*hf_FillDoubleAttachedPart
Reflects the current die part, duplicating elements and surfaces, and fills the gap in between, creating the surface and the mesh in the die part component.
*hf_FillDoubleAttachedPart creation_flag x_coord y_coord z_coord gap n1 n2
HyperMesh Tcl Modify Command
This command reflects the current die part, duplicating elements and surfaces, and fills the gap in between, creating the surface and the mesh in the die part component.
creation_flag
1 - Triangular mesh method.
2 - Ruled surface method.
x_coord
The reflection direction x-coordinate.
Y_coord
The reflection direction y-coordinate.
Z_coord
The reflection direction z-coordinate.
gap
The minimum distance between the original and reflected parts.
n1
The node ID of the first node on the part profile of the area to enclose.
n2
The node ID of the second node on the part profile of the area to enclose.
To create the double attached part using the ruled surface method, a symmetry plane of 1., 0., 0., a gap of 5.7 and nodes 23 and 34 on the part profile:
*hf_FillDoubleAttachedPart 2 1 0 0 5.7 23 34
   # Handle error
Version History
11.0
