hm_setpanelposition
Sets the position of the panel area.
hm_setpanelposition position
HyperMesh Tcl GUI Command
This command sets the position (top | bottom) of the panel area. If the panel area is not currently visible, it will not be turned on.
position
The position of the panel area. Valid values are top and bottom.
hm_setpanelposition top
   # Handle error
Version History
9.0
2021 - Deprecated in HyperWorks but continues to be supported in HyperWorks Desktop.
