*unlockallentities
Unlock all entities with the same entity type and ID pool across includes.
*unlockallentities entity_type pool_id dataname
HyperMesh Tcl Modify Command
entity_type
The type of entity to unlock.
pool_id
The ID of the solver pool.
dataname
Must be set to id.
Examples
Unlock all elements with ID pool 2:
*unlockallentities elems 2 id
   # Handle error
Version History
2019
