*surfacesplitwithline
Splits a surface with a line by sweeping the line along a vector.
*surfacesplitwithline surface line vector entire_surf_flag distance
HyperMesh Tcl Modify Command
surface
The ID of surface to be split.
line
The ID of the line used to split the surface.
vector
The vector used to sweep the line.
entire_surf_flag
1 - The line is swept throughout the entire surface.
0 - The line is swept for a distance of distance
distance
The distance to sweep line, if entire_surf_flag is set to 0.
To split surface 1 by sweeping line 2 along the x-axis for a distance of 100:
*createvector(3,1.0,0.0,0.0)
*surfacesplitwithline(1,2,3,0,100.0)
None.
