*linessmoothtotol
Smooths a line based on a give tolerance.
*linessmoothtotol mark tol
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the lines to smooth.
tol
Tolerance used to smooth the lines.
To smooth line 1 to within a tolerance of .1
*createmark(lines,1) 1
*linessmoothtotol(1,.1)
None.
