hm_viewreverse
Rotates the model 180 degrees about an axis oriented vertically across the screen.
hm_viewreverse
HyperMesh Tcl GUI Command
This command allows the user to rotate the model 180 degrees about an axis oriented vertically across the screen.
hm_viewreverse
None.
