hm_launchhb
Launches the HyperBeam GUI with a specified beam section loaded by default.
hm_launchhb ?beam_section_id?
HyperMesh Tcl GUI Command
beam_section_id
The ID of the beam section to load by default when launching the GUI. If not specified, the first section is loaded.
To launch the GUI with beam section ID 10 loaded by default:
hm_launchhb 10
   # Handle error
Version History
12.0
