*createcirclefrompointplane
Creates a circle or arc by spinning a point about the normal vector of a plane.
*createcirclefrompointplane list_id plane_id angle offset
HyperMesh Tcl Modify Command
This command creates a circle or arc by spinning a point about the normal vector of a plane.
- list_id
 - The ID of the list containing the nodes to be spun. A circle or arc is created for each node in the list.
 - plane_id
 - The ID of the plane defining the circle normal, defined using the *createplane command. The center of each circle is located at the base of the plane. This must be set to 1.
 - angle
 - The angle of the arc. To create a circle, set to 360.
 - offset
 - Sets the starting offset for an arc.
Examples
*createplane 1 0.0 0.0 1.0 0.0 0.0 0.0
*createlist nodes 1 18
*createcirclefrompointplane 1 1 360.0 0.0Errors
   # Handle error
