hm_editcard
Launches the Card Editor to edit a specific entity or mark of entities.
hm_editcard entity_type mark_id ?config? ?type? ?card_image?
HyperMesh Tcl GUI Command
This command launches the HyperMesh Card Editor to allow editing of a specific entity or mark of entities. This command must be called from within hm_setpanelproc.
entity_type
The type of entity to card edit.
mark_id
The ID of the mark containing the entity or entities. Valid values are 1 and 2.
?config?
The entity's configuration number. This is only required for entities that have a configuration number.
?type?
The entity's solver type number. This is only required for entities that have a type number.
?card_image?
The name of the card image to load.
To edit element 100:
*createmark elems 1 100
hm_setpanelproc {hm_editcard elems 1}
   # Handle error
