*attributeupdate_entityidarray2d_mark
Updates an attribute, which is a 2D array of entity IDs, on a set of entities.
*attributeupdate_entityidarray2d_mark entity type mark identifier solver status behavior target entity data rows cols
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark where the list of IDs resides.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - target entity
 - The type of entity to which the attribute refers.
 - data
 - The 2D array of IDs.
 - rows
 - The number of rows in the array.
 - cols
 - The number of columns in the array.
- 1 2
 - 8 9
*createmark(loadcols,1) 1 2 3 4 5 6 7
*createarray(4) 1 2 8 9
*attributeupdate_entityidarray2d(loadcols, 1, 1234, 1, 2, 0, materials, 2, 2)
