*morphvolumeconnect
Joins the specified morph volumes.
*morphvolumeconnect hcube1 hcube2 tan mode nauto
HyperMesh Tcl Modify Command
- hcube1
 - ID of first morph volume.
 - hcube2
 - ID of second morph volume.
 - tan
 - 0 = no tangency
 - mode
 - 0 = join hcube2 to hcube1
 - nauto
 - 0 = do not register all nodes found inside morph volumes
*morphvolumeconnect (21,22,1,1,1)
      This command will join the specified morph volumes provided that the process does not make the morph volume "matrix" inconsistent. Newly combined morph volumes can optionally have tangency automatically applied.
None.
