Remeshes 2D elements at intersection locations.
      *remesh_element_intersection
        entity_type mark_id params
      HyperMesh Tcl Modify Command
      Remeshes 2D elements at intersection locations. Elements are distributed into groups based
        on their connectivity. The elements belonging to different components may be in the same
        group. Only different groups are taken as counterparts for the intersection calculation.
        Moreover, elements sharing a node are not counterparts of the intersection calculation on
        checking element/element intersection.
          - entity_type
          - The type of entities to remesh. Valid values are comps and elems.
          - mark_id
          - The ID of the mark containing the entities to remesh. Valid values are 1 and 2.
          - params
          - The parameters of re-meshing along the cut, defined as "keyword value" format.
          - For example: "angle 30.0 generate_intersect_segments_only 0 remove_internal_shell 1
            do_only_remove_internal_shell 0 num_remesh_layers 2"
          - Valid keywords and values are:
                - angle
                - Values used to define feature edges on mesh. Default if not specified is
                  30.0.
                - break_shell_along_component_boundaries
                - All elements connected to each other are classified as a group. This defines how
                  that grouping occurs:
                - 0 - Do not break element grouping at component boundaries (default)
                - 1 - Element grouping stops at component boundaries. This means that elements in
                  an element group belong to a single component.
                - close_small_intersection_gaps
                - Specifies whether to close small gaps along intersection lines and free shell
                  mesh boundaries.
                - 0 - Do not close (default)
                - 1 - Close
                - do_only_remove_internal_shell
                - Indicates that the command only removes internal elements. It requires that all
                  intersecting elements are conformal along the common intersecting element edge
                  lines.
                - 0 - Do not apply (default)
                - 1 - Only remove internal shells. If specified,
                    remove_internal_shell must be 1 or undefined and
                    generate_intersect_segments_only must be 0 or not
                  defined.
                - gap_close_method
                - Specifies the method for closing small gaps. Gaps are closed by extending free
                  edge elements to the intersecting target mesh.
                - 1 - Tangent extension
                - 2 - Free edge normal projection
                - generate_intersect_segments_only
                - Indicates that the command only creates intersection segments.
                - 1 - Only generate intersection segments. If specified,
                    do_only_remove_internal_shell must be 0 or undefined.
                - intersection_gap_close_limit
                - The gap close size limit. Must be specified if
                    close_small_intersection_gaps=1.
                - keep_intersect_edges
                - Specifies whether to store mesh intersections as 1D elements.
                - 0 - Do not store (default)
                - 1 - Store
                - num_remesh_layers
                - Defines the number of element layers attached to intersecting elements
                  considered for remeshing. Valid values are:
                - -1 - Intersecting elements are split and stitched to obtain conformal element
                  connectivity.
                - 0 - Remesh only intersecting elements.
                - > 0 - Remesh specified additional layers in addition to intersecting
                  elements.
                - num_threads
                - Specifies the number of threads to use:
                - -1 - Multi-teading with no limit (default)
                - 0 - No multi-threading
                - > 0 - The exact number of threads
                - remove_internal_shell
                - 0 - Do not remove internal elements when selected elements form two or more
                  watertight shells.
                - 1 - Remove internal elements when selected elements form two or more watertight
                  shells (default).
                - remove_small_penetration
                - Specifies whether to remove small penetrations. A penetration consists of a
                  group of connected elements whose boundaries are only intersection lines and free
                  shell mesh boundaries.
                - 0 - Do not remove (default)
                - 1 - Remove
                - tria_remesh_growth_ratio
                - The element size growth ratio used by the adaptive tria mesher when
                    use_adaptive_tria_remesh=1. Default if not specified is 1.5.
                - tria_remesh_span_angle
                - The maximum element normal angle deviation used by the adaptive tria mesher when
                  35.0.
                - trim_removal_limit
                - The maximum distance between intersection lines and free element edges in small
                  penetrations to be removed. Must be specified if
                    remove_small_penetration=1.
                - use_adaptive_tria_remesh
                - Specifies whether to use the adaptive tria mesher when re-meshing triangular
                  elements.
                - 0 - Do not use (default)
                - 1 - Use
      To trim displayed components, removing internal shells and remeshing using 2 additional
        layers:
      *createmark comps 1 "displayed"
*remesh_element_intersection comps 1 "generate_intersect_segments_only 0 remove_internal_shell 1 do_only_remove_internal_shell 0 num_remesh_layers 2 angle 30.0"
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
