*calculateElemDrapingAngles
Calculates the draping angles of elements associated with ply.
*calculateElemDrapingAngles mark_id result_file table_name fiber_vector stamping_vector ply_id
HyperMesh Tcl Modify Command
This command updates connectors with entities.
- mark_id
 - The ID of the mark containing the ply elements. Valid values are 1 and 2.
 - result_file
 - Reserved for future use. Must be set to "".
 - table_name
 - The name of the table entity to use for storing the results.
 - fiber_vector_id
 - The ID of the vector defining the fiber direction, defined using the *createvector command.
 - stamping_vector_id
 - The ID of the vector defining the stamping direction, defined using the *createvector command.
 - ply_id
 - The ID of the ply.
Examples
*createmark elements 1 "by ply id" 10
*createvector 1 1 0 0
*createvector 2 0 1 0
*calculateElemDrapingAngles 1 "" drapetable 1 2 10Errors
   # Handle error
}Version History
13.0
