hm_centerview
Moves the selected location to the center of the modeling window.
hm_centerview
HyperMesh Tcl GUI Command
This command allows you to move the selected point to the center of the modeling window. When the command is first executed, it waits for the cursor to move into the modeling window. The left mouse button can then be pressed to select a point to move to the center. The right mouse button can be used to cancel the operation. Moving the mouse outside the modeling window also cancels the operation.
hm_centerview
None.
