*CE_AddLinkEntitiesWithRules
Update connectors at the specified locations with rules.
*CE_AddLinkEntitiesWithRules connector_mark_id entity_type entity_mark_id entity_state ce_rules ce_le_rule tolerance_flag tolerance num_ents
HyperMesh Tcl Modify Command
This command updates connectors at the specified locations with rules.
- connector_mark_id
 - The ID of the mark containing the connectors to update. Valid values are 1 and 2.
 - entity_type
 - Type of entity to be added to the connectors as links.
 - entity_mark_id
 - The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
 - entity_state
 - The state of the link entities. Valid values are:
 - ce_rules
 - Flag indicating when to make the links. Valid values are:
 - ce_le_rule
 - Flag indicating how to make the links. Valid values are:
 - tolerance_flag
 - Flag indicating whether to use the default tolerance. Valid values are:
 - tolerance
 - Used to add entities only within the given tolerance from the specified connector.
 - num_ents
 - Number of entities to add/update connector (connectors thickness (2T, 3T, etc.) value).
Examples
*createmark connectors 1 1 2
*createmark comps 1 21 23 24 27
*CE_AddLinkEntitiesWithRules 1 comps 2 1 1 1 1 1.0 2Errors
   # Handle error
