*combineelements
Combines the selected elements into one.
*combineelements mark tolerance angle
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing the elements to be combined.
 - tolerance
 - The maximum tolerance allowed before a node within the group of selected elements is considered to be not on the plane formed by any three nodes attached to the group of selected elements.
 - angle
 - The maximum angle between three nodes which is considered to be a flat side.
Examples
*createmark(elements,1) 10 13 15
*combineelements(1,0.1,150.0)*combineelements() only works with two-dimensional elements.
