*surfacesplitwithsurface
Splits one surface with another.
*surfacesplitwithsurface surface1 surface2
HyperMesh Tcl Modify Command
- surface1
 - The surface to be split.
 - surface2
 - The surface used to split surface1.
*surfacesplitwithsurface(1,2)Errors
None.
