*positiondummy
Positions the components of a dummy.
*positiondummy entities collectorId x y z
HyperMesh Tcl Modify Command
- entities
 - The entity type selected that recognizes the dummy. Currently, only components are supported.
 - collectorid
 - The id of the entity recognizing the dummy.
 - x
 - The X coordinate to which the dummy is translated.
 - y
 - The Y coordinate to which the dummy is translated.
 - z
 - The Z coordinate to which the dummy is translated.
To translate a dummy, use any collector belonging to the dummy (and is part of the parent/child system) and select the x, y, and z coordinates to position it to:
positiondummy(components, 1, 0.0, 30.0, 0.0)
None.
