hm_getpanelitems
Returns the IDs and names of menu bar items in the Connector panels.
hm_getpanelitems ce_panelname
HyperMesh Tcl GUI Command
The command returns the IDs names of all the fields inside the Connector panels, as well as the subpanels, in the form of an organized list with the name of the subpanel at the beginning. Currently this command is only supported for the Connector panels.
ce_panelname
The name of the panel to query. Currently supported values are:
  • "connector area"
  • "connector bolt"
  • "connector seam"
  • "connector spot"
To get the panel IDs and names for the Connector Spot panel:
hm_getpanelitems "connector spot"
Version History
9.0
