*CE_ReviewConnectorCollectors
Review connectors by collector according to user options.
*CE_ReviewConnectorCollectors collector_type mark_id operation_type string_array number_of_strings output_mark
HyperMesh Tcl Modify Command
Review connectors according to user options according to collector.
- collector_type
 - The collector type for the connectors. Currently only supported for connectorgroup.
 - mark_id
 - The ID of the mark to review. Valid values are 1 and 2.
 - operation_type
 - The string for the type of operation to be performed:
 - string_array
 - A string array containing any additional input parameters, created using *createstringarray. This must be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string_array created using *createstringarray.
 - output_mark
 - The ID of the mark onto which reviewed entities are placed. Valid values are 1 and 2.
Examples
*createmark connectorgroups 1 "by id only" 1 2
*createstringarray 1 "consider_HAZ_elems=true"
*CE_ReviewConnectorCollectors connectorgroups 1 isolate 1 2 2Errors
   # Handle error
}Version History
2019
