*surfaceplane
Creates a square, planar surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a square planar surface for the automesher to use under the mesh without surface option.
*surfaceplane plane id size
HyperMesh Tcl Modify Command
- plane id
 - The ID of the plane (vector and base) on which the surface will be created.
 - size
 - The length of the edges of the surface.
To create a square, planar surface normal to the x axis, with the center at the origin, of size 10.0, but not create any elements:
*surfacemode(4)
*createplane(1,1.0,0.0,0.0,0.0,0.0,0.0)
*surfaceplane(1,10.0)
      *createplane() is required for this command. The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
None.
