hm_collectordisplayed
Returns the display status of a collector.
hm_collectordisplayed entity_type entity_name
HyperMesh Tcl GUI Command
This command returns the status (0 or 1) of the specified collector. For collectors with both geometry and element display states, only the element display state is considered.
entity_type
The type of the collector entity to query.
entity_name
The name of the collector.
To determine if component "part200" is displayed on (based on elements):
hm_collectordisplayed comps part200
   # Handle error
