*CE_FE_UCCUpdateUseConnector
Updates a connector control using a connector.
*CE_FE_UCCUpdateUseConnector cc_name ce_id
HyperMesh Tcl Modify Command
- cc_name
 - The name of the connector control to update.
 - ccd_name
 - The ID of the connector to use.
Comment.
Examples
Update a connector control named "my_acm" from connector 101:
*CE_FE_UCCUpdateUseConnector "my_acm" 101
   # Handle error
}Version History
2021
