*displaycollectorsall
Controls the display state of all collectors.
*displaycollectorsall mode elements geometry
HyperMesh Tcl Modify Command
mode
The mode being performed, defined by the following:
  • on - All collectors are turned on.
  • all - All collectors are turned on.
  • off - All collectors are turned off.
  • none - All collectors are turned off.
  • toggle - All collectors are toggled (visible become invisible and vice-versa).
  • reverse - All collectors are toggled (visible become invisible and vice-versa).
elements
Indicates if elements within collectors are to be turned on or off.
  • 1 - Yes
  • 0 - No
geometry
Indicates if geometry within collectors are to be turned on or off.
  • 1 - Yes
  • 0 - No
To turn off all entities in the user mark, except geometry:
*displaycollectorsall(off,1,0)
