hm_registerentitysubtypefilter
Registers an entity sub-type filter for usage by *createmarkpanel or *createentitypanel.
hm_registerentitysubtypefilter entity_type sub_type filter_value
HyperMesh Tcl Query Command
Registers an entity sub-type filter for usage by *createmarkpanel or *createentitypanel. Note that filters persist through an entire HyperMesh session unless they are cleared.
entity_type
The type of entity to register the filter for.
sub_type
The sub-type identifier. Valid values are cardimage, config, and idpool.
filter_value
The value of the sub-type filter.
For sub_type card image a filter_value of &PRESENT filters solely on the existence of any card image for the entity.
To register a filter for properties with the card image PSHELL, prompt the user to select, and unregister:
hm_registerentitysubtypefilter props cardimage PSHELL
*createmarkpanel props 1 "Select a PSHELL property."
hm_unregisterentitysubtypefilter props
   # Handle error
Version History
13.0
