hm_clearmarker
Clears the graphical marker created by hm_plotmarker.
hm_clearmarker ?entity_type? ?<select_type>=<selection>? ?dataname=<data name/attribute>?
HyperMesh Tcl GUI Command
To clear specific markers on specific entities: hm_plotmarker entity_type <select_type>=<selection> dataname=<data name/attribute>
To clear all markers on specific entities: hm_plotmarker entity_type <select_type>=<selection>
To clear all markers on a specific entity type: hm_plotmarker entity_type
To clear all markers: hm_plotmarker
entity_type
The type of entity to clear markers for. Valid values are nodes, elements, points, lines, surfs and solids.
The entity or entities to clear markers for.
id=<id>
The ID of the single entity.
list=<list_id>
The ID of the list containing the entiteis. Valid values are 1 and 2.
mark=<mark_id>
The ID of the mark containing the entities. Valid values are 1 and 2.
The data name or attribute to clear markers for.
Examples
To clear the ID data name markers for elements 1-100:
*createmark elems 1 1-100
hm_clearmarker elements mark=1 dataname=id
To clear all markers for elements 1-100:
To clear all markers for all elements:
hm_clearmarker
   # Handle error
Version History
2019.1
