*linecreatestraight
Create a straight segment curve from coordinates.
*linecreatestraight x1 y1 z1 x2 y2 z2
HyperMesh Tcl Modify Command
This command creates a straight segment line between the given input end point coordinates. The distance between the input points must be not smaller than the global value of the geometry cleanup tolerance set by *setoption cleanup_tolerance.
- x1 y1 z1
 - Coordinates of segment start point.
 - x2 y2 z2
 - Coordinates of segment end point.
To create straight segment with endpoints (1, 2, 3) and (4, 5, 6):
*linecreatestraight 1 2 3 4 5 6
   # Handle error
}Version History
10.0
