*createinclude
Defines a new include file in the database.
*createinclude id shortname fullname parentid
HyperMesh Tcl Modify Command
- id
 - Use 0, if HyperMesh should take the next available ID. Specifying a non-zero value will overwrite any existing include that already uses that ID value.
 - shortname
 - The last portion of the fullname (not including path). Short names must be unique.
 - fullname
 - The include’s full name, including file path. Must be unique, and must conform to the shortname, as described above.
 - parentid
 - The identifier for the file that includes this file.
Examples
*createinclude(0,mat1.dyn,C:/common files/mats/mat1.dyn,0)
