hm_clearshape
Clears the graphical shape created by hm_plotshape.
hm_clearshape ?entity_type? ?<select_type>=<selection>? ?shape=<shape>?
HyperMesh Tcl GUI Command
To clear specific shapes on specific entities: hm_plotshape entity_type <select_type>=<selection> shape=<shape>
To clear all shapes on specific entities: hm_plotshape entity_type <select_type>=<selection>
To clear all shapes on a specific entity type: hm_plotshape entity_type
To clear all shapes: hm_plotshape
entity_type
The type of entity to clear shapes for. Valid values are nodes.
The entity or entities to clear shapes for.
id=<id>
The ID of the single entity.
list=<list_id>
The ID of the list containing the entiteis. Valid values are 1 and 2.
mark=<mark_id>
The ID of the mark containing the entities. Valid values are 1 and 2.
shape=<shape>
The shape type to clear. Valid values are box, cone, cylinder, ellipsoid, frustum and sphere.
Examples
To clear the sphere shapes for nodes 1-100:
*createmark nodes 1 1-100
hm_clearshape nodes mark=1 shape=sphere
To clear all shapes for nodes 1-100:
To clear all shapes for all nodes:
hm_clearshape nodes
hm_clearshape
   # Handle error
Version History
2019.1
