*exclusiveidrange
Sets an exclusive ID range.
*exclusiveidrange submodel_type id shortname entity_type ?pool_id?
HyperMesh Tcl Modify Command
This command sets an exclusive ID range for a submodel.
- submodel_type
 - The submodel type to sets the exclusive ID range for. Valid values are includes and includefiles.
 - id
 - The submodel ID. Not required, if shortname is used.
 - shortname
 - The shortname of the submodel. Not required if id is used.
 - entity_type
 - The entity type to set the exclusive ID range for.
 - pool_id
 - The optional ID of the solver pool.
*exclusiveidrange includes 1 "" compsErrors
   # Handle error
}Version History
12.0.110
2019 - Added new optional argument pool_id.
