*createmarkpanel
Provides a panel to add entities to a mark.
*createmarkpanel entity_type mark_id message ?face_edge_mode? ?filter?
HyperMesh Tcl Modify Command
entity_type
The type of entities to add.
mark_id
The ID of the mark. Valid values are 1 and 2.
message
A string to show in the message bar when entering the panel.
?face_edge_mode?
The default face/edge selection mode to use when entering the panel. This is valid only for nodes and elements. An invalid value defaults to 0, or is ignored for non-supported entity types.
  • 0 - Standard entity selection
  • 1 - 2D faces (elems) or faces (nodes)
  • 2 - 2D faces ext (elems and nodes)
  • 3 - Free edges (nodes only)
  • 4 - Edges (nodes only)
  • 5 - Loops (nodes only)
  • 6 - Free edges ext (nodes only)
  • 7 - Edges ext (nodes only)
?filter?
Defines which selection modes should be allowed. Bit values are used and the value is calculated as (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 + 64*Bit6 + 128*Bit7).
A value of 0 (default) means all selection modes are available.
For nodes, if the sum does not include Bit0 set to 1, although nodes are collected, what is highlighted are the faces/edges. Proceed from the panel, and the corresponding nodes will be highlighted.
Bit0:
0 - Do not allow standard selection (elems and nodes)
1 - Allow standard selection (elems and nodes).
Bit1:
0 - Do not allow 2D faces (elems) or faces (nodes)
1 - Allow 2D faces (elems) or faces (nodes)
Bit2:
0 - Do not allow 2D faces ext (elems and nodes)
1 - Allow 2D faces ext (elems and nodes)
Bit3:
0 - Do not allow free edges (nodes only)
1 - Allow free edges (nodes only)
Bit4:
0 - Do not allow edges (nodes only)
1 - Allow edges (nodes only)
Bit5:
0 - Do not allow loops (nodes only)
1 - Allow loops (nodes only)
Bit6:
0 - Do not allow free edges ext (nodes only)
1 - Allow free edges ext (nodes only)
Bit7:
0 - Do not allow edge ext (nodes only)
1 - Allow edge ext (nodes only)
Examples
To create a mark of elements in a panel:
*createmarkpanel elems 1 "Please select the elements"
hm_getmark elems 1
To create a mark of elements in a panel using 2D faces as the default selection mode:
*createmarkpanel elems 1 "Please select the elements" 1
hm_getmark elems 1
To create a mark of elements in a panel using 2D faces as the default selection mode, only allowing 2D faces and 2D faces ext modes:
*createmarkpanel elems 1 "Please select the elements" 1 6
hm_getmark elems 1
   # Handle error
Version History
2019 - Added new face_edge_mode values 6 and 7.
