*optimized_mesh
Generates a mesh with the selection of the best meshing algorithm and optimization of node positions.
*optimized_mesh mark_id filename elem_size elem_type smooth_across feature_angle algorithm do_remesh comp_mode
HyperMesh Tcl Modify Command
This command is used to create a mesh on a surface using saved or default parameters on surfaces and specifying various options. Any elements attached to the input surfaces are deleted before the meshing operation.
- mark_id
 - The mark ID containing the surfaces to mesh. Valid values are 1 and 2.
 - criteria_file
 - The full path and filename for the user-defined quality index criteria file. If no file is given, "dummy" should be specified.
 - elem_size
 - The default element size used to calculate element densities along edges for topology cleanup operations.
 - elem_type
 - The type of elements to create. Valid values are:
- 0 - trias
 - 1 - quads
 - 2 - mixed
 - 3 - right trias
 - 4 - quads only
 - smooth_across
 - Flag indicating whether to ignore surface edges for element smoothing and cleanup
            operations. Valid values are:
- 0 - Honor surface edges for element smoothing and cleanup.
 - 1 - Ignore surface edges for element smoothing and cleanup.
 - feature_angle
 - The angle, in degrees, specifying the feature lines. This is approximately the minimum angle between the elements adjacent to a feature line.
 - algorithm
 - Determines the algorithm for surface meshing. Valid values are:
- 0 - Standard surface meshing
 - 1 - Meshing with flow "align" control
 - 3 - Meshing with flow "align" and "size" control
 - do_remesh
 - Flag indicating whether to keep or delete existing elements on the surfaces. Valid
            values are:
- 0 - Keep existing elements on selected surfaces.
 - 1 - Delete existing elements on selected surfaces.
 - comp_mode
 - Parameter specifying how entities are organized into components:
- 0 - Elements are created in the current component.
 - 1 - Elements are created in the same components as their parent surfaces.
To start the optimization process with a criteria file named C:/criteria/mycriteria.txt for displayed surfaces, with tria elements, element size of 15, feature angle of 35 degrees, ignoring surface edges for smoothing and new elements created in their surface components:
*createmark surfaces 1 displayed
*optimized_mesh 1 "C:/criteria/mycriteria.txt" 15 0 0 1 35 0 0 1
   # Handle error
