hm_getint
Get an integer value using a HyperMesh panel.
hm_getint ?caption? ?message? ?default_value?
HyperMesh Tcl GUI Command
This command returns an integer value by providing you with a HyperMesh panel.
- ?caption?
 - Optional caption to show when entering the panel.
 - ?message?
 - Optional string to show in the status bar when entering the panel. caption must be specified to use this option.
 - ?default_value?
 - Optional default integer to set when entering the panel. message must be specified to use this option.
set count [hm_getint "Count=" "Please specify the count"]
None.
Version History
2017.1 - Added new optional default_value argument.
