Moves the specified line to the specified component and sets it as TL or POL.
            • *hf_SlideHandleptrOnSectionPlane
              Updates the handle position. The binder and the section are automatically identified.
            • *hf_TranslateBinderSurf
              Translate the binder along an axis in space. The binder is automatically identified.
            • *hf_trim_multi
              Trims the selected elements with the selected lines, optionally maintaining selected nodes.
            • *hf_TrimBinderOrAddendumWithAddDbeadDbar
              Trims the current die module binder or addendum with the current addendum drawbar/bead FL.
            • *hf_TrimElementsOnOff
              Controls the display/masking state of trim elements.
            • *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
              Trims surfaces with lines and deletes the part of the surfaces enclosed by the lines.
            • *hiddenlinemethod
              Selects the algorithm used to perform hidden line removal.
            • *hideall
              Turns off the display of all entities.
            • *hideentity
              Turns off the display of an entity.
            • *hideentitybymark
              Turns off the display of a mark of entities.
            • *hideview
              Hides the entities with respect to a view saved using *saveviewmask.
            • *hm_auto_elem_cleanup_new
              Attempts to automatically improve the quality of failed elements using node movements and/or local remeshing, along with optional tria reduction.
            • *hm_batchmesh2
              Performs interactive BatchMeshing.
            • *hm_failed_elements_cleanup
              Cleans up the mesh by eliminating reversed and small sized elements. May create new elements instead of reversed.
            • *hm_meshutils_cutelements_2points
              Cut elements with a box defined by 2 diagonal points.
            • *hm_meshutils_cutelements_8points
              Cut elements with a general box defined by 8 points.
            • *hm_meshutils_cutelements_predefined
              Cuts elements with a predefined box.
            • *hm_meshutils_cutjoints
              Cuts elements of a joint section orthogonal to the cross-sections for joint stiffness studies.
            • *hm_trim_elements_with_box
              Trims shell elements using solids.
            • *hm_trim_elements_with_predefined_box
              Trims shell elements using a predefined box.
            • *hm_trim_elements_with_two_point_box
              Trims shell elements using a box defined by two diagonal points.
            • *hmmeshdrag
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *drag...toformsurface commands.
            • *hmmeshlinedrag
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *linedrag...toformsurface commands.
            • *hmmeshskin
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm that approximates a skin surface. Can only be used together with *surfacemode 3 and *skinsurface.
            • *hmmeshspin
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *spin...toformsurface commands.
            • *hmmeshspline
              Within the automeshing module, generates quad or tria elements using a flexible surfaceless algorithm. Can only be used together with *surfacemode 3 and *splinesurface.
            • *hmmeshsurfacecone
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacecone... commands.
            • *hmmeshsurfaceplane
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and *surfaceplane.
            • *hmmeshsurfacesphere
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacesphere... commands.
            • *hmmeshsurfacetorus
              Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacetorus... commands.
            • *hmplygeomsmoothing
              Create smoothed geometry contour lines and surfaces for ply entities, with various options.
            • *hmplysmoothing
              Smooth ply entities to get better shapes.
            • *hmshrinkwrap
              Used to shrink wrap mesh selected elements.
            • *hwCfdCreateMeshControlsFromSolverOptions
              Creates mesh control entities from the equivalent solver options entities in the CFD profile.a
            • *hwCfdSceneReverseAll
              Reverses the display of all the entities of a given entity type.
            • *hwCfdSceneShowAll
              Turns on the display of all the entities.
            • *hwCfdSceneShowHideIsolateEntity
              Manages the display of a mark of entities.
            • *hwct_addrepsfromlibrary
              Adds representations from a connected library.
            • *hwct_addselectedrepsfromlibrary
              Adds specific representations from a connected library.
            • *hwct_closelibrary
              Closes a currently open library.
            • *hwct_deleterepsfromlibrary
              Deletes representations from a connected library.
            • *hwct_openlibrary
              Opens a library
            • *hwct_savetolibrary
              Saves representations to a connected library.
            • *hwct_synclibrary
              Synchronizes library information from a connected library.
            • *icelementcreate
              Creates an IC element.
            • *idmgrshowhide
              Show/hide submodel or exclusive entities.
            • *importbom
              Imports a UDMXML BOM file into a given part.
            • *imprint_elements
              Imprints, connects and optionally remeshes source 1D/2D elements onto target 2D elements.
            • *imprint_geom
              Imprints, connects source points, nodes, lines and surfaces onto target FE surfaces.
            • *imprint_nodelist
              Imprints, connects and optionally remeshes source segments defined by a node list onto target 2D elements.
            • *include
              Includes a file.
            • *includesuppressactive
              Sets the active/inactive state of all supported entities contained within the specified include file.
            • *includesuppressoutput
              Sets the export/do not export state of all supported entities contained within the specified include file.
            • *inputsimulation
              Sets the current simulation and data type for contour and assigned plots, vector plots, and animations.
            • *interactivemeshelems
              Brings all marked elements into the automeshing module and prepares them for processing, enabling the use of all restricted module commands.
            • *interactivemeshsurf
              Brings a surface into the automeshing module and prepares it for processing, enabling the use of all the restricted module commands.
            • *interactiveremeshelems
              Brings all the marked elements into the automeshing module and prepares it for processing, enabling the use of all the restricted module commands. All elements previously attached to this mark are deleted.
            • *interactiveremeshsurf
              Brings a surface into the automeshing module and prepares it for processing, enabling the use of all the restricted module commands. All elements previously attached to the surface are deleted.
            • *interfaceadd
              Creates interface elements.
            • *interfaceaddsolidface
              Creates interface elements on shell elements and faces of solid elements.
            • *intersectmark
              Creates nodes/lines by intersecting 1D/2D elements with a plane.
            • *intersectmark2
            • *isolateelementswithinradius
              Isolates entities within the radius specified.
            • *isolateentitybymark
              Turns on the display of a mark of entities and turns off the display of all others of the same type.
            • *isolateonlyentity
              Turns on the display of an entity and turns off the display of all others across types.
            • *isolateonlyentitybymark
              Turns on the display of a mark of entities and turns off the display of all others across types.
            • *jointelement_fournoded
              Creates a four-noded joint element.
            • *jointelement_sixnoded
              Creates a six-noded joint element.
            • *jointelement_twonoded
              Creates a spherical or two-noded joint element.
            • *jpegfile
              Captures the graphics area to a JPEG image in the current working directory.
            • *jpegfilenamed
              Captures the graphics area to a JPEG image with the specified name.
            • *laminaterealizewithoptions
              Realizing laminate to create solver entities for updating layer information.
            • *lastsimulation
              Sets the last simulation and data type for transient animations.
            • *legendcoloredit
              Edits a color in the legend.
            • *legendcolorsmooth
              Performs linear interpolation between two colors.
            • *legenddisplay
              Controls the display of the legend.
            • *legendlocate
              Moves the legend to its default location (upper left corner).
            • *legendmove
              Moves the legend.
            • *legendon
            • *legendsavecolors
              Saves the colors of a legend to a file.
            • *legendsetbordercolor
              Specifies the legend border and text color from both the hm.cfg file and a command file.
            • *legendsetcolor
              Sets the color used to display the legend.
            • *legendsetcolors
              Sets the number of colors which will be used in the legend.
            • *legendsetfont
              Sets the font used to display the legend.
            • *legendsetlocate
              Locates the legend to the default position (upper left).
            • *lightswitch
              Turns the lights on or off.
            • *linear1delements
              Creates 1D elements between two sets of plate elements.
            • *line_mesh_decimator
              Decimate 1D elements to user given element size.
            • *line_trim_ends
              Trims free lines at the specified locations.
            • *linearmesh
              Within the automeshing module, generates quad or tria elements using a flexible surfaceless algorithm that approximates a ruled surface. Can only be used together with *surfacemode(3) and one of the *linearsurface...() commands.
            • *linearsolids
              Creates solid elements between two groups of plate elements.
            • *linearsolidsbynodelist
              Creates solid elements between two groups of plane elements, with the layers identified by nodes in a node list.
            • *linearsurfacebetweenlines
              Creates a ruled surface between two trimmed line lists, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a ruled surface for the automesher to use under the mesh without surface option.
            • *linearsurfacebetweennodes
              Creates a ruled surface between two node lists.
            • *linearsurfacebetweennodesandline
              Creates a ruled surface between a node list and a trimmed line list, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a ruled surface for the automesher to use under the mesh without surface option.
            • *linecombine
              Combines two free lines into one.
            • *linecombinemark
              Combines multiple free lines into one or more continuous segments.
            • *linecombinemarkall
              Combine a selection of lines into a single line.
            • *linecreateatplanesintersection
              Create a line at the intersection of two planes.
            • *linecreateatsurfacefeatures
              Splits selected surfaces at locations of internal features.
            • *linecreateatsurfparams
              Create lines at parametric locations on a surface.
            • *linecreateconic
              Create a conic section curve segment.
            • *linecreatedragnodealongvector
              Create lines by dragging nodes or points along a direction.
            • *linecreatefromcoords
              Create a line passing through a list of 3D points.
            • *linecreatefromnodes
              Create a line which passed through a list of nodes.
            • *linecreatefromnodesandprojecttobinder
              Create a specific type of line from a list of nodes and project it along a direction onto a surface.
            • *linecreatefromnodesonsurface
              Create a line on a surface from nodes or points on the surface.
            • *linecreatenormal2d
              Create a line in a plane normal to geometry.
            • *linecreatenormalfromgeom
              Create straight segment lines from a node or point normal to the respective geometry.
            • *linecreatenormaltogeom
              Create a straight segment from a point normal to a geometry.
            • *linecreatenurbs
              Create a NURBS line using input parameters.
            • *linecreateoffsetalongcurvature
              Creates a line by offsetting the input lines along their curvature direction.
            • *linecreatespline
              Create a cubic spline curve by interpolating input points.
            • *linecreatestraight
              Create a straight segment curve from coordinates.
            • *linedragelements
              Creates a mesh by dragging elements along a line.
            • *linedraglinetoformsurface
              Drags a trimmed line along a trimmed line to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a line-dragged surface for the automesher to use under the mesh without surface option.
            • *linedragnodestoformsurface
              Drags a list of nodes along a trimmed line to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a line-dragged surface for the automesher to use under the mesh without surface option.
            • *lineeditlength
              Modifies the length of a free line.
            • *lineextenddistance
              Extends the specified line.
            • *lineextendtoline
              Extends line1 to line2.
            • *lineextendtonode
              Extends the specified line to a node.
            • *lineextendtopoint
              Extends the specified line to a point.
            • *lineextendtosurf
              Extends the specified line to a surface.
            • *linefromsurfedgecomp
              Creates lines by copying one or more surface edges.
            • *lineimprintpoints
              Imprints locations/points, given by coordinates, onto free lines or edges within a given max distance.
            • *linelistbypath
              Creates a line path from the starting line to the ending line.
            • *linemarkbypath
            • *linemarkremovepinholes
              Removes 2D holes in the geometry, that has single boundary line, by filling it with surface. Optionally, one can create a vertex point at the center of the hole.
            • *linemesh_preparedata1
              Prepares the selected entities for 1D meshing.
            • *linemesh_preparenodeslist1
              Prepares the selected node list for 1D meshing.
            • *linemesh_savedata_bar1
              Creates 1D elements, with options for bar2 elements, and cleans up memory.
            • *linemesh_savedata1
              Creates 1D elements and cleans up memory.
            • *linemesh_saveparameters
              Assigns meshing parameters to line or node list segments for 1D meshing.
            • *lineplot
              Generates a line plot.
            • *linereverse
              Reverse line direction.
            • *lines_approximate
              Simplifies curved free lines.
            • *linescombine
              Combines two free surface edges to create one unsuppressed common edge.
            • *linescreatemidline
              Creates a line that approximates the middle path between two roughly parallel, roughly planar, lines.
            • *linesplitatjoint
              Splits a line at a joint.
            • *linesplitatline
              Splits a group of lines at a line.
            • *linesplitatmultiplelines
              Splits a group of selected free lines by a group of selected cut lines or edges.
            • *linesplitatplane
              Splits a group of lines at a plane.
            • *linesplitatpoint
              Splits a line at an arbitrary point.
            • *linessmoothtoangle
              Smooths a line based on a give angle.
            • *linessmoothtotol
              Smooths a line based on a give tolerance.
            • *linestoelementsaddelemsfixed
              Marks the specified lines as feature edges before using the command for remeshing elements.
            • *loadcreate
              Creates a load (force, moment, pressure or constraint) at a node or element.
            • *loadcreateonentity
              Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces.
            • *loadcreateonentity_curve
              Creates load with magnitudes defined by a curve.
            • *loadcreatewithsystem
              Creates a load (force, moment, pressure, or constraint) at a node or element defined in a local coordinate system.
            • *loadcreatewithsystemonentity
              Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces, defined in a local coordinate system.
            • *loadcreatewithsystemonentity_curve
              Creates loads, defined in a local coordinate system, with magnitudes defined by a curve.
            • *loadcreatewithsystemonentitywithvars
              Create loads on nodes using Tcl variables for the load components, using a local system.
            • *loaddefaultattributevaluesfromxml
              Loads the entity's default setting values in the specified XML file.
            • *loadsettypes
              Sets the global load type variable.
            • *loadsupdate
              Updates the magnitude, direction, and coordinate system of selected loads.
            • *loadsupdatecurve
              Updates the magnitude, direction, coordinate system, and other information of selected loads.
            • *loadsupdatefixedvalue
              Updates the fixed constraint value on SPC and SPCD constraint loads for OptiStruct.
            • *loadtype
              Sets the load types to the current global value.
            • *lockallentities
              Lock all entities with the same entity type and ID pool across includes.
            • *lockentities
              Adds entity locks.
            • *lockview
              Saves the current view orientation and visible entities with the name "Lock".
            • *makepreservednodes
              Makes the selected nodes preserved.
            • *makesecondarymodeleditable
              Sets the editable state of secondary models.
            • *maketempfrompreservednodes
              Converts nodes from preserved nodes to temp nodes.
            • *manualsplit_applypatterns
              Splits shell elements with specific patterns, and automatically splits attached 1Ds.
            • *map_symmetric_mesh
              Maps a mesh between symmetric source/target surfaces.
            • *mapgroupelementsfromshellstosolids
              Maps base elements of group main/secondary elements from shells to associated solids.
            • *maploadtomesh
              Creates loads on an FE mesh that correspond to a load on the underlying geometry.
            • *mark_preserved_edges
              Use this command to highlight edge lines that have been flagged for preservation by means of *set_preserved_edges() .
            • *markcombineelements
              Combines selected plate and shell elements into one quad or tria element.
            • *markdifference
              Determines the difference between two marks and stores the results in the first mark.
            • *markercreate
              Creates an MBD marker.
            • *markersupdate
              Updates multiple MBD markers.
            • *markintersection
              Determines the intersection between two marks and stores the results in the first mark.
            • *markintersectplane
              Selects a chain of elements and nodes cut by a given section plane.
            • *markmovetoinclude
              Organizes entities into an include file.
            • *markmovetoincludewithcontents
              Organizes entities into an include file, optionally also moving child entities.
            • *markmovetomodule
              Organizes entities into a module.
            • *markmovetoskeleton
              Moves memberjoints, members and memberpanels to skeleton entity.
            • *markmovetosubmodel
              Organizes entities into a solver submodel.
            • *marknodenudge
              Moves nodes along a surface. The nodes must first be associated to a surface.
            • *marknotintersection
              Determines the intersection between two marks and stores everything but the intersection in the first mark.
            • *markprojectnormallytoline
              Projects entities to the line, using the normal to the line as the direction vector.
            • *markprojectnormallytosurface
              Project nodes, elems, points, or lines onto the surface along the surface normal.
            • *markprojecttoline
              Projects entities to the line.
            • *markprojecttomanysurfaces
              Projects entities to multiple surfaces.
            • *markprojecttosurface
              Project entities to a surface.
            • *marksmoothelements
              Applies a smoothing algorithm to a mark of elements for a given number of iterations. Optionally, one or more nodes may be specified as being anchored in place and not movable.
            • *marksmoothsolids
              Applies a simple smoothing algorithm to reposition the interior floating nodes in a mesh of solid elements, attempting to moderate variations in element size and quality.
            • *marktousermark
              Store the entity IDs of the passed entity type on the user mark.
            • *maskall
              Masks all supported entities.
            • *maskall2
            • *maskentitiesincollector
              Masks the specified entities contained within the specified collectors.
            • *maskentitymark
              Masks the entities on the specified mark.
            • *masknotshown
              Masks all supported entities not in the current view window.
            • *masknotshown2
            • *maskreverse
              Reverses the masking state of a specific entity type.
            • *maskreverseall
              Reverses the masking state of supported entities.
            • *maskreverseall2
            • *masselement
              Creates a mass element.
            • *masselementwithvar
              Creates a mass element with a Tcl variable.
            • *mbjointcreate
              Creates a new mbjoint entity.
            • *mbplanecreate
              Creates a new mbplane entity.
            • *mbplanecreatewithcoords
            • *ME_CoreBehaviorAdjust
              Adjusts part and part assembly related behaviors based on certain aspects and policies.
            • *ME_ModuleExport
              Exports the contents of a module to an ASCII export file based on an output template.
            • *ME_ModuleOccurrenceBackPropagate
              Pushes all modifications made to a previous split occurrence back to its original prototype and all occurrences based on it.
            • *ME_ModuleOccurrenceClone
              Create a module as a copy of another. Module contents are copied unless specified otherwise.
            • *ME_ModuleOccurrenceConvert
              Converts a module from part to part assembly and vice-versa.
            • *ME_ModuleOccurrenceCreate
              Creates a module part or part assembly.
            • *ME_ModuleOccurrenceDelete
              Deletes a module part or part assembly, including any recursive contents.
            • *ME_ModuleOccurrenceInstancesDetach
              Breaks a list of module occurrences from their current prototype and re-assigns them to new prototypes.
            • *ME_ModuleOccurrenceMoveContents
              Move the contents from one module part to another.
            • *ME_ModuleOccurrencePurge
              Empty the contents of a module part or part assembly.
            • *ME_ModuleOccurrenceReparent
              Move a module part or part assembly underneath another part assembly in the model hierarchy.
            • *ME_ModuleOccurrenceRepresentationLoad
              Loads a representation of a part or part assembly using options.
            • *ME_ModuleOccurrencesDeleteByMark
              Deletes a mark of modules.
            • *ME_ModuleOccurrencesLink
              Links a set of module occurrences to a main module occurrence.
            • *ME_ModuleOccurrencesPurge
              Empty the contents of multiple module parts or part assemblies.
            • *ME_ModuleOccurrencesReparent
              Move a list of module parts or part assemblies underneath another part assembly in the model hierarchy.
            • *ME_ModuleOccurrencesSyncContents
              Synchronize the contents of one module occurrence to the specified target occurrences that shares a common module prototype.
            • *ME_ModulePopulate
              Moves entities from one module to another.
            • *ME_ModulePosition
              Positions a module using its hierarchical transformation matrices.
            • *ME_ModulesHierarchyLibrarySync
              Finds library related information for a part from a connected part library and updates Part Browser.
            • *ME_TransformationMatrixSet
              Sets the transformation matrix for a module.
            • *mechadjustballjoint
              Actuates a ball joint to reach a new value.
            • *mechadjustjoint
              Actuates a joint to reach a new value.
            • *mechapplybodymovements
              Moves the bodies of a mechanism to the specified matrix orientation.
            • *mechapplybodytotargetpoints
              Moves source points on the bodies of a mechanism to target points.
            • *mechapplyediposition
              Applies a position to a mechanism.
            • *mechcontructfromedi
              Creates objects needed for solving enabled mechanisms.
            • *mechexportdaf
              Exports the dummy angle file for the current dummy.
            • *mechimportdaf
              Imports the dummy angle file for the current dummy.
            • *mechjointlimits
              Sets the type of limits to use on joints for the current dummy.
            • *mechplacebodytopoint
              Moves a body of a mechanism from a source point to a target point.
            • *mechplanetranslatebody
              Moves a body of a mechanism from a source point to a target point using rotation angles.
            • *mechrotatebody
              Rotates a body of a mechanism about a normal, passing through the origin of the plane by given angle.
            • *memberpanelmesh
              Meshes memberpanels to create 2D elements.
            • *menufilterdisable
              Disables filtering.
            • *menufilterenable
              Enables filtering.
            • *menufilterset
              Sets the filter to the filter string.
            • *menufont
              Sets the size of the menu font.
            • *mergefile
              Merges a HyperMesh binary file into the current model.
            • *mergefile2
              Merges a HyperMesh binary file into the current model, additionally applying Redundant Entity Management (REM).
            • *meshdragelements2
              Creates solid elements by dragging 2D elements along a vector.
            • *mesh_fusing
              Connect/merge the proximity regions of 2D elements within a given tolerance.
            • *meshline_create_from_plot_elements
              Creates meshlines from selected plot elements.
            • *meshline_create_from_points
              Creates meshlines from a node list.
            • *meshline_delete
              Deletes meshlines.
            • *meshline_display_scaffold
              Displays the meshline scaffolds for creating surfaces.
            • *meshline_end
              Cleans up meshline internal structures and memory.
            • *meshline_initialize
              Initializes meshline internal structures and memory.
            • *meshline_mark_entity_inside_class
              Marks entities as being inside a meshline class.
            • *meshline_mask_class_element
              Masks underlying meshline class elements.
            • *meshline_reject
              Synchronizes meshline internal structures.
            • *meshline_set_approximate_tol_factor
              Sets the tolerance factor for approximating meshlines with NURBs curves.
            • *meshline_update_surface
              Creates surfaces on closed meshline loops.
            • *meshmode
              Sets the mesh line display mode.
            • *meshspinelements2
              Creates solid elements by spinning 2D elements around a plane normal.
            • *meshtopologyadjust
              Adjusts the mesh on selected surfaces to its boundary by moving nodes to the boundary, splitting elements or suppressing geometry edges or vertices.
            • *messagefilefilter
              Sets a filter on the type of messages written when using the *messagefileset command.
            • *messagefileset
              Writes certain messages to a file.
            • *metadatamarkdate
              Creates date metadata on the specified mark of entities.
            • *metadatamarkdouble
              Creates double metadata on the specified mark of entities.
            • *metadatamarkdoublearray
              Creates double array metadata on the specified mark of entities.
            • *metadatamarkentityidtype
              Creates entity ID type metadata on the specified mark of entities.
            • *metadatamarkentityidtypearray
              Creates entity ID type array metadata on the specified mark of entities.
            • *metadatamarkint
              Creates integer metadata on the specified mark of entities.
            • *metadatamarkintarray
              Creates integer array metadata on the specified mark of entities.
            • *metadatamarkremove
              Removes metadata from the specified mark of entities.
            • *metadatamarkstring
              Creates string metadata on the specified mark of entities.
            • *metadatamarkstringarray
              Creates string array metadata on the specified mark of entities.
            • *midmesh_extract
              Extracts the midmesh of an input geometry.
            • *midmesh_inspect_delete_sets
              Deletes sets created in the midmesh inspect module.
            • *midmesh_inspect_end
              Clears memory and ends the midmesh inspection module.
            • *midmesh_inspect_fix_problems
              Repairs found problems in the midmesh inspect module.
            • *midmesh_inspect_init
              Initializes the midmesh inspection module.
            • *midmesh_repair
              Provides various modes/operators to edit midmeshes.
            • *midsurface_accept_edge_target_by_number
              Assigns targets for the surface edge.
            • *midsurface_accept_point_target
              Assigns a target point to a vertex.
            • *midsurface_clear_plate_info
              Deletes the plate and thickness information from selected surfaces.
            • *midsurface_collapse_lines
              Sets the selection of lines to be collapsed during mid-surface extraction when performing a rerun operation.
            • *midsurface_combine_all_targets
              Combines the targets for all the vertices of the surface to offset
            • *midsurface_display_plate_sides
              Creates two components that contain copies of the model surfaces belonging to two sides of a given plate.
            • *midsurface_display_plates
              Creates components that show the plate information present in the model.
            • *midsurface_edit_base_surfaces
              Adds or removes surfaces to the base surfaces used in midsurfacing.
            • *midsurface_extract_10
              Extracts mid-surfaces from a selection of surfaces or solids.
            • *midsurface_imprint
              Imprints selected lines or edges of selected surfaces onto midsurfaces.
            • *midsurface_merge_into_one_plate
              Merges the given surfaces into a single plate of the specified type.
            • *midsurface_new_plate
              Creates a new plate of the specified type.
            • *midsurface_offset_by_targets_11
              Offsets a surface according to the targets that are attached to its vertices and edges.
            • *midsurface_remove_display_plate_sides
              Deletes the two components that contain copies of the model surfaces belonging to two sides of a given plate.
            • *midsurface_remove_display_plates
              Deletes components that show the plate information present in the model.
            • *midsurface_remove_edge_target_by_number
              Removes a target from a surface edge specified by a line number.
            • *midsurface_remove_edit_bodies
              Deletes components named midsurface to edit, targets, surface to offset, new target, targets being combined, surface thickness, and surface without thickness.
            • *midsurface_remove_new_target
              Deletes components named new target and targets being combined.
            • *midsurface_remove_plate_base_conflicts
              Removes conflicts between base surface information and planar or sweep plate information on all surfaces by changing the type of all relevant planar and sweep plates into offset plates.
            • *midsurface_remove_target
              Finds the surface vertex that is closest to a chosen point and, if it is close enough, removes targets from this vertex.
            • *midsurface_set_not_a_plate_side
              Assigns the given set of surfaces a non-plate type.
            • *midsurface_show_for_edit
              Displays all targets that are attached to the surface vertices and edges.
            • *midsurface_switch_sides_within_plate
              Switches the side of the plate to which the input surfaces belong.
            • *midsurface_unsuppress_conflict_edges
              Unsuppresses edges that separate surfaces with differing plate information.
            • *midsurface_update_from_plate_edit
              Removes relevant pre-existing midsurfaces and plate display components, extracts mid-surfaces corresponding to the existing plate edit information, and re-draws the plate display components.
            • *midsurfaceextract
              Extracts midsurfaces using a surface pair.
            • *midsurfmesh
              Creates a mesh on the mid-surface, with optional cleanup steps and mesh thickness assignment.
            • *migrateloadcolcardstoanalysisparam
              Updates solver cards defined as load collectors to analysisparameters entity and removes the CAALOAD load collector card.
            • *migratetorigidwall
              Converts RWALL from groups to rigidwalls with config 301, and RWALADD from loadcols to rigidwalls with config 302 for OptiStruct.
            • *min_size_node_movement
              Move feature nodes to solve minimum element size failures.
            • *minmaxtitlemove
              Moves a minimum or maximum title.
            • *minmaxtitlesetcolor
              Sets the color of a minimum or maximum title.
            • *minmaxtitlesetfont
              Sets the font of a minimum or maximum title.
            • *mode
              Sets the operations performed when a full-size plot is generated in a command file.
            • *modelcheck_applyautocorrection
              Runs auto correction on the model, if checks are run.
            • *modelcheck_applyautocorrectiononmark
              Runs auto correction on specific entities for a given check, if checks are run.
            • *modelcheck_applycorrection
              Runs auto correction on a given check, if checks are run.
            • *modelcheck_clearresults
              Clears model checker results.
            • *modelcheck_createchecks
              Loads a model check config file and creates check and correction entities.
            • *modelcheck_loadconfigfile
              Loads the default model check config file associated with the current profile and creates check and correction entities.
            • *modelcheck_organizechecks
              Organize the model check check entities under a given parent folder.
            • *modelcheck_runchecks
              Runs model checker checks.
            • *modelcleanup
              Deletes the empty, unused, or undefined entities in the session based on the selected options.
            • *modent_addcontentsbyids
              Adds entities to a modular entity via IDs.
            • *modent_addcontentsbymark
              Adds entities to a modular entity via a mark.
            • *modent_addrepresentations
              Adds representation information to a modular entity.
            • *modent_deletebymark
              Deletes a mark of modular entities.
            • *modent_deleterepresentation
              Deletes the representation information from a mark of modular entities.
            • *modent_export
              Exports a modular entity and its contents using the currently loaded solver template.
            • *modent_realizerepresentation
              Loads the contents of a modular entity representation.
            • *modent_registerconstraintruleoptions
              Registers a list of options that control the behavior of add/move/remove operations for a modular entity.
            • *modent_removecontentsbyids
              Removes entities from a modular entity via IDs.
            • *modent_removecontentsbymark
              Removes entities from a modular entity via a mark.
            • *modent_saverepresentation
              Saves the contents of a modular entity representation.
            • *modent_unrealizerepresentation
              Unloads the contents of a modular entity representation.
            • *modifyicelement
              Modifies a dependent node of an IC element.
            • *ModifySectionHandle
              Modify the section shape updating the handle position. The section is identifying automatically and the handle is identified by the old position.
            • *morphalteranglevec
              Alters the angle for three nodes using morphing and measuring perpendicular to a vector.
            • *morphaltercurvectr
              Alter the radius, curvature, or arc angle of edge or 2D domains on mark.
            • *morphalterdistancevec
              Alter the distance between two nodes using morphing and measuring along a vector.
            • *morphapplyfesolver
              Invokes the finite element solver solution for all perturbed domains with a limited number of elements.
            • *morphapplylargedomains
              Applies current morphing to large domains.
            • *morphbeziershape
              Create polynomial or spline based shapes for handles on the domains on mark.
            • *morphbiasstyle
              Applies updated bias style retroactively to existing perturbations.
            • *morphbiasupdate
              Updates the bias factor for the specified handle.
            • *morphbiasupdatemulti
              Updates the bias factor for the handles on the mark.
            • *morphbiasupdateretroactive
              Applies updated biases retroactively to existing perturbations.
            • *morphcombineedges
              Combines multiple edge domains into one edge domain.
            • *morphcombinemorphvolumes
              Combines the specified morph volumes and propagates the combination.
            • *morphconnstodoms
              Creates general domains for selected connectors.
            • *morphconstraintapply
              Applies all morph constraints to the model.
            • *morphconstraintcreateangle
              Creates a model type constraint based on the angle between three nodes.
            • *morphconstraintcreatearcrad
              Creates a model type constraint based on the radius or arc length of an edge domain.
            • *morphconstraintcreateavm
              Creates a model type constraint based on the area, volume, or mass of the elements on the mark.
            • *morphconstraintcreatedof
              Creates a constraint which fixes the x (or radial), y (or theta), and/or z degrees of freedom for the selected nodes for a given system.
            • *morphconstraintcreateedge
              Creates a tangency constraint between two edge or 2D domains or for a single edge domain.
            • *morphconstraintcreateelems
              Creates a mesh type morphconstraint for the selected nodes with the option of having those nodes either move along the specified mesh or be bounded by it.
            • *morphconstraintcreateeq
              Creates an equation type constraint for the specified nodes.
            • *morphconstraintcreatefc
              Creates either a fixed or cluster type morphconstraint for the selected nodes with the options of having mesh stretching around those nodes and having the nodes rotate.
            • *morphconstraintcreatelayer
              Creates a layer type morphconstraint for the selected nodes such that they move relative to the selected elements.
            • *morphconstraintcreatelength
              Creates a model type constraint based on the length of a list of nodes.
            • *morphconstraintcreateline
              Creates a line type morphconstraint for the selected nodes with the option of having those nodes either move along the line or be bounded by it.
            • *morphconstraintcreatematch
              Creates a match type morphconstraint between two marks of elements so that they maintain a similar shape.
            • *morphconstraintcreateplane
              Creates a plane type morphconstraint for the selected nodes with the option of having those nodes either move along the plane or be bounded by it.
            • *morphconstraintcreatesmooth
              Creates a smooth type morphconstraint for the selected nodes.
            • *morphconstraintcreatesurf
              Creates a surface type morphconstraint for the selected nodes with the option of having those nodes either move along the surface or be bounded by it.
            • *morphconstraintcreatevec
              Creates a vector type morphconstraint for the selected nodes with the option of having those nodes bounded to move no closer than a given distance from the specified plane.
            • *morphconstraintsetcolor
              Sets the color for a morph constraint.
            • *morphconstraintupdateangle
              Updates a model type constraint based on the angle between three nodes.
            • *morphconstraintupdatearcrad
              Updates a model type constraint based on the radius or arc length of an edge domain.
            • *morphconstraintupdateavm
              Updates a model type constraint based on the area, volume, or mass of the elements on the mark.
            • *morphconstraintupdatedof
              Updates a constraint which fixes the x (or radial), y (or theta), and/or z degrees of freedom for the selected nodes for a given system.
            • *morphconstraintupdateedge
              Updates a tangency constraint between two edge or 2D domains or for a single edge domain.
            • *morphconstraintupdateelems
              Updates a mesh type morphconstraint for the selected nodes with the option of having those nodes either move along the specified mesh or be bounded by it.
            • *morphconstraintupdateeq
              Updates an equation type constraint for the specified nodes.
            • *morphconstraintupdatefc
            • *morphconstraintupdatelayer
              Updates a layer type morphconstraint for the selected nodes such that they move relative to the selected elements.
            • *morphconstraintupdatelength
              Updates a model type constraint based on the length of a list of nodes.
            • *morphconstraintupdateline
              Updates a line type morphconstraint for the selected nodes with the option of having those nodes either move along the line or be bounded by it.
            • *morphconstraintupdatematch
              Updates a match type morphconstraint between two marks of elements so that they maintain a similar shape.
            • *morphconstraintupdateplane
            • *morphconstraintupdatesmooth
            • *morphconstraintupdatesurf
            • *morphconstraintupdatevec
            • *morphconvertmv
              Converts the morph volumes on the mark to hexa elements or vice-versa.
            • *morphcreatedomaindc
              Creates a domain from the elements on the mark with various options.
            • *morphcreatedomainedge
              Creates a domain from node list.
            • *morphcreatedomainglobalnodes
              Creates a global domain governing the selected nodes.
            • *morphcreateline
              Creates a line for a given node list.
            • *morphcreatemodelshape
              Creates an arbitrary shape that can be used with a model constraint.
            • *morphcreateresultsfile
              Creates and loads a results file named autodv.animate from the selected shapes.
            • *morphcreatetempline
              Creates a line entity for a given node list.
            • *morphdeleteall
              Deletes all morphing entities.
            • *morphdeletehandlesanddomains
              Deletes all morphing handles and domains.
            • *morphdeletemvedgenodes
              Deletes the selected mid-edge nodes from the edges of morph volume.
            • *morphdisplayconstraints
              Displays the vectors defining the constraints on the mark.
            • *morphdisplayconstraintvector
              Draw vector to the screen.
            • *morphdisplaydependencies
              Displays dependencies for handles on mark.
            • *morphdisplaysymmetries
            • *morphdomainautocolor
              Automatically assign a different color to selected domains.
            • *morphdomainsetcolor
              Sets the color of a single domain.
            • *morphdomainsupdatecolor
              Sets the color of selected domains.
            • *morphdoshape
              Apply undo, redo, undo all, or redo all.
            • *morphentitydelete
              Deletes entities on a mark.
            • *morphfitfaces
              Fits selected faces to nodes or elements according to the specified parameters.
            • *morphfittosurface
              Fits domains, elements, or morph volume faces to surfaces or a mesh, matching boundary edges and projecting the interior nodes on to the target entities.
            • *morphhandlecreatenodes
              Creates handles at nodes on mark on domain.
            • *morphhandlecreatenodesnodom
              Creates handles at nodes on mark with no domain given.
            • *morphhandlecreatexyz
              Creates handle at x,y,z, location for the given system.
            • *morphhandlepertnormal
              Perturbs handles on mark normal to elements.
            • *morphhandlepertxyz
              Perturbs handles by a specified value.
            • *morphhandleprojectentity
              Morphs a mesh by projecting selected handles on to the selected surfaces or elements.
            • *morphhandleprojectline
              Morphs a mesh by projecting selected handles on to the selected line list.
            • *morphhandleprojectplane
              Morphs a mesh by projecting selected handles on to the specified plane.
            • *morphhandlerotate
              Rotates handles on mark.
            • *morphhandlescalexyz
              Morphs a mesh by scaling the distances between handles and a specified node according to the specified system.
            • *morphhandleupdatemulti
              Updates dependencies for handles on mark.
            • *morphhandleupdatesingle
              Updates position and dependencies for specified handle.
            • *morphhypermorph
              Create shapes with xyz perturbations for handles on mark.
            • *morphhypermorphnormal
              Create shapes in the normal direction for handles on mark.
            • *morphhypermorphvector
              Create shapes in the direction of a vector for handles on mark.
            • *morphhyperpreview
              Draws vectors for shapes to be created.
            • *morphhyperpreviewbezier
              Draws vectors for shapes to be created using morphbeziershape if a shape is being used.
            • *morphinterpolatesurf
              Morphs a mesh on to a surface interpolated from the specified mark of nodes or lines.
            • *morphkrigmanual
              Set of commands to allow manual Kriging of the model.
            • *morphlistupdate
              Updates the morphing undo/redo list.
            • *morphloaddata
              Loads handle and/or shape data from a file.
            • *morphloadmvols
              Loads morph volume, handle, and shape data from a file.
            • *morphloadshape
              Reads local shapes stored in the specified file.
            • *morphmanageedgemark
              Adds a morph volume edge, subtracts a morph volume edge, or clears all morph volume edges from a morph volume edge user mark.
            • *morphmanagefacemark
              Adds a morph volume face, subtracts a morph volume face, or clears all morph volume faces from the specified user mark.
            • *morphmanualapplyenvelope
              Turns manually modified node positions into a morph.
            • *morphmanualinit
              Initializes the model to prepare for manual morphing.
            • *morphmanualrestore
              Restores the positions of nodes after a *morphmanualinit command.
            • *morphmapdifference
              Creates two lines and maps selected nodes from one to the other optionally following the curvature differences (rotate) between the lines and/or mapping about an axis (axis and plane) or using a number of linear mapping options.
            • *morphmapdifferencesurf
              Maps selected nodes from one surface or element mark to the other surface or element mark optionally following the curvature differences (rotate) between the surfaces or element marks and/or mapping about an axis (axis and plane) or using a number of linear mapping options.
            • *morphmapedgestoequationoffset
              Maps selected morph volume edges to the surface of an equation.
            • *morphmapedgestoextendedoffset
              Maps selected morph volume edges to extended versions of the specified surfaces or elements.
            • *morphmapedgestolineoffset
              Maps selected morph volume edges to the specified lines.
            • *morphmapedgestonodelistoffset
              Maps selected morph volume edges to the specified node list.
            • *morphmapedgestoplaneoffset
              Maps selected morph volume edges to the specified plane.
            • *morphmapedgestosurfaceoffset
              Maps selected morph volume edges to the specified surfaces.
            • *morphmapedgestotacitoffset
              Maps selected morph volume edges to the specified elements.
            • *morphmaplinestolines
              Maps selected elements lying on an initial set of lines to an interpolated cross section represented by another set of lines optionally rotating trailing nodes and/or mapping about an axis (axis and plane) or using a number of linear mapping options.
            • *morphmapnormaloffset
              Offset elements on mark in normal direction.
            • *morphmaprecalc
              Recalculate influences and prepare for mapping.
            • *morphmapsections
              Map elements on mark to section lines.
            • *morphmaptoequationvecoffset
              Maps nodes to the surface of an equation along a vector.
            • *morphmaptoextendedvecoffset
              Maps nodes to extended versions of the specified surfaces or elements.
            • *morphmaptolinenodesoffset
              Maps a node list to a line list along a vector.
            • *morphmaptolinevecoffset
              Maps nodes to a line list along a vector.
            • *morphmaptonodelistvecoffset
              Maps nodes to a line along a vector.
            • *morphmaptonodesnodelistoffset
              Maps a node list to a line along a vector.
            • *morphmaptoplanevecoffset
              Maps nodes to a plane along a vector.
            • *morphmaptosurfacevecoffset
              Maps nodes to surfaces along a vector.
            • *morphmaptotacitvecoffset
            • *morphmaptshp
              Adds a handle perturbation to the current temporary shape.
            • *morphmaptshpedge
              Adds and edge domain perturbation to the current temporary shape.
            • *morphmaptshpface
              Adds a 2D domain perturbation to the current temporary shape.
            • *morphmvskinsolve
              Solves for the interior nodes of a solid mesh which are registered to morph volumes when morphing in "skin only" mode.
            • *morphnodesequaoffset
              Moves the selected nodes to the surface of the specified function while morphing the affected elements.
            • *morphnodesextendedoffset
              Moves the selected nodes to a mark of extended surfaces or elements while morphing the affected elements.
            • *morphnodeslineoffset
              Moves the selected nodes to a line while morphing the affected elements.
            • *morphnodesmatrixdiffenvelope
              Reorients the selected nodes by taking the difference between two matrices while morphing the affected elements.
            • *morphnodesmeshoffset
              Moves the selected nodes to a mesh while morphing the affected elements.
            • *morphnodesnodesoffset
              Moves the selected nodes to a line created from a node list while morphing the affected elements.
            • *morphnodesnormalenvelope
              Moves the selected nodes normal to the attached elements while morphing the affected elements.
            • *morphnodesplaneoffset
              Moves the selected nodes to a plane while morphing the affected elements.
            • *morphnodesrotateenvelope
              Rotates the selected nodes while morphing the affected elements.
            • *morphnodesshapeenvelope
              Applies the specified shape while morphing the affected elements.
            • *morphnodessurfoffset
              Moves the selected nodes to the specified surfaces while morphing the affected elements.
            • *morphnodestranslateenvelope
              Translates the selected nodes while morphing the affected elements.
            • *morphnodesvectoroffset
              Moves the selected nodes to a line extending along a vector created from two nodes while morphing the affected elements.
            • *morphorganizedomain
              Organizes elements on mark into specified domain.
            • *morphorganizedomainsplit
              Splits edge domain at given node.
            • *morphpartition
            • *morphpositionshapemark
              Positions shapes from one part of the mesh to another, scales them, and applies them only to the nodes on the mark.
            • *morphrecalcmvhandles
              Recalculates the influences for the handles on morph volumes.
            • *morphrecalculateconstraints
              Recalculates out-of-date morph constraints.
            • *morphreflectshapemark
              Reflects shapes in accordance with symmetries and applies them only to the nodes on the mark.
            • *morphregistergeometry
              Controls the registration of geometric entities for morphing.
            • *morphremeshedges
              Remeshes selected elements or domains with the target element size.
            • *morphremoveconstraint
              Remove constraint(s).
            • *morphrenamehandle
              Renames a handle.
            • *morphreparam
              Reparameterizes domains on the mark.
            • *morphrotatetrue
              Rotates handles on mark using 'true' rotation.
            • *morphsavedata
              Saves global handles and shapes to a file.
            • *morphsavemvols
              Saves morph volume, handle, and shape data to a file.
            • *morphsaveshape
            • *morphsculptmesh3
              Sculpts the affected elements according to the selected tools and parameters, optionally using a finite element solver to resolve the mesh stretching.
            • *morphsetactive
              Sets an active parameter for either morph constraints or symmetries.
            • *morphsetsmoothignoredelems
              Assigns elements to be ignored when performing element test criteria for shape combination checking via *morphshapesmooth.
            • *morphsetsmoothtests
              Sets the element test criteria used for shape combination checking via *morphshapesmooth.
            • *morphshapeapply
              Applies the shapes on the mark to the model.
            • *morphshapeapplynodes
              Applies the shapes on the mark to only the selected nodes.
            • *morphshapecreatecolor
              Creates a new shape out of the applied morphs, with a specified color.
            • *morphshapecreatecolorsystem
              Creates a new shape out of the applied morphs specifying the color and coordinate system.
            • *morphshapecreatelist
              Creates a number of new shapes from the morph list.
            • *morphshapecreateorthogonal
              Creates shapes, design variables, dlink2s, and equations to enable non-linear shape variables in linear optimization.
            • *morphshapecreateorthogonalbound
              Creates shapes, design variables with the specified bounds, dlink2s, and equations to enable non-linear shape variables in linear optimization.
            • *morphshapelinkedapply
              Applies all shapes stored on an internal list at their stored multipliers as well as any shapes linked to those shapes via desvar, deqatn and dlink2 cards.
            • *morphshapelinkedpush
              Adds a shape and a multiplier to a list of shapes to be used by *morphshapelinkedapply.
            • *morphshapepreview
              Applies (with a multiplier of one) or unapplies selected shapes.
            • *morphshapesmooth
              Checks the element quality for all combinations of the selected shapes either as they are currently or after smoothing them.
            • *morphshapeupdatecolor
              Updates the color of a shape.
            • *morphshrinkmvols
              Applies shrinking to selected morph volumes.
            • *morphsmooth
              Applies smoothing to selected domains.
            • *morphsmoothmorphbased
              Uses a morphing based smoothing algorithm to smooth a mesh and improve element quality.
            • *morphsplitmorphvolumes
              Splits the morph volumes in the model given the specified morph volume edge.
            • *morphstoredomains
              Stores or restores a copy of current domains, handles, and shapes.
            • *morphstorematch
              Matches domains to surfaces for a subsequent fitting operation.
            • *morphstoremorphvolumes
              Stores or restores a copy of current morph volumes and handles.
            • *morphsubdivide
              Subdivides selected 3D domains.
            • *morphsurfaces
              Calls surface morphing function.
            • *morphsymmetrycreateaxis
              Creates symmetry dependent on system.
            • *morphsymmetryrefresh
              Recalculates symmetric relationships between handles
            • *morphsymmetryupdateaxis
              Update one symmetry.
            • *morphsymmetryupdatebyd
              Update symmetries for a domain.
            • *morphtranslateshapemark
              Translates shapes to specified node positions and applies them only to the nodes on the mark.
            • *morphupdatedatabase
              Updates morph volume database.
            • *morphupdatedisplay
              Updates the display of morphing entities.
            • *morphupdatedomainmethod
              Updates method for selected 1D domains.
            • *morphupdatedomains
              Updates global domains.
            • *morphupdateendbymvol
              Updates the end conditions of edges on selected morph volumes.
            • *morphupdateendcondition
              Updates the end condition of one or two morph volume edges.
            • *morphupdatemodelcheck
              Scans through all morphing entities and updates all of those that require attention, such as domains needing to be recalculated.
            • *morphupdatemvedgenodes
              Updates the mid-nodes of the specified morph volume edge.
            • *morphupdatemvnodes
              Updates nodes on mark to be registered for the morph volumes on mark.
            • *morphupdatemvols
              Updates morph volumes on mark.
            • *morphupdateparameter
              Updates integer/real morphing parameters.
            • *morphupdateparameterstring
              Updates string morphing parameters.
            • *morphupdateshapes
              Updates or converts shapes.
            • *morphvolumeconnect
              Joins the specified morph volumes.
            • *morphvolumecreate
              Creates a matrix of morph volumes.
            • *morphvolumecreateflex
              Creates a series of morph volumes using a selected profile (elements, morph volumes, lines, matrix) along a line, vector, through elements, or about an axis.
            • *morphvolumecreatenodes
              Creates a morph volume for the given nodes enclosing the elements on the mark.
            • *morphvolumecreateplus
              Creates a matrix of morph volumes and optionally applies shrinking.
            • *morphvolumedeleteempty
              Deletes any morph volumes that have no nodes registered to them.
            • *morphvolumeequivalence
              Joins morph volumes on a mark together which are within a specified tolerance.
            • *morphvolumereflect
              Creates morph volumes by reflecting the selected morph volumes using reflective symmetries.
            • *morphwritenodes
              Writes node positions and perturbations to a file.
            • *move_clipping_sphere_to_XYZ_and_fit
              Re-centers the view around a specified point, zooms in or out to fit a specified radius around that point, and does all of this in a specified number of frames of animation rather than instantly.
            • *move_feature
              Moves a selection of elements and pastes them onto the displayed shell elements at the target location.
            • *movecuttingplane
              Moves a cutting plane a specified distance.
            • *moveinclude
              Moves an include file to a new location in the include hierarchy.
            • *moveincludecontents
              Moves the contents of one include to another, with an option to delete the source include.
            • *movemark
              Organizes entities into collectors.
            • *movemarkgroup
              Organizes main/secondary elements into groups.
            • *movesolvermasses
              Moves the child solvermasses from one parent solvermass to another parent solvermass.
            • *movesubmodel
              shortDescription
            • *multi_surfs_lines_merge
              Merge selected set of surfaces into topologically valid body, optionally using input free lines to create additional trim lines on surfaces.
            • *multi_trim_by_offset_edges
              Trims the selected surfaces by offsetting selected edges by a given distance. Offset can be applied multiple times.
            • *nameview
              Gives a name to a view.
            • *newidoption
              Defines how new IDs are assigned for a submodel.
            • *nodeaddtempmark
              Adds nodes to the temporary node mark.
            • *nodecleartempmark
              Clears all of the nodes from the temporary node mark.
            • *nodecloud2facet
              Generate STL facets from a node cloud.
            • *nodecreateatintersection
              Create nodes or points at locations of intersection between the input geometric entities.
            • *nodecreateatlineparams
              Create nodes or points at parametric locations on a line.
            • *nodecreateatplaneintersection
              Create nodes or points at locations of intersection between the input geometric entities and a plane or vector.
            • *nodecreateatsurfparams
              Create nodes or points at parametric locations on a surface.
            • *nodecreateatvectorplaneintersection
              Create node or point at location of intersection between two vectors or a plane and a vector.
            • *nodecreatebetweennodes
              Create nodes or points on line or surface between given list of nodes.
            • *nodecreatelinemarkparams
              Creates nodes or points at parametric locations on lines.
            • *nodecreateonlines
              Create nodes along lines, with optional biasing.
            • *nodelistbypath
              Creates a node path from the starting node to the ending node.
            • *nodelistbypath2
            • *nodemarkaddtempmark
              Places a node on the temporary node mark.
            • *nodemarkbypath
            • *nodemarkcleartempmark
              Clears a group of nodes from the temporary node mark.
            • *nodemodify
              Modifies the location of a node in space.
            • *nodeplaceatxyz
              Moves a node to a location on a surface and associates the node to the surface.
            • *nodesandelemsclear
              Clear numbers from the modeling window for all nodes and elements.
            • *nodesassociatetogeometry
              Associates nodes to points, lines, surfaces or solids.
            • *nodetoelementgapscreate
              Creates node-to-element gap elements (CGAPG) for use with the OS solver
            • *nonstructuralmasscreate
              Creates a group with non-structural mass configuration.
            • *nonstructuralmasscreateall
              Creates a group with non-structural mass configuration for all properties of a specified card image.
            • *nonstructuralmassupdate
              Updates a group with non-structural mass configuration.
            • *nonstructuralmassupdateall
              Updates a group with non-structural mass configuration for all properties of a specified card image.
            • *normalsadjust2
              Adjusts the normals of 2D and 3D elements.
            • *normalsadjustbynodes
              Adjusts the normals of 3D elements according to nodes of a solid element.
            • *normalsdisplay
              Turns on the display of 2D and 3D element normals.
            • *normalsoff
              Turns off the display of element/surface normals.
            • *normalsreverse
              Reverses the normals of 2D and 3D elements.
            • *numbers
              Turns the numbers mark on or off.
            • *numbersclear
              Clears all of the entities out of the numbers mark.
            • *numbersmark
              Places the entities in the mark on the numbers mark. This will display the ID of the entity.
            • *offset_surfaces_and_modify
              Offsets selected surfaces or solids.
            • *offset_surfaces_display_offset
              Creates segments indicating the direction of surface or solid offsets for visualization/review.
            • *optimized_elements_remesh2
              Remeshes elements with the user specified algorithm and optimization of node positions.
            • *optimized_mesh
              Generates a mesh with the selection of the best meshing algorithm and optimization of node positions.
            • *optimsmooth
              Applies the quality index optimization smoothing algorithm to a mark of plate elements.
            • *orderchangetofirst
              Converts second order elements to first order.
            • *orderchangetosecond
              Converts first order elements to second order.
            • *organizecomponents
              Reorganizes elements in existing components based on selected policy.
            • *organizeRegionsAcrossModules
              Organize selected regions to newly created modules per region.
            • *orient_normals_outside_solid
              Re-orients the normals of a solid inside or outside, depending on the orientation flag.
            • *ossmooth_12
              Extract the final design geometry from OptiStruct topology, topography and shape optimization results, and achieve smoothed plies from free-size optimization results on composites.
            • *ossmooth_createsurf_auto
              Creates surfaces from OSSmooth isosurface and autobead results.
            • *ossmooth_geometry
              Extract the final design geometry from OptiStruct topology, topography and shape optimization results.
            • *ossmooth_reanalysis
              Extract the final geometry from OptiStruct topology optimization results and inherit the boundary conditions for reanalysis.
            • *ossmooth_savesurf
              Exports the final design geometry from OptiStruct topology, topography and shape optimization results.
            • *ossmooth2
              This command extracts the final design geometry from OptiStruct topology, topography or shape optimization results.
            • *panelcreation
              Creates a panel entity.
            • *parsesolveroutputfile
              Creates tables from solver output files.
            • *penetrationcheck
              Checks the given components for contact surface penetrations.
            • *penetrationcheckend
              Releases the memory from previous penetration check command operations.
            • *PenetrationCheckSummary
              Generates a summary log file for last run penetration check.
            • *penetrationchecktwo
              Checks penetration for entities selection type groups, elems2elems, nodes2elems, and elemsonly.
            • *penetrationdisplay
              Displays the amount of penetration through nodes, vectors, or contour.
            • *penetrationrecheck
              Modifies the element thickness to correct penetration problems.
            • *permutemark
              Permutes the entities on a mark.
            • *perturbationshapecreate
              Creates a perturbation shape.
            • *perturbationshapeupdate
              Updates a perturbation shape.
            • *plot
              Plots the current model.
            • *plotaxisnodes
              Plots a curve based on the values of marked nodes ordered along an axis.
            • *plotinfotitlemove
              Moves the plot information title.
            • *plotinfotitlesetcolor
              Sets the color of the plot information title.
            • *plotinfotitlesetfont
              Sets the font of the plot information title.
            • *plotinfotitlesettext
              Sets the text to be displayed in the plot information title.
            • *plotmassdistribution
              Plots the distribution of the mass assigned on nodes.
            • *plotnodelist
              Plots a curve based on the values of a contour along a list of nodes.
            • *plottitlemove
              Moves the plot title.
            • *plottitlesetcolor
              Sets the color of the plot title.
            • *plottitlesetfont
              Sets the font for the plot title.
            • *plottitlesettext
              Sets the text for the plot title.
            • *plydrape
              Drapes plies using the Laminate Tool.
            • *plynormalsdisplay
              Controls the display of 2D element ply normals.
            • *plynormalsreverse
              Reverses the 2D element ply normals.
            • *plyrealization_option
              Extracts/projects elements belonging to ply contours.
            • *pointmodify
              Specifies new coordinates for the point.
            • *positiondummy
              Positions the components of a dummy.
            • *positionmark
              Positions a selection of entities in space.
            • *prepare_solid_holes_for_meshing
              Detects holes in a 3D model and prepares them for meshing.
            • *pressureonelement_curve
              Creates a pressure load on an element.
            • *pressures
              Creates pressure loads on elements.
            • *pressuresonentity
              Creates a pressure load on a surface or an element.
            • *pressuresonentity_curve
              Creates a pressure load on a mark of elements, surfaces, components or sets, potentially with its magnitude defined by a curve.
            • *processflange
              Given a set of fixed points, this command splits the edges of surfaces by adding a fixed point on the edge.
            • *projectmarktoplane
              Projects a group of entities to a plane.
            • *projectpointstoedges
              Create surface vertices by projecting the points onto the edges perpendicular to the edge.
            • *projectsystem
              References a vector that is projected on the element plane. Re-orients and visualizes the element (material) coordinate system for selected elements.
            • *propagate_welds
              Use this command to create a series of weld points between surfaces.
            • *propagatesplithexas
              Given a hexa element and two nodes diagonally across a face of that element, splits the hexa according to a set pattern and propagates that split to any hexa adjoining the opposite face of the hexa and so on through the displayed elements of the database.
            • *pushtofront
              Sets a visualization mode to keep certain entities visible in front of others.
            • *qismoothconstrained
              This command tries to improve the selected elements' quality index by QI optimizing elements nodes positions.
            • *qismoothfixfailed
              Selectively applies QI smoothing (the quality index-based node-position optimization) to elements violating the quality index thresholds. Allowed displacements of nodes on the feature edges are limited by user-specified thresholds. The command tries to fix the failed elements while making moving the feature nodes as little as possible.
            • *quad_split
              Split warped quads into trias such that it does not create intersections.
            • *quatrotate
              Defines a rotation θ about the vector [x, y, z].
            • *quit
              Stops the execution of a command file.
            • *rbe3
              Creates an RBE3 element.
            • *rbody_mesh
              Creates a rigid body mesh on surfaces.
            • *readbatchparamsfile
              Use this command to set cleanup parameters directly in the command file when using automatic topology cleanup with the *autotopocleanup command.
            • *readfile
              Reads a HyperMesh database into the current session and deletes any existing model.
            • *readmeshcontroltemplate
              Imports a Mesh Control template file.
            • *readnodepositionsfromdynainfile
              Moves nodes in the current model to positions given in a dynain file.
            • *readnodepositionsfromh3dfile
              Modes nodes in the current model to positions given in an H3D file.
            • *readqiviewsettings
              Loads a file containing the element quality view mode settings.
            • *readqualitycriteria
              Reads quality criteria from the specified criteria file and sets the criteria as current.
            • *realizecontactsurfstosets
              Realizes all contact surfaces of a given card image to segment sets.
            • *realizecsfbdsectiontostdfbdsection
              Realize cross-section based freebodysections to standard freebodysections.
            • *realizeengineeringentities
              Realize engineering entities.
            • *realizeengineeringentity
              Realize an engineering entity.
            • *realizeentity
              Realizes an engineering entity into solver data.
            • *realizefieldloads
              Realizes engineering loads into classical loads.
            • *realizehmentity
              Realizes HyperMesh entities.
            • *realizemasselementstosolvermasses
              Creates nodal group solvermasses out of mass elements.
            • *realizesetstocontactsurfs
              Realizes all segment sets of a given card image to contact surfaces.
            • *realizesolvermassestomasselements
              Creates mass elements from solver mass entities.
            • *rebuild_mesh
              Remeshes selected shell elements with quality and flow considerations.
            • *rebuild_mesh_advanced
              Remesh/Improve selected shell elements with quality and flow considerations, and optional flow guide selections to guide the mesh directions.
            • *reconcilemasslocation
              Reconciles all locations of a mass to actual locations, and synchronizes the ghosts with actual locations.
            • *redohistorystate
              Redoes one or more history states.
            • *refine_adaptive
              Refines elements based on proximity and angle.
            • *refine_by_patterns
              Refines a zone of elements using an all quad pattern.
            • *refine_by_patterns_multiple_points
              Refines multiple zones of elements using an all quad pattern.
            • *refineelementsbydeviation
              Refine elements to chordal deviation.
            • *refineelementsbysize
              Refine elements to target element size.
            • *reflectmark
              Reflects a selection of entities about a plane.
            • *reflectmarkwithoption
              Reflects a selection of entities about a plane with an option to specify how to handle bar elements.
            • *rejectmark
              Rejects the entities held on the reject mark.
            • *rejectmesh
              Discards a generated mesh (if any) for the specified face within the automeshing module.
            • *relativerotatedummyjoint
              Rotates a dummy joint relative to its current location.
            • *remap
              Remaps a list of nodes to a line.
            • *remesh_element_intersection
              Remeshes 2D elements at intersection locations.
            • *remesh_main_secondary_boolean
              Performs intersection and Boolean operations of 2D elements.
            • *remesh_optistruct
              Remeshes the current model with FE type definitions maintained, used to improve the mesh quality in OptiStruct free shape, shape or topography optimization.
            • *remove_fe_cracks
              Stitches free edge loops in FE.
            • *remove_solid_holes
              Detects and removes holes in 3D geometry.
            • *removeassembly
              Deletes assemblies and their contents, including recursive children.
            • *removecrbrelation
              Removes a main-secondary relationship for LS-DYNA *CONSTRAINED_RIGID_BODIES keyword.
            • *removeedgefillets
              Defeatures surface edge fillets.
            • *removeelemsfromcontactsurf
              Removes elements from a contactsurf.
            • *removeelemsfromcontactsurfusingnodes
              Removes elements from a contactsurf using face nodes.
            • *removefilletbetweennodes
              Removes the edge fillet between two nodes.
            • *removeinclude
              Deletes the include file from the database, optionally removing all of its contents as well.
            • *removeincludefromdisplay
              Removes the entities contained in the specified include file from the current display.
            • *removemodel
              Removes a secondary model.
            • *removeposition
              Removes a solver position from another solver position entity.
            • *removesubmodel
              Deletes a solversubmodel or include file, optionally removing all of its contents as well.
            • *removetempcleanupfile
              Use this command to remove temporary files created by the use of *autotopocleanup.
            • *removetransformation
              Removes transformations from positions.
            • *removeview
              Deletes a saved view from the database.
            • *renamecollector
              Renames a collector.
            • *renamecollectorbyid
              Renames a collector to its ID.
            • *renamefile
              Renames a file.
            • *renameviewmask
              Renames a view saved using *saveviewmask.
            • *renumber
              Renumbers the internal HyperMesh IDs for the specified entity type.
            • *renumberall
              Renumbers the internal HyperMesh IDs for all entities in the model.
            • *renumberelemsnodesasmapgrid
              Orders nodes and elements in grid format and renumber nodes and elements with specified start ID.
            • *renumbersolverid
              Renumbers the solver IDs for the specified entity type.
            • *renumbersolveridall
              Renumbers the solver IDs for all entities in the model.
            • *renumbersolveridlist
              Renumbers the solver IDs sent in an ordered list for the specified entity type.
            • *reorderinclude
              Changes the order of the include files in a model.
            • *repair_midmesh_line_imprinter
              Imprint geometric lines to the mesh in the direction provided by the user.
            • *reparammark
              Reparameterizes the lines on a mark.
            • *replacenodes
              Replaces or moves a node with another node.
            • *replacentitywithentity
              Replaces a single component.
            • *replacentitywithentitymark
              Replaces multiple components.
            • *replacesetentitydata
              Sets the data required for part replacement.
            • *rescanunresolvedids
              Discards the unresolved IDs database and creates a new one by examining every entity and its link to other entities to see which are actually unresolved.
            • *reset_elemsize_criteria
              Adjusts the current quality criteria to the specified ideal element size.
            • *reset_thickness_legend
              Resets the thickness legend to its default values.
            • *resetcuttingplanesbase
              Sets the origin coordinates for all cutting planes.
            • *resetreview
              Resets the entity review of the *reviewentity command.
            • *resize
              Sets the resize flag in HyperMesh.
            • *resolvemasslocation
              Resolves unresolved mass locations, using a specified search technique order.
            • *restoreviewmask
              Restores a view saved using *saveviewmask.
            • *retainmarkselections
              Sets the display state of marked entities.
            • *reversecontactsurfnormals
              Change normals (inward to outward, vice versa) of contactsurf.
            • *reverseview
              Reverses the display with respect to a view saved using *saveviewmask.
            • *reviewclearall
              Removes/clears all entities from the review list.
            • *reviewclearbyid
              Removes/clears entities from the review list based on an entity ID.
            • *reviewclearbymark
              Removes/clears entities from the review list based on a mark.
            • *reviewcontactnormalinconsistency
              Graphically reviews the group entity region where the contact normal is inconsistent.
            • *reviewentity
              Graphically reviews a specified entity.
            • *reviewentitybymark
              Graphically reviews a mark of entities.
            • *reviewmaterialorientation
            • *reviewmaterialorientation_option
              Reads and plots the first axis of the element (material) coordinate system for selected elements.
            • *reviewreferencegeometry
              Reviews reference geometry control volume.
            • *reviewsystem
              Reads and plots the x-axis of the element (material) coordinate system for selected elements.
            • *reviewtwomark
              Graphically reviews two mark of nodes with different colors.
            • *rigid
              Creates a rigid element between two nodes.
            • *rigidlink
              Creates a rigid link element between an independent node and multiple dependent nodes.
            • *rigidlinkbycollector
              Creates a rigid link with one independent node and dependent node defined by a collector.
            • *rigidlinkinodecalandcreate
              Creates a rigidlink elem by calculating the independent node based on selection of dependent nodes. Location of independent nodes will be at the geometric center of dependent nodes.
            • *rigidlinkupdatebycollector
              Updates connectivity and properties of a rigid link element with one independent node and dependent node defined by collector.
            • *rigidlinkupdatecalcinodebycollector
              Updates a rigidlink by calculating the independent node based on selection of dependent nodes defined by comps, mats, assems, props sets and nodes.
            • *rigidlinkwithset
              Create a rigid link element with dependent nodes attached as a node set connected to the element. The attached node set may exist before or may be created from a given mark of dependent nodes while the rigid link element is created.
            • *rigidlinkwithset_twonodes
              Create a rigid link element "55" between two nodes, with a dependent node attached as a node set connected with the element.
            • *rigidscombine
              Combines rigids and rigidlinks.
            • *rigidwall_geometry
              Adds geometric definition to a rigid wall.
            • *rigidwallsize
              Sets the size for axis and motion arrow plotting.
            • *rlinkcalcinodeandcreateforcollector
              Creates a rigidlink by calculating the independent node based on selection of dependent nodes defined by collector. The supported collectors are comps, mats, assems, props and sets.
            • *rod
              Creates a rod element.
            • *rotate
              Rotates the model based on a user-defined rotation axis.
            • *rotateabout
              Defines a new center of rotation for *rotate() and *quatrotate() commands.
            • *rotatedummy
              Rotates the dummy by an arbitrary axis that is specified by the *createplane() command.
            • *rotatedummyrootbodytoeulerangles
              Rotates a dummy about a given point.
            • *rotatemark
              Rotates a selection of entities about a plane normal.
            • *rundesignmethod
              Run the design method for a given design point set.
            • *savefailednodesvectors
              Saves the location, magnitude, and direction of the penetrated areas.
            • *savefailedsurfstomark
              Scans all the displayed surfaces, finds those for which all the meshing algorithms failed, and places them on the specified mark. This command is used after one of the commands performing meshing by surfaces.
            • *saveviewmask
              Saves the current view orientation and visible entities.
            • *scale_thickness
              Scales the thickness of an entity.
            • *scalemark
              Scales a selection of entities by multiplying the coordinates.
            • *scalemarkwithsystem
              Scales a selection of entities by multiplying the coordinates relative to the specified system.
            • *screencopy
              Allows users to create a bitmap of the screen and send it to the printer.
            • *screendump
              Generates a PostScript output file from a Macro menu macro.
            • *screenfile
              Allows users to create a bitmap of the screen and save it in a file.
            • *seatbelttensioning
              Updates the nodes of a seatbelt to any intermediate/final configuration. This is attained while tensioning with a choice to maintain the length of the seatbelt.
            • *seatfoamdeformer
              Deforms the selected seat foam components with a choice to create their initial reference geometries.
            • *secondorderfix2
              Advanced fixing of middle nodes for 2nd order elements.
            • *section_plane_mesh
              Generates a shell mesh from a selection of planar boundary elements.
            • *segmentsetaddfaces
              Adds elements using the face/edge option to a segment set.
            • *segmentsetaddfacesusingfacenumber
              Adds faces of elements using a specific face number to a segment set.
            • *segmentsetaddmixedfaces
              Adds element faces to a segment set.
            • *segmentsetaddshells
              Adds selected 1D and 2D elements to a segment set.
            • *segmentsetadjustnormal
              Adjusts a segment set normal using an orientation element.
            • *segmentsetcreateusingfacenumber
              Creates a segment set using 2D element edges or 2D/3D element faces.
            • *segmentsetcreatewithfaces
            • *segmentsetcreatewithmixedfaces
              Creates a segment set using a mixture of solid elements and shell elements.
            • *segmentsetcreatewithshells
              Creates a segment set using 1D or 2D elements.
            • *segmentsetremoveelems
              Removes elements from a segment set.
            • *segmentsetremoveelemsusingnodes
              Removes elements from a segment set using face nodes.
            • *segmentsetreversenormals
              Reverse normals of a segment set.
            • *segregateByPatches
              Creates components using the patches/clusters of connected shell elements.
            • *selfstitchcombine
              Performs equivalencing of edges within surfaces or/and between surfaces.
            • *selfstitchcombine2
            • *separate_fillets
              Detects fillets in 3D models, groups them by radius and width, and moves the fillet surfaces to separate components created for the fillet groups.
            • *separate_holes_in_3d_body_new
              Detects holes in 3D models, groups them by diameter and moves the surfaces defining the holes to separate components created for each hole diameter group.
            • *set_acousticmesh_options
              Assigns certain options used during acoustic cavity meshing.
            • *set_default_quality_criteria
              Sets the default criteria, adjusted to a specified element size, as the current quality criteria.
            • *set_flags_for_2dmesh_context
              Preserves selection topology used by 2D meshing.
            • *set_meshedgeparams
              Sets some of the edge-specific parameters for the automeshing module.
            • *set_meshfaceparams
              Sets some of the face-specific parameters for the automeshing module.
            • *set_midsurface_z_offset
              Sets the z-offset value assigned to a midsurface.
            • *set_preserved_edges
              Marks edge geometry to be preserved during batch meshing, or clears the "preserved" flag from preserved edges.
            • *setautoupdatesets
              Controls automatic updating of sets, segment sets, and contact surfaces during mesh changes.
            • *setbackgroundgradient
              Sets the gradient background color1 and color2 values.
            • *setcleanupglobalflags
              Sets or clears global flags used for switching of some default modes for geometry autocleanup, element cleanup and element QI smoothing.
            • *setcolor
              Set a colormap entry for the entity colors.
            • *setcomponentdisplayattributes
              Sets a component to the specified style and color.
            • *setcomptopologydisplay
              Sets the various types of geometry display at the component level.
            • *setcurrentinclude
              Specifies the include file into which HyperMesh should place newly created entities.
            • *setcurrentmodel
              Sets the specified model as curent.
            • *setcuttingplaneactive
              Turns the specified cutting plane on/off.
            • *setcuttingplanecolor
              Sets the color of the base of the specified cutting plane.
            • *setcuttingplanesbase
            • *setcuttingplanethickness
              Sets the specified cutting plane thickness value.
            • *setcuttingplanethicknesson
              Turns the specified cutting plane thickness on/off.
            • *setdisplayattributes
              Sets all components in the model to the specified style and coloring method.
            • *setedgedensitylink
              Sets the method for linking opposite edge densities during automeshing.
            • *setedgedensitylinkbytypeandaspectratio
            • *setedgedensitylinkwithaspectratio
            • *setelementcheckmethod
              Sets the method (solver) used for calculating specific element quality check parameters which are generally those used by an FE solver.
            • *setelemparamcolor
              Sets the color for a specified element quality parameter for elements violating the threshold.
            • *setelemparamscolors
              Sets the color for all element quality parameters for elements violating the threshold.
            • *setelemparamsvisualpriorities
              Sets the priority for all element quality parameters when reviewing multiple criteria.
            • *setelemparamvisualpriority
              Sets the priority for a specified element quality parameter when reviewing multiple criteria.
            • *setelemqualityparamactive
              Sets the on/off state for a specified element quality parameter.
            • *setentitytypesupportedbyenggid
              Sets the entity types which will be supported by an engineering ID.
            • *setentitytypesupportedbynamepool
              Enables the entity types to have duplicate names for the specified types.
            • *setfacetfactor
              Refines geometry graphical facets based on user settings.
            • *setglobalply
              Sets the ply name to review.
            • *setglobalply_option
              Sets the ply/layer name to review.
            • *setgraphictranslation
              Graphically translates the specified entity.
            • *sethistorylimit
              Sets the maximum number of history states to allow.
            • *sethistorymemorylimit
              Sets the maximum amount of memory that history states are allowed to use.
            • *sethistoryrecord
              Sets whether history recording is enabled or disabled.
            • *setisosurfaceparameters
              Sets the display parameters of the isosurface.
            • *setlegendbackgroundcolor
              Sets the HyperMesh legend background color.
            • *setlightsource
              Set direction of the global light source.
            • *setmacrofile
              Set the default macro file.
            • *setmarkdisplayattributes
              Set the display attributes (wireframe/hidden line, color, etc.) for the entities contained in a mark.
            • *setmarktopologydisplay
              Sets the topology visualization style for the marked geometric entities.
            • *setmenustate
              Controls the display of the HyperMesh menus.
            • *setmeshparams
              Sets 2D meshing edge and face parameters used during surface and element meshing.
            • *setnormalsdisplaytype
              Sets the display type for element normals.
            • *setoffsetconflictoptionmessage
              Set the message option when there is offset conflict during drag-and-drop.
            • *setoption
              Sets various option values.
            • *setply
            • *setply_option
              Sets the ply/layer number to review.
            • *setqualitycriteria
              Defines the current element quality criteria via flexible string input.
            • *setqualitythresholdcolor
              Sets the color for a specified element quality index range.
            • *setqualitythresholdscolors
              Sets the color for all element quality index ranges.
            • *setredoconnectparams
              Specifies parameters for redo connectivity element remeshing.
            • *setreviewbyid
              Adds entities to the review list based on an entity ID.
            • *setreviewbymark
              Adds entities to the review list based on a mark.
            • *setreviewbymarkenhanced
              Adds entities to the enhanced review list based on a mark.
            • *setreviewbyname
              Adds entities to the review list based on an entity name.
            • *setreviewcolormode
              Sets the color mode for non-review list entities.
            • *setreviewmode
              Turns on/off the review list.
            • *setreviewtransparentmode
              Sets the transparency mode for non-review list entities.
            • *setsimulationstep
              Sets the current subcase and simulation step.
            • *setsolver
              Sets the solver.
            • *setsolverusessegmentsets
              Enables/disables support for segment sets.
            • *setsphereclip
              Toggles the spherical clipping feature on and off.
            • *setsubmodeltype
              Sets the sub-model type supported by ID manaager.
            • *setsurfacenormalsdisplaytype
              Sets the display type for surface normals.
            • *setsystem
              Sets the element (material) orientation by setting the angle. This angle is measured from the I-J (1-2) edge of the element around the normal of the element. Re-orients and visualizes the element (material) coordinate systems for selected elements.
            • *settransparency
              Toggles the shaded surface transparency feature on and off.
            • *settrimcuttingplanes
              Turns the cutting plane trim option on/off.
            • *settopologydisplaytype
              Sets the various types of geometry display (wireframe, shaded, etc.)
            • *setusefeatures
              Specifies the mode for defining and using feature edges for element-based re-meshing.
            • *setvalue
              Updates an existing entity/entities with new/modified data.
            • *setviewangles
              Sets the view based on angles.
            • *shapevarcreate_xproduct
              Creates a shape variable by using the cross product of two other shape variables.
            • *shapevarupdate_xproduct
              Updates a shape variable created from the cross product of two other shape variables.
            • *shell_mesh_smoother
              Performs smoothing on selected mesh patches.
            • *shelloffset
              Offsets shells along their element normal direction.
            • *show_new_edge_target_by_number
              Displays the target for a selected surface edge number in the new target component.
            • *show_new_target
              Draws a segment in the new target component. This segment connects the point to offset with the target point.
            • *showall
              Turns on the display of all entities.
            • *showentity
              Turns on the display of an entity.
            • *showentitybymark
              Turns on the display of a mark of entities.
            • *showview
              Shows the entities with respect to a view saved using *saveviewmask.
            • *shrinkwrapmesh
              Generates a shrink wrap mesh of shell or solid elements.
            • *simulationsetangle
              Sets the angle used to evaluate complex results. The evaluated results are used in contour and assigned plots.
            • *simulationtitleon
              Controls the display of the simulation title.
            • *sketchdisassociateentities
              Removes the association between the sketch and its realized entities.
            • *sketchedit
              Edits the sketch entity by adding/removing/modifying entities with various operations.
            • *sketchintersect
              Adds intersected curves into the sketch by intersecting selected entities with the sketch work plane.
            • *sketchproject
              Projects line and surface entities into the sketch work plane along the normal direction.
            • *sl_feature_mesh
              Performs feature-based meshing of surfaces using meshcontrols.
            • *sl_meshsurfaces
              Performs feature-based meshing of surfaces using an XML config file.
            • *slivertetrafix
              Fixes sliver tetra and wedge elements and optimizes node positions based on certain quality criteria.
            • *smooth3d
              Optimizes node locations of 3D elements against user supplied quality criteria.
            • *smoothelements
              In the automeshing module, applies the specified smoothing operator to the mesh (if any) found on the face for the given number of times.
            • *snap_nodes_to_original_geometry_location
              Relocates moved nodes to their original locations on the surface.
            • *solid_cavity_detect_end
              Releases memory from the *solid_cavity_detect_start command.
            • *solid_cavity_detect_fill
              Creates solids from detected cavities and optionally merges the created solids with the parent.
            • *solid_cavity_detect_local
              Extracts cavity surfaces based on input rims and a face of that cavity.
            • *solid_cavity_detect_modify_rims
              Modify a partially detected cavity by adding and removing rims.
            • *solid_cavity_detect_modify_surfaces
              Modify a partially detected cavity by adding and removing surfaces.
            • *solid_cavity_detect_start
              Detects cavities (protrusion only) from a solid.
            • *solid_extrude_from_surfs
              Create solids by extruding a set of selected surfaces along a given vector.
            • *solid_facesfind
              Find new 2D faces from 3D elements in select components.
            • *solid_fixedptsmaker
              Used in the Solidmap panel to create fixed points on the edges of selected components. These points are generated from nodes on the component’s edges that fall within a specified tolerance, and are meant to be transitory.
            • *solid_fixedptssuppressor
              Suppresses the selected fixed points.
            • *solid_offset_from_surfs
              Create solids by normally offsetting a set of selected surfaces.
            • *solid_prepare_entitylst
              Used to read entities on mark ID 1 into an internal solidmap entity array.
            • *solid_prepare_nodeline
              Used to read nodes on list ID 2 into an internal solidmap node array.
            • *solid_split_by_tool
              Splits solid geometry using various tool types.
            • *solid_untrim
              Untrims solids by removing surfaces that separate them.
            • *solidblock
              Create a parallelepiped block solid.
            • *solidcone
              Create a full or partial cone or cylindrical solid.
            • *solidcreatedragsurfalongline
              Create one or more solids by dragging one or more surfaces along a line.
            • *solidcreateruled
              Create a solid that interpolates linearly or smoothly between input surfaces.
            • *solidcreatespinsurfwithoffsetangle
              Create solids by rotating a set of selected surfaces around a given axis.
            • *solidmap_begin
              Marks the beginning of a solid mapping command block.
            • *solidmap_end
              Marks the end of a solid mapping command block.
            • *solidmap_equivalence
              Used for equivalencing two sets of nodes for solid mapped meshing.
            • *solidmap_initialize_edges
              Initializes the line mesh parameters after resolving the density conflicts of the lines in the solid.
            • *solidmap_prepare_usrdataptr
              Used to setup the inputs to a solid mapping command block.
            • *solidmap_set_source_size
              Sets the source 2D mesh size for the next call to *solidmap_end.
            • *solidmap_solids_begin
              Starts a multiple-solid solidmap command block.
            • *solidmap_solids_begin2
              Starts a multiple-solid solidmap command block, with optional source and destination hints.
            • *solidmap_solids_end
              Ends a multiple-solid solidmap command block.
            • *solidmap_solids_set_density
              Sets the per-edge element density within a multiple-solid solidmap command block.
            • *solidmap_solids_set_elemsize
              Sets the per-edge element size within a multiple-solid solidmap command block.
            • *solidmap_solids_set_face_params
              Sets the per-surface mesh type and mesh flags within a multiple-solid solidmap command block.
            • *solidmap_solids_set_mapface
              Sets the surface shared by the 4 input points to the mapped type within a multiple-solid solidmap command block.
            • *solidmesh9lines
              Creates a solid mesh on a volume formed by nine lines.
            • *solidmesh12lines
              Creates a solid mesh in a volume formed by twelve lines.
            • *solidmeshwithsurfaces
              Creates a mesh of solid elements by first extruding an existing 2D finite element mesh, and then mapping the extruded mesh into a volume.
            • *solids_create_from_surfaces
            • *solverconvert
              Converts a model from one solver to another.
            • *solverdeckcleanup
              Deletes or retains certain solver specific entities, based on their validity in the current model.
            • *sort_midsurfaces
              Sorts mid-surfaces from the "Middle Surface" component into other components.
            • *spatialrenumbering
              Renumbers the solver IDs for the specified entity type based on spatial locations.
            • *specialelements
              Creates special elements like gasket elements between a source and target, or updates penta/hexa elements to special elements like gasket elements.
            • *sphereclipautofit
              Toggles the autofit feature for spherical clipping on or off.
            • *sphereclipcenter
              Sets the center for spherical clipping.
            • *sphereclipradius
              Set the radius for spherical clipping.
            • *sphgenerate_new
              Generates SPH elements with various options.
            • *splinesurface
              Creates a 3D or planar surface defined by a set of lines, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a Coons patch surface for the automesher to use under the mesh without surface option.
            • *split_elements_by_structure_pattern
              Creates a transition mesh between refined and boundary regions.
            • *split_elements_by_structure_pattern_freeselection
              Creates a refined mesh inside a selected area and makes the transition using structured patterns .
            • *split_hex_continuum
              Split solid element layers through all edges that are topologicaly parallel to the selected edges while maintaining connectivity and associativity.
            • *split1delements
              Split 1D elements using various options.
            • *splitcontactfromcontactgroup
              Disassociates a group (contact pair/tie) entity from a contact group.
            • *splitelementbyedges
              Splits shell element edges that are intersected by a line joining the input points.
            • *splitelementbyelemselect
              Splits shell element patches using patterns based on the patch shared edges.
            • *splitelements
              Splits shell elements using various methods.
            • *splitelementswith1D
              Splits shell elements on all sides, along with all connected 1D elements.
            • *splitsolidelements
              Divides the given solid elements into hexa or tetra elements.
            • *splitSurfaceRegions
              Splits regions based on the connectivity of the contained surfaces.
            • *spring
              Creates a spring element between two nodes using an orientation vector.
            • *springfournoded
              Creates a spring element between four nodes using an orientation vector.
            • *springos
              Creates a spring element between two nodes using various orientation methods.
            • *springsosupdate
              Updates a spring element using various orientation methods.
            • *springsupdate
              Updates the properties of spring elements.
            • *springthreenoded
              Creates a spring element between three nodes using an orientation vector.
            • *stackdisplay
              Displays the stack direction of selected entities.
            • *stackreverse
              Reverses the stack direction of selected entities.
            • *start_batch_import
              Initializes a sequence of multi-file batch import/merge operations.
            • *startnotehistorystate
              Defines the start of a history state.
            • *stiffenedpanelmesh
              Creates a stiffened panel mesh between lines or on surfaces.
            • *storemeshtodatabase
              Converts a generated mesh (if any) into elements in the specified component.
            • *summary
              Prints or displays a summary from a specified template.
            • *superelementset
              Sets the super element flag on a group of nodes.
            • *surface_rmesh
              Used by the R-Mesh macro to quickly generate a quad/tria shell mesh for rigid tool surfaces.
            • *surfaceaddnodesfixed
              Adds meshing fixed points to a mark of surfaces, either by breaking edges or adding interior fixed points. The coordinates of the fixed points are supplied by a list of nodes.
            • *surfaceaddpoint
              Add a fixed point on a surface at the specified coordinates.
            • *surfaceaddpointsfixed
              Adds meshing fixed points to a mark of surfaces, either by breaking edges or adding interior fixed points. The coordinates for the fixed points are supplied by a pointmark.
            • *surfacecone
              Creates a full or partial cone, and optionally, prepares it for immediate use in the automesher. It also can identify a conical region for the automesher to use under the mesh without surface option.
            • *surfaceconefull
              Creates a cone with a specified center and radius, and optionally, prepares it for immediate use in the automesher. It also can identify a conical region for the automesher to use under the mesh without surface option.
            • *surfacecopyedges
              Create lines from the edges of a surface.
            • *surfacecreatedraglinealongline
              Create one or more surfaces by dragging one or more lines along a line.
            • *surfacecreatedraglinealongnormal
              Creates one or more surface by dragging the input lines along their curvature direction.
            • *surfacecreatedraglinealongvector
              Create surface(s) by extruding line(s) along a vector.
            • *surfacecreatedragnodesalongline
              Create one or more surfaces by dragging a line which is created by a set of input nodes along another line.
            • *surfacecreatenormalfromedges
              Creates surfaces in the normal direction from the edges of adjacent surfaces.
            • *surfacecreatenurbs
              Create a NURBS surface using input parameters.
            • *surfacecreateruled
              Create surfaces that interpolates linearly or smoothly between input lines.
            • *surfacecreatespinlinewithoffsetangle
              Spins lines to create surfaces by specifying a start and end angle.
            • *surfacecreatespinnodeswithoffsetangle
              Spins a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher.
            • *surfacecreatetangentfromedges
              Create surfaces extending in the tangent direction from the surfaces along selected edges.
            • *surfacedisplaynormals
              Turns on the display of surface normals.
            • *surfacefilletremove
              Defeatures/removes selected fillet surfaces.
            • *surfaceimprintpoints
              Imprints locations/points, given by coordinates, onto surfaces within a given max distance.
            • *surfaceintersectmark
              Creates lines by intersecting surfaces with a plane or other surfaces.
            • *surfaceintersectmark2
            • *surfacemark_duplicate_check
              Check identity between input surface sets.
            • *surfacemark_find_organize_symmetry
              Identify symmetry between surfaces in a given set, with respect to a given reflection plane.
            • *surfacemarkaddnodesfixed
              Add fixed points to a surface at locations specified by nodes.
            • *surfacemarkclipwithline
              Splits a group of surfaces with a line by projecting that line perpendicularly onto the surfaces.
            • *surfacemarkclipwithlines
              Splits a group of surfaces with lines by projecting those lines perpendicularly onto the surfaces.
            • *surfacemarkfeatures
              Reorganize the topology of a given set of surfaces based on various input test parameters. There are five separate tests available as well as options to close orphans and update or move (explained below). If the arguments to a test are -1, the test is not done. Therefore, the command is used for a variety of combinations of various tests.
            • *surfacemarkmerge
              Combines the selected surfaces into one surface, and divides the surface along the internal edges that correspond to fillets and feature lines.
            • *surfacemarkremoveallpinholes
              Removes all pinholes of a specified size from the specified surfaces.
            • *surfacemarkremovelinefillets
              Defeatures specific surface edge fillets.
            • *surfacemarkremovepinholes
              Removes pinholes.
            • *surfacemarksplitwithline
              Splits a mark of surfaces with a line swept along a vector.
            • *surfacemarksplitwithlines
              Splits a mark of surfaces with lines swept along a vector.
            • *surfacemarksplitwithnodes
              Splits a group of surfaces with a smooth line defined by the nodes.
            • *surfacemarksplitwithplane
              Splits a group of surfaces with an infinite plane.
            • *surfacemarksplitwithsurface
              Splits a group of surfaces with another surface.
            • *surfacemarkuntrim
              Removes any trim lines from the selected surfaces and lets the surface expand to its natural limits. The trim lines are separated from the surface and placed in the current component.
            • *surfacemode
              Sets the mode for automesh surface and shell mesh generation.
            • *surface_patch
            • *surfaceplane
              Creates a square, planar surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a square planar surface for the automesher to use under the mesh without surface option.
            • *surfaceprimitivefromlines
              Create a primitive type surface from selected lines.
            • *surfaceprimitivefrompoints
              Create a primitive type surface from selected nodes or points.
            • *surfacereversenormals2
              Reverses the normals of surfaces.
            • *surfaceskin
              Creates a skin surface across a line list, and optionally, prepares it for immediate use in the automesher. It can also identify a region in the shape of a skin surface for the automesher to use under the mesh without surface option.
            • *surfacespherefromfournodes
              Creates a sphere which passes through the four specified nodes, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
            • *surfacespherefromthreepoints
              Creates a full or partial sphere, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
            • *surfacespherefull
              Creates a sphere with a specified center and radius, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
            • *surfacesplinefillholes
              Creates spline surfaces on all loops of selected lines.
            • *surfacesplinefillholes2
            • *surfacesplinefrommesh
              Creates geometry on selected 2D mesh elements. Uses selected plot elements to create edges between surfaces.
            • *surfacesplinefrompoints
              Creates a spline surface using selected nodes or points as boundary conditions.
            • *surfacesplineonlinesloop
              Create a single spline surface on a loop of lines.
            • *surfacesplineonnodesloop2
              Creates a spline surface using a node list as boundary conditions.
            • *surfacesplinepatchforholes
              Creates a spline surface inside all loops of selected lines.
            • *surfacesplitwithcoords
              Splits a surface with a line created between using coordinates.
            • *surfacesplitwithline
              Splits a surface with a line by sweeping the line along a vector.
            • *surfacesplitwithplane
              Splits a surface with an infinite plane.
            • *surfacesplitwithsurface
              Splits one surface with another.
            • *surfacestringcreatemidline
              Creates midlines for strings of narrow surfaces (fillets, rib tops, etc...).
            • *surfacetorus
              Creates a full or partial torus, and optionally, prepares it for immediate use in the automesher. It also can identify a toroidal region for the automesher to use with the mesh without surface option.
            • *surfacetorusfromthreepoints
              Creates a torus which passes through the three specified nodes, and optionally, prepares it for immediate use in the automesher. It also can identify a toroidal region for the automesher to use with the mesh without surface option.
            • *surfacetorusfull
              Creates a torus with specified radii, and optionally, prepares it for immediate use in the automesher.
            • *surfmark_trim_by_elemmark
              Trims the selected surfaces by selected elements using input lines or edges as reference.
            • *surfmark_trim_by_surfmark
              Trims surfaces along the intersection(s) with other surfaces.
            • *swapcards
              Swaps the card image of an entity.
            • *swapcontactmainsecondary
              Swaps the main and secondary entities of groups.
            • *syncpropertybeamsectionvalues
              Copies the beam section values to property values. Currently valid only for Nastran and OptiStruct.
            • *system
              Creates and updates coordinate systems.
            • *systemcommand
              Executes a system command.
            • *systemconvertnodetoaxis
              Converts systems from nodal reference to axis reference.
            • *systemcreate3nodes
              Creates a rectangular coordinate system.
            • *systemorthobound
              Makes sure that a child system lies within the specified euler angle bounds with respect to the parent child system. If it does not, it moves the child system in the most direct path so that it does.
            • *tableaddcolumn
              Adds a column of data to the right of a table.
            • *tableaddrow
              Adds a row of data to the bottom of a table.
            • *tablecontour
              Contours node/element data from a table.
            • *tablecreate
              Creates a new table.
            • *tabledeletecolumn
              Deletes a column of data from a table.
            • *tabledeleterow
              Deletes a row of data from a table.
            • *tableexport
              Exports data from a table to a file.
            • *tableinsertcolumn
              Inserts a column of data into a table.
            • *tableinsertrow
              Inserts a row of data into a table.
            • *tablepopulate
              Populates a table with data from a delimited file.
            • *tableupdatecell
              Updates the value of a cell in a table.
            • *tableupdatecolumn
              Updates the values in a column of a table.
            • *tableupdatelabels
              Updates the column labels of a table.
            • *tableupdaterow
              Updates the values in a row of a table.
            • *tangentbetweenlines
              Creates a tangent line between two lines.
            • *tangentbetweennodeandline
              Creates a tangent line between a node and a line.
            • *templatefileset
              Sets the global template file name.
            • *tetmesh
              Creates tetra meshes and CFD tetra meshes (with boundary layers).
            • *tetmesh_create_size_ctrl
              Creates a special component for use as an element size control box.
            • *tetmesh_set_input
              Supplies additional input to *tetmesh.
            • *time
              Prints the current time to the command file.
            • *titlecreate
              Creates a title.
            • *titledraw
              Draws a title.
            • *titlemodify
              Modifies a title entity.
            • *titlepop
              Pops a title to the front.
            • *titlepush
              Pushes a title to the background.
            • *titlesetcurrent
              Sets a title to be the current title.
            • *toggleincludefromdisplay
              Toggles the entities contained in the specified include file to/from the current display.
            • *topography_reanalysis
              Extract the final geometry from OptiStruct topology, topography and shape optimization results and inherit the boundary conditions for reanalysis.
            • *transformmark
              Transforms a selection of entities using a transformation matrix.
            • *translatemark
              Translates a selection of entities along a vector.
            • *translatemarkwithsystem
              Translates a selection of entities along a vector of the specified system.
            • *transparencymark
              Makes the shaded surfaces in components on the mark transparent.
            • *transparencyvalue
              Sets the level of transparency for the shaded surface in components that are set to be transparent.
            • *triangle_clean_up
              Fixes sliver/bad quality elements which fail the user-defined aspect ratio.
            • *trim_by_offset_edges
              Offset selected surface edges and trim attached surfaces.
            • *trim_elements2
              Trims 2D elements using 1D or 2D elements.
            • *trim_elems_by_multi_circular_hole
              Trims shell elements with a circular hole and adds optional washer layers.
            • *trim_mesh_by_mesh
              Trims intersecting meshes using the source, target, or both.
            • *trim_shell_elems_by_shell_elems
              Trim 2D elements with 2D elements along their intersection lines, and remove small penetrating parts of elements between the intersection lines and free element edges.
            • *trueview
              Modifies the view so that a model-defined vector is normal to the screen.
            • *undohistorystate
              Undoes one or more history states.
            • *unlockallentities
              Unlock all entities with the same entity type and ID pool across includes.
            • *unlockentities
              Removes entity locks.
            • *unlockview
              Deletes the saved view with the name "Lock".
            • *unmaskall
              Unmasks all supported entities.
            • *unmaskall2
            • *unmaskentitiesincollector
              Unmasks the specified entities contained within the specified collectors.
            • *unmaskentitymark
              Unmasks the entities on the specified mark.
            • *unmaskshown
              Unmasks all supported entities in the current view window.
            • *unmaskshown2
            • *unrealizeengineeringentities
              Unrealize engineering entities.
            • *unrealizeengineeringentity
              Unrealize an engineering entity.
            • *unsmoothelements
              From within the automeshing module, undoes the last operation of the *smoothelements() command for the specified face.
            • *untrim_selected_edges
              Untrims selected surface free edges.
            • *update1delements
              Updates 1D beams, bars and rods, and optionally assigns properties. Alternately, properties and offset can be calculated from a section cut on the model.
            • *UpdateBinderSections
              Update the binder shape using the current section. The binder and the section are identified automatically.
            • *UpdateController
              Updates connector control or attachment control information.
            • *updatefeatures
              Specifies for element remesh with feature edges, if 1D elements selected as features are also refined.
            • *updatefree1delements
              Updates rigidlink and RBE3 elements to remove free legs and optionally update the weights.
            • *updateidrange
              Updates an ID range.
            • *updateinclude
              Updates include file basic information.
            • *updateincludedata2
              Updates include file solver specific information.
            • *UpdateLatitudeLineDrag
              This command updates the latitude line shape and the addendum surface shape, after the latitude line handle drag.
            • *updateoffset
              Update the definition of offset.
            • *updatepositions
              Reorganize entities, in case of an add, remove, delete transformations or change in transformation order operations.
            • *updatepropertyidforfejoints
              Updates the property ID for the given FE joint elements.
            • *updatereferencegeometry
              Updates a reference geometry control volume.
            • *usercheck
              Runs a template that can be used to check element quality.
            • *vabs
              Generates VABS cross-sectional ply mesh information along with an OptiStruct solver file.
            • *validatefeatures
              Validates the selected feature entities and flags them for re-detection.
            • *vectorcreate_xproduct
              Creates a vector entity by using the cross product of two other vectors.
            • *vectorplot
              Creates a vector plot from results data.
            • *vectorsoff
              Remove review vectors from the screen.
            • *vectorupdate_xproduct
              Updates a vector entity created from the cross product of two other vectors.
            • *vertexrelease
              Unstitches the selected vertex.
            • *verticescombine
              Given one surface fixed point to retain, and one or more additional fixed points, combines all of the points into the first point. Some surface edges or entire surfaces may be deleted in the process.
            • *verticesmarksuppress
              Removes the selected fixed points from their surfaces, and gives the option to create free points at those locations.
            • *verticesrelease
              Unstitches selected vertices.
            • *view
              Modifies the current view.
            • *view_restoreprevious
              Return to previous view state.
            • *viewset
              Sets the graphics view.
            • *visualizemode
              Sets the parameters for visualization mode.
            • *voxel_lattice_hex_mesh_add_box
              Adds elements within a box to the include entities in the voxel domain.
            • *voxel_lattice_hex_mesh_add_buffer_layers
              Adds buffer layers to all include entities in the voxel domain.
            • *voxel_lattice_hex_mesh_add_entities
              Adds entities to the voxel domain.
            • *voxel_lattice_hex_mesh_add_entities_with_buffer
              Adds entities to the voxel domain with a number of buffer layers.
            • *voxel_lattice_hex_mesh_add_planar_constraint
              Adds a planar constraint to the voxel session.
            • *voxel_lattice_hex_mesh_add_volume
              Adds a volume surrounding a given point to the voxel domain.
            • *voxel_lattice_hex_mesh_create
              Creates voxel elements from the inputs given to the voxel session.
            • *voxel_lattice_hex_mesh_drag_faces
              Drags faces of existing voxels to create new voxels.
            • *voxel_lattice_hex_mesh_end
              Ends the voxel hex mesh module.
            • *voxel_lattice_hex_mesh_fill_voids
              Sets the mode for filling closed volumes during voxel creation.
            • *voxel_lattice_hex_mesh_import
              Imports an existing voxelization in to the current voxel session.
            • *voxel_lattice_hex_mesh_init
              Initializes the voxel hex mesh module.
            • *voxel_lattice_hex_mesh_remove_buffer_layers
              Removes buffer layers from all include entities in the voxel domain.
            • *voxel_lattice_hex_mesh_remove_constraints
              Removes all planar constraints for the current voxel session.
            • *voxel_lattice_hex_mesh_remove_entities
              Removes entities from the voxel domain.
            • *voxel_lattice_hex_mesh_remove_volume
              Removes a volume surrounding a given point from the voxel domain.
            • *voxel_lattice_hex_mesh_renumber_to_grid_position
              Renumbers the voxel elements according to grid numbering.
            • *wadlines_createlines
              Creates multiple wadlines.
            • *wadlines_createspheres
              Creates sphere surfaces for testing rear reference line of pedestrian impact.
            • *wadlines_hardpartzone
              Creates the hard part zone by duplicating and trimming the vehicle outer components with test zone boundaries.
            • *wadlines_windscreenperiphery
              Creates the hard part zone for pedestrian tool by duplicating and trimming vehicle outer components with test zone boundaries.
            • *walldisplay
              Displays a wall.
            • *weld
              Creates a weld element between two nodes.
            • *wind_tunnel_mesh
              Generates a hex mesh for the far-field, a tetra mesh for the interface clearance, and a 3D boundary-layer mesh on the body.
            • *window
              Modifies the current window.
            • *window_entitymark
              Fits the view to the entities on the mark.
            • *writecurrentqualitycriteria
              Writes the current quality criteria to the specified file.
            • *writefile
              Saves a binary HyperMesh database.
            • *writeh3dwithoptions
              Writes an H3D file using various options to control the exported data.
            • *writemodelcheckresultfile
              Writes out model check results to a file.
            • *writepart
              Exports part information.
            • *writeqiviewsettings
              Writes a file containing the element quality view mode settings.
            • *writequalitysummary
              This command is executed from the 2D page’s Quality Index panel. It has little to no valid usage in custom macro scripts, because it does not perform any calculations.
            • *xelem_bynodelist
              Creates a new element(/XELEM) of config 27 and type 1 using a node list.
            • *xelem_bysetid
              Creates a new element(/XELEM) of config 27 and type 1 using a node set.
            • *xyplotchangemode
              Changes the mode of an extended plot.
            • *xyplotcoloroverride
              Sets the override color for xy plots.
            • *xyplotcreate
              Creates an xy plot.
            • *xyplotcreateandsize
              Creates an xy plot with the indicated position and dimensions.
            • *xyplotcreatecomplex
              Creates an extended or dual plot that contains two sub-plots.
            • *xyplotcurvecreate
              Creates a curve.
            • *xyplotcurvemodify
              Modifies a curve.
            • *xyplotcurvepermute
              Permutes a curve.
            • *xyplotdraw
              Draws an xy plot.
            • *xyplotexpand
              Expands a plot to cover the entire graphics region of the screen.
            • *xyplotfindcurves
              Resizes the xy plot window so that the curves on the xy plot are fully visible.
            • *xyplotmodify
              Modifies an xy plot.
            • *xyplotonecurvemath
              Performs a math function on a curve.
            • *xyplotorganize
              Organizes the active plots so that they are fully visible on the screen.
            • *xyplotpage
              Pages through the active xy plots making each plot the entire size of the screen, and then pausing until a mouse click.
            • *xyplotpop
              Pops an xy plot to the top level.
            • *xyplotpush
              Pushes an xy plot to the bottom level.
            • *xyplotreadcurve
              Reads a curve(s) from an ASCII file.
            • *xyplotreadengineeringcurve
              Reads in stress/strain information for HyperForm.
            • *xyplotregisterexternalreader
              Registers a translator for use in the Edit Curves panel.
            • *xyplotregisterimporttemplate
              Registers an import template.
            • *xyplotsetcurrent
              Sets the current xy plot
            • *xyplotsetcurve
              Sets the current curve.
            • *xyplotsetcurves
              Sets the curve pointers on a plot.
            • *xyplotsetsecondcurve
              Sets the second curve to be used when performing mathematical functions on a curve.
            • *xyplotstack
              Stacks the active xy plots.
            • *xyplottwocurvemath
              Performs a math function on two curves.
            • *xyplotwindow
              Sets the minimum and maximum values for the plot window.
            • *xyplotzoomout
              Modifies the window of an xy plot by zooming out (reducing the size of the curves).
            • Deprecated Tcl Modify Commands
              The list of deprecated Tcl modify commands, and the new commands to use.
            • Undocumented Tcl Modify Commands
              The list of undocumented Tcl modify commands.
          • Tcl Query Commands
          • Utility Menu Commands
            Documentation on the commands that control the Utility menu.
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
View All Altair Simulation Help
HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  2. HyperWorks Reference Guides
  3. HyperMesh
  4. Scripts
  5. Commands and Functions
  6. Tcl Modify Commands
  7. *view_restoreprevious
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Reference Guides
Index
HyperMesh Tcl Modify Command
None.
Related reference
hm_arcball
hm_centerview
hm_circlezoom
hm_getcurrentview
hm_panview
hm_rotateview
hm_scaleview
hm_viewbottomside
hm_viewccw
hm_viewcw
hm_viewdown
hm_viewfit
hm_viewfrontside
hm_viewisometric
hm_viewleft
hm_viewleftside
hm_viewprevious
hm_viewrearside
hm_viewreverse
hm_viewright
hm_viewrightside
hm_viewtopside
hm_viewup
hm_zoomin
hm_zoomout
*rotateabout
*view
*window
See Also
*quatrotate
*rotate
*rotateabout
*view
*viewset
*window
hm_winfo
hm_writeviewcommands
