hm_enableitem
Enables a panel menu item.
hm_enableitem panel_name item_number
HyperMesh Tcl GUI Command
This command enables a panel menu item.
panel_name
The name of the panel.
item_number
The number of the item in the panel. hm_getitemnumber can be used to get the number for a menu item.
   # Handle error
