Creates an FBD displacement plot, and fields or loads from the results.
      *fbddisplacement
        set_ids=<value> data_strings=<value> num_strings=<value>
      HyperMesh Tcl Modify Command
      This queries the displacement data from the result entity on a freebodysection.
          - set_ids=<value>
          - The set entity IDs.
          - data_strings=<value>
          - The ID of the string array that contains the additional input parameters. The string
            array is created using the *createstringarray command. This should
            always be set to 1.
          - Valid parameters and their syntax are:
                - arrlen=<value>
                - Controls the FBD plot arrow length.  Default is 75 (%).
                - arroworigin=<value>
                - 0 - Tail of arrow at node for the plot (default)
                - 1 - Tip of arrow at node for the plot
                - colorfx=<value>
                - The color of the Fx arrow.  Valid values are 1-64.
                - colorfxy=<value>
                - The color of the Fxy arrow.  Valid values are 1-64.
                - colorfxyz=<value>
                - The color of the Fxyz arrow.  Valid values are 1-64.
                - colorfxz=<value>
                - The color of the Fxz arrow.  Valid values are 1-64.
                - colorfy=<value>
                - The color of the Fy arrow.  Valid values are 1-64.
                - colorfyz=<value>
                - The color of the Fyz arrow.  Valid values are 1-64.
                - colorfz=<value>
                - The color of the Fz arrow.  Valid values are 1-64.
                - colormx=<value>
                - The color of the Mx arrow.  Valid values are 1-64.
                - colormxy=<value>
                - The color of the Mxy arrow.  Valid values are 1-64.
                - colormxyz=<value>
                - The color of the Mxyz arrow.  Valid values are 1-64.
                - colormxz=<value>
                - The color of the Mxz arrow.  Valid values are 1-64.
                - colormy=<value>
                - The color of the My arrow.  Valid values are 1-64.
                - colormyz=<value>
                - The color of the Myz arrow.  Valid values are 1-64.
                - colormz=<value>
                - The color of the Mz arrow.  Valid values are 1-64.
                - createfield=<value>
                - 0 - Do not create a nodal displacement field (default)
                - 1 - Create a nodal displacement field
                - createload=<value>
                - 0 - Do not create FBD displacement loads (default)
                - 1 - Create FBD displacement loads
                - declim=<value>
                - Controls the decimal limit.  Default is 2.
                - display=<value>
                - 0 - Do not plot FBD displacements
                - 1 - Plot FBD displacements (default)
                - displacement=<value>
                - 0 - Applied forces are not particupating in the FBD calculation (default)
                - 1 - Applied forces are particupating in the FBD calculation
                - freenode=<value>
                - Currently must be set to 2. This is a mandatory argument.
                - fx=<value>
                - 0 - Fx translations are not included in the plot, load or field creation
                  (default)
                - 1 - Fx translations are included in the plot, load or field creation
                - fxy=<value>
                - 0 - Fxy resultant translations are not included in the plot (default)
                - 1 - Fxy resultant translations are included in the plot
                - fxyz=<value>
                - 0 - Fxyz resultant translations are not included in the plot (default)
                - 1 - Fxyz resultant translations are included in the plot
                - fxz=<value>
                - 0 - Fxz resultant translations are not included in the plot (default)
                - 1 - Fxz resultant translations are included in the plot
                - fy=<value>
                - 0 - Fy translations are not included in the plot, load or field creation
                  (default)
                - 1 - Fy translations are included in the plot, load or field creation
                - fyz=<value>
                - 0 - Fyz resultant translations are not included in the plot (default)
                - 1 - Fyz resultant translations are included in the plot
                - fz=<value>
                - 0 - Fz translations are not included in the plot, load or field creation
                  (default)
                - 1 - Fz translations are included in the plot, load or field creation
                - mx=<value>
                - 0 - Mx rotations are not included in the plot, load or field creation
                  (default)
                - 1 - Mx rotations are included in the plot, load or field creation
                - mxy=<value>
                - 0 - Mxy resultant rotations are not included in the plot (default)
                - 1 - Mxy resultant rotations are included in the plot
                - mxyz=<value>
                - 0 - Mxyz resultant rotations are not included in the plot (default)
                - 1 - Mxyz resultant rotations are included in the plot
                - mxz=<value>
                - 0 - Mxz resultant rotations are not included in the plot (default)
                - 1 - Mxz resultant rotations are included in the plot
                - my=<value>
                - 0 - My rotations are not included in the plot, load or field creation
                  (default)
                - 1 - My rotations are included in the plot, load or field creation
                - myz=<value>
                - 0 - Myz resultant rotations are not included in the plot (default)
                - 1 - Myz resultant rotations are included in the plot
                - mz=<value>
                - 0 - Mz rotations are not included in the plot, load or field creation
                  (default)
                - 1 - Mz rotations are included in the plot, load or field creation
                - resfileid=<value>
                - The result file ID for resultid. Useful when multiple result
                  files are loaded for a single result entity.
                - resolvein_sys=<value>
                - 0 - Resolve in analysis system (default)
                - 1 - Resolve in global system
                - 2 - Resolve in user system
                - resultid=<value>
                - The result entity ID.
                - rotation=<value>
                - 0 - SPC forces are not particupating in the FBD calculation (default)
                - 1 - SPC forces are particupating in the FBD calculation
                - scid=<value>
                - The results subcase ID for resultid.
                - scientific=<value>
                - 0 - Fixed format text (default)
                - 1 - Scientific format text
                - showvalue=<value>
                - 0 - Show text (default)
                - 1 - Hide text
                - sizescale=<value>
                - 0 - Constant FBD plot arrow length (default)
                - 1 - Magnitude FBD plot arrow length
                - stepid=<value>
                - The step/simulation ID for scid.
                - tolerance=<value>
                - The tolerance to limit the values. Default is 0.00001.
                - user_sys_id=<value>
                - The system ID when resolvein_sys=2.
                - vecstyle=<value>
                - 0 - 3D FBD plot arrow (default)
                - 1 - 2D FBD plot arrow
          - num_strings=<value>
          - Integer indicating the size (number of strings) in the data_strings
            array.
      Create an FBD displacement
        plot:
*createstringarray 46 "scientific=1" "arroworigin=0" "tolerance=0.00001" "scid=1" "resfileid=1" "resultid=1" "showvalue=1" "stepid=1" "sizescale=0" "vecstyle=0" "resolvein_sys=3 " "user_sys_id=2" "displacement=1" "rotation=1" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "fxy=1" "fyz=1" "fxz=1" "mxy=1" "myz=1" "mxz=1" "fxyz=1" "mxyz=1" "arrlen=75" "declim=2" "freenode=2" "display=1" "colorfx=3" "colorfy=4" "colorfz=5" "colorfxy=7" "colorfyz=8" "colorfxz=9" "colorfxyz=12" "colormx=3" "colormy=4" "colormz=5" "colormxy=7" "colormyz=8" "colormxz=9" "colormxyz=12"
set setIds {1 2 3}
*fbddisplacement $setIds 1 46
      Create
        loads:
*createstringarray 17 "createload=1" "resolvein_sys=0" "scid=1" "resfileid=1" "resulted=1" "stepid=1" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "tolerance=0.00001" "displacement=1" "rotation=1" "display=0" "freenode=2"
set setIds {1 2 3}
*fbddisplacement $setIds 1 17
      Create a
        field:
*createstringarray 18 "createload=1" "resolvein_sys=3 " "user_sys_id=2" "scid=1" "resfileid=1" "resulted=1" "stepid=1" "fx=1" "fy=1" "fz=1" "mx=1" "my=1" "mz=1" "tolerance=0.00001" "displacement=1" "rotation=1" "display=0" "freenode=2"
set setIds {1 2 3}
*fbddisplacement $setIds 1 18
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
