*blmesh_2d_computeblthickness
Generates boundary layer thickness on boundary nodes, with specified parameters.
*blmesh_2d_computeblthickness base_entity_type base_mark_id num_layers first_layer_thickness growth_rate core_to_BL_ratio corner_factor
HyperMesh Tcl Modify Command
Specifies non-boundary layer input for *bl_mesh2d2 and *bl_mesh2d_computeblthickness.
If *blmesh_2d_input_nonbl is not called before *blmesh_2d2, then all edges of the selected region are considered as boundary layer edges.
- base_entity_type
 - The type of entities to use for the base to generate BL thickness. Only elems are valid.
 - base_mark_id
 - The ID of the mark containing the base entities. Valid values are 1 and 2.
 - num_layers
 - The number of boundary layers to generate.
 - first_layer_thickness
 - The thickness value of the first layer.
 - growth_rate
 - The growth rate of the boundary layers.
 - core_to_BL_ratio
 - Ratio of core mesh to BL thickness, which is used for BL reduction.
 - corner_factor
 - A dimensionless value used for corner management. The range is 0.1-1.0 for thinner BL thickness, and 1.0-10.0 for thicker BL thickness.
Examples
*createmark elems 1 1 2
*createmark elems 2 5 6
*blmesh_2d_input_nonbl elems 1 elems 2 1
*createmark elems 1 10-100
*blmesh_2d_computeblthickness elems 1 5 0.15 1.2 2.5 1.1Errors
   # Handle error
}Version History
11.0.130
