*hmmeshspline
Within the automeshing module, generates quad or tria elements using a flexible surfaceless algorithm. Can only be used together with *surfacemode 3 and *splinesurface.
*hmmeshspline quads
HyperMesh Tcl Modify Command
quads
If nonzero, specifies that the created elements should be quads.
To generate elements with densities of 10, 11, 10, and 10 along the given edges:
*surfacemode 3
*createmark lines 1 1 2 7 8
*createplane 1 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000
*splinesurface lines 1 0 1
*set_meshedgeparams 0 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 1 11.0 0 0 0 0 0 0 0
*set_meshedgeparams 2 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 3 10.0 0 0 0 0 0 0 0
*hmmeshspline 1
*storemeshtodatabase 0
*ameshclearsurface
None.
