*elementtestjacobian
Tests 2D and 3D elements for whether or not they pass the Jacobian ratio element quality check, and puts those that fail on the specified outputmark.
*elementtestjacobian entities markmask jacobian outputmark dimension contour title
HyperMesh Tcl Modify Command
- entities
 - The entity types to be checked. Currently, elements is the only allowable option.
 - markmask
 - The mark that contains the elements to test.
 - jacobian
 - The value to use as a threshold beyond which elements should be considered to have failed the test.
 - outputmark
 - The mark where HyperMesh should put the elements that fail the test.
 - dimension
 - A code telling to measure the dimension of:
- 2 - Measure 2D elements.
 - 4 - Measure 3D elements.
 - contour
 - A code telling if HyperMesh should:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram.
*createmark(elements,1) "displayed"
*createmark(elements,2)
*elementtestjacobian(elements,1,0.7,2,2,0,"2D Element Jacobian")
      The details of the Jacobian ratio element quality check can be found in the online help for the Check Elements panel.
